• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Auto mask Leaves a Halo - bug or feature?
Explorer ,
Aug 13, 2017 Aug 13, 2017
I am running LR CC 2015.12 on an iMac
I have struck problems with halos before but had never really examined them. In this case I have a statue against a bright cloudy sky. I painted the sky with a de-haze brush then switched to Auto-mask to paint around the edges. Auto-mask left a clearly defined 1 pixel halo around the clearly defined edge. To remove the halo I had to zoom in 3:1 then paint carefully with a hard edged brush (zero feather). This pretty much negates to usefulness of auto-mask and I think is a bug. The problem seems to affect hard edges in particular and is certainly no apparent on softer edges.
Views
379
Translate
Translate
Report
Report
Community guidelines
community guidelines
LEGEND ,
IIRC yes this is a bug of some type when using it on hard edges.
Votes
Translate
Translate
Report
Report
Community Expert ,
I don't believe that is a bug, but a result of simple physics.  Whenever you have a dark object against a light background, there is generally a degree of Chromatic Aberration created in the image due to the very slight differences in the way light of different wavelengths (Color) travel through the lens.  This is the most likely cause of the halo when using the brush.  You can try to remove this by first going to Lens Correction and checking the box to remove Chromatic Aberration.  If that does not work, try your hand at manual correction.  Results will vary.  Generally it is best to avoid making major brush adjustments in this case.
Votes
Translate
Translate
Report
Report
Explorer ,
Joe, your answer doesn't make much sense to me. I don't see what physics has to do with it. I do understand what causes chromatic aberration.
As a matter of course I always remove chromatic aberration and enable profile corrections. I don't believe either has any effect on edge detection. In this case there is none, just a clean edge which auto-mask won't go within a pixel of. That doesn't sound like desirable behaviour to me.
Avoiding major brush adjustments where there is a hard edge is certainly an option but not something I would be looking for in a premium photo processing package.
I would be interested in work-arounds other than tedious hand painting.
Votes
Translate
Translate
Report
Report
Community Expert ,
LATEST
Chromatic Aberration is not always complete removed.  Even if it were, physics is still involved.  The "clean" edge you are referring to is not as clean as you think, except perhaps for vertical or horizontal edges.  Pixels are square with vertical and horizontal edges.  A diagonal or curved edge is not "clean" as there is some smoothing going on to add realism to curved and diagonal lines (Anti-Aliasing), which is part of the problem you are seeing; this also results in difficulties in removing Chromatic Aberration. Magnify your image to 10 to 1 to view individual pixels and you will see that the edge is not "Clean".  Premium package or not, physics makes this a very difficult task.  You are pushing the math beyond the capability of auto mask.
Votes
Translate
Translate
Report
Report
