• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Can you batch import custom stamps into Acrobat Reader DC?
New Here ,
Aug 14, 2017 Aug 14, 2017
We have a pdf with over 60 custom stamps which we can import into Acrobat Pro X, but is there a way to import these stamps into Acrobat Reader DC in one go?
I can see that there is an option to import each stamp individually but to save time I'd like to import them all in one go. Is this possible, or is it restricted to the paid version of acrobat?
Regards,
John
TOPICS
Windows
Views
16.4K
Translate
Translate
Report
Report
Community guidelines
community guidelines
Community Expert , Aug 15, 2017 Aug 15, 2017
You can do it by locating the Stamps folder of Acrobat and then the PDF file that contains the stamp templates. Then copy it to the Stamps folder of Reader and they will be automatically imported into the application the next time you open it.
The exact location of this folder depends on your OS and version of Acrobat/Reader. For example, on Windows 7 with Acrobat XI it's:
C:\Users\<USER NAME>\AppData\Roaming\Adobe\Acrobat\11.0\Stamps
Votes
Translate
Translate
Community Expert ,
Votes
Translate
Translate
Report
Report
New Here ,
Thanks try67​, worked a treat
Votes
Translate
Translate
Report
Report
New Here ,
Dec 27, 2017 Dec 27, 2017
I have located the Stamps folder and PDF files from my origin in Acrobat 10 Pro on windows 7, but having trouble locating the equivalent destination for Acrobat Pro DC (CC) under windows 10. Any ideas? Thanks!
Votes
Translate
Translate
Report
Report
Community Expert ,
In Acrobat, press Ctrl+J and paste this code into the window that opens:
app.getPath("user", "stamps")
Then press Ctrl+Enter and it will print out the path of the Stamps folder for this user.
Votes
Translate
Translate
Report
Report
New Here ,
Jun 26, 2018 Jun 26, 2018
I have done this, found the path and my stamps are in the correct folder, but they are not showing up in Acrobat 8 Professional. They worked perfectly until I had to reinstall Windows 10 and Acrobat.
Any ideas why they're not showing up in the program even though they're in the correct folder?
-Amanda
Votes
Translate
Translate
Report
Report
Community Expert ,
Acrobat 8 is a very old version, and not compatible with Windows 10, so such problems are to be expected. Might be time for an upgrade...
Votes
Translate
Translate
Report
Report
New Here ,
As I said, they were working perfectly on Windows 10 in Acrobat 8 before I had to do the fresh install thanks to a Microsoft update that warped my system.
However, I also tried to install them in the latest edition of the Reader, and they still didn't show up, so could it be something with the stamp document itself? They are all in a PDF file, one stamp per page.
Votes
Translate
Translate
Report
Report
Community Expert ,
How did you install them, exactly?
Votes
Translate
Translate
Report
Report
New Here ,
Sep 29, 2019 Sep 29, 2019
Anyone got a solution for the same issue for Acobat DC ? Dumping the PDFs into the the above folder does not work for me in Win 10
Votes
Translate
Translate
Report
Report
New Here ,
Jul 08, 2020 Jul 08, 2020
I am having the same struggle with DC.  Some of my files show up after I drop them into the stamps folder.  Other files want me to import each image seperately.  With hundreds of stamps in a file, I'll never get all of my engineers to spend the time to get all of these stamp files installed on their computers.
I would love some direction on this.  None of my custom stamps are dynamic.  Just simple graphics like a flagnote symbol with a letter inside.
Votes
Translate
Translate
Report
Report
Community Expert ,
Doing what I described above should be enough. What do you mean by "Other files want me to import each image seperately", exactly?
Votes
Translate
Translate
Report
Report
New Here ,
Jul 15, 2020 Jul 15, 2020
It doesnt work for me too.
Win 10 Acrobat Pro DC
Found the right folder in AppData.
https://blogs.adobe.com/acrolaw/2014/11/23-free-review-stamps-for-acrobat/#comment-40713
This stamp examples work fine. But if i make my own it doesnt work.
If i copy the example file and rename it, the stamps are added to the "base" file.
Im trying to make the pdf stamp file with illustrator. each stamp has its own page (artboard). and there is a blank page up front.
I think it has something to do with the PDF Standards.
Votes
Translate
Translate
Report
Report
New Here ,
right now i nearly tried every pdf format illustatir can export. Nothing is working. this shouldnt be such a pita
Does anyone can make stamps in illustrator and can put them in the "autostart" of acrobat pro dc standard stamps? Like in the blog?
Votes
Translate
Translate
Report
Report
New Here ,
Oct 05, 2021 Oct 05, 2021
I am having the same issue. Running Acrobat Pro DC on Win10. Got a new system. Have nearly 60 individual custom stamps [made in Illustrator, saved as individual PDFs] to add. Always been able to add but had to do one at a time, which is time-consuming. Found the AppData folder noted above but, even after closing/reopening Acrobat several times, restarting system, Acrobat does not see the new stamps placed in the DC/Stamps folder.
Votes
Translate
Translate
Report
Report
New Here ,
Feb 04, 2022 Feb 04, 2022
I spoke to tech support about the same issue, and they told me you have to do them one at a time. I also have 60 stamps! This is ridiculous. Everything messed up when I upgraded to Pro.
Votes
Translate
Translate
Report
Report
Community Expert ,
Feb 05, 2022 Feb 05, 2022
You don't. Just copy the files from the location I specified above to the parallel one in the new version. Do NOT use those files to create new stamps in Acrobat (or Reader). Just copy them over.
Votes
Translate
Translate
Report
Report
New Here ,
Aug 10, 2023 Aug 10, 2023
any guidance on how to do this on a mac? I'm lost
Votes
Translate
Translate
Report
Report
Community Expert ,
Aug 11, 2023 Aug 11, 2023
LATEST
It's exactly the same as on Windows. You just need to locate the correct path where the stamp files are located.
Votes
Translate
Translate
Report
Report
Community Expert ,
MOVED TO THE ACROBAT READER FORUM
Votes
Translate
Translate
Report
Report
