1 Reply Latest reply on Aug 14, 2017 3:34 AM by tpk1982
    Error with Javascript file that was working perfectly
    alice9091
      I have been using a script to export all text from a document and haven't had any issues with it.
      Then today I went to use it and I'm am having this message pop up.
      JavaScript Error!
      Error Number: 48
      Error String: Cannot find the folder "/Volumes/Private/var/folders/d1/7nsrmmm94kb872qbgvv5tl9c0000gn/T/TemporaryItems/tempText File.txt".
      Engine: main
      File: /Applications/Adobe InDesign CC 2017/Scripts/Scripts Panel/Samples/JavaScript/ExportAllText CS3.jsx
      Line: 55
      Source: myStory.exportfile(ExportFormat.taggedText,myTempFile);
      Here is the script I have been using.
      Any suggestions?
      if(app.documents.length != 0){
        if(app.documents.item(0).stories.length != 0){
        myGetFileName(app.documents.item(0).name);
      //========================= FUNCTIONS ===========================
      function myGetFileName(myDocumentName){
        var myFilePath = File.saveDialog("Save Exported File As:");
        if(myFilePath != null){
        myDisplayDialog(myDocumentName, myFilePath);
      function myDisplayDialog(myDocumentName, myFilePath){
        //Need to get export format, story separator.
        var myExportFormats = ["Text Only", "Tagged Text", "RTF"];
        var myDialog = app.dialogs.add({name:"ExportAllStories"});
        with(myDialog.dialogColumns.add()){
        with(dialogRows.add()){
        with(dialogColumns.add()){
        var myExportFormatDropdown = dropdowns.add({stringList:myExportFormats, selectedIndex:0});
        var myAddSeparatorCheckbox = checkboxControls.add({staticLabel:"Add separator line", checkedState:true});
        var myResult = myDialog.show();
        if(myResult == true){
        var myExportFormat = myExportFormats[myExportFormatDropdown.selectedIndex];
        var myAddSeparator = myAddSeparatorCheckbox.checkedState;
        myDialog.destroy();
        myExportAllText(myDocumentName, myFilePath, myExportFormat, myAddSeparator);
        else{
        myDialog.destroy();
      function myExportAllText(myDocumentName, myFilePath, myExportFormat, myAddSeparator){
        var myPage, myStory;
        var myExportedStories = [];
        var myTempFolder = Folder.temp;
        var myTempFile = File(myTempFolder + "/tempTextFile.txt");
        var myNewDocument = app.documents.add();
        var myDocument = app.documents.item(myDocumentName);
        var myTextFrame = myNewDocument.pages.item(0).textFrames.add({geometricBounds:myGetBounds(myNewDocument, myNewDocument.pages.item(0))});
        var myNewStory = myTextFrame.parentStory;
        for (var i = 0; i < myDocument.pages.length; i++) {
        myPage = myDocument.pages.item(i);
        for (var t = 0; t < myPage.textFrames.length; t++){
        myStory = myPage.textFrames[t].parentStory;
        if (!IsInArray(myStory.id, myExportedStories)) {
        //Export the story as tagged text.
        myStory.exportFile(ExportFormat.taggedText, myTempFile);
        myExportedStories.push(myStory.id);
        //Import (place) the file at the end of the temporary story.
        myNewStory.insertionPoints.item(-1).place(myTempFile);
        //If the imported text did not end with a return, enter a return
        //to keep the stories from running together.
        if(i != myDocument.stories.length -1){
        if(myNewStory.characters.item(-1).contents != "\r"){
        myNewStory.insertionPoints.item(-1).contents = "\r";
        if(myAddSeparator == true){
        myNewStory.insertionPoints.item(-1).contents = "----------------------------------------\r";
        } // if not exported
        } // for text frames
        } // for pages
        switch(myExportFormat){
        case "Text Only":
        myFormat = ExportFormat.textType;
        myExtension = ".txt"
        break;
        case "RTF":
        myFormat = ExportFormat.RTF;
        myExtension = ".rtf"
        break;
        case "Tagged Text":
        myFormat = ExportFormat.taggedText;
        break;
        myNewStory.exportFile(myFormat, File(myFilePath));
        myNewDocument.close(SaveOptions.no);
        myTempFile.remove();
      function myGetBounds(myDocument, myPage){
        var myPageWidth = myDocument.documentPreferences.pageWidth;
        var myPageHeight = myDocument.documentPreferences.pageHeight
        if(myPage.side == PageSideOptions.leftHand){
        var myX2 = myPage.marginPreferences.left;
        var myX1 = myPage.marginPreferences.right;
        else{
        var myX1 = myPage.marginPreferences.left;
        var myX2 = myPage.marginPreferences.right;
        var myY1 = myPage.marginPreferences.top;
        var myX2 = myPageWidth - myX2;
        var myY2 = myPageHeight - myPage.marginPreferences.bottom;
        return [myY1, myX1, myY2, myX2];
      function IsInArray(myString, myArray) {
        for (x in myArray) {
        if (myString == myArray[x]) {
        return true;
        return false;
      [EDIT – moved to In Design Scripting – moderator]
