We are calling IDS from a nodejs app using the "node-soap" component. We are now introducing sessions and encountering the issue.
I just stared a session and tried to close it. Always get error message inside the event soapError saying "Client opened session with ID 1 but the SOAP header targets session with ID 2!" .If I try to run it again I get error "Client opened session with ID 1 but the SOAP header targets session with ID 3!". Tried runscript() also , It ran successfully but still get the error message.
I use indesign server 2015.
Please see the code which I use,
var soap = require("soap");
var url = "http://localhost:8194/wsdl?wsdl";
var args = { "IDSP:runScriptParameters":
"scriptLanguage": "javascript",
"scriptFile": scriptPath,
"IDSP:scriptArgs" : [
{ "IDSP:name" : "user",
"IDSP:value" : thisUser}
soap.createClient(url, function(err, client) {
client.on("soapError", function(err) {
console.log(err.message);
return errDataCallback(soapErr);
var sessionId;
client.BeginSession(function(err,session,test1){
sessionId = session.sessionID;
console.log("sessionID : "+sessionId);
if(err){
return errDataCallback(err);
var result = client.addSoapHeader({"sessionID":sessionId},"sessionID","IDSP","");
var sessionArg = { "IDSP:sessionID": sessionId.toString()};
client.EndSession(sessionArg, function(err){
Please help me to resolve the issue.
Ok I finally figure it out.
The issue is that IDS attach in some way a socket to a session.
So whenever the socket is closed, the session is closed as well.
The trick in nodejs is to create a custom http.Agent you pass to your http request for each session you want to be maintained with (for example) those params :
let keepAliveAgent = new http.Agent({
keepAlive: true, // so the socket is not closed after http request completion (do not forget to do a request.end() after your request.wri
Moving to InDesign Server Developers Forum
Anybody worked with Indesign server + node js.
Is there anyone form Adobe team to help with ?
keepAlive: true, // so the socket is not closed after http request completion (do not forget to do a request.end() after your request.write())
keepAliveMsecs:600000, // set to enough time to not have the connection timed out
maxSockets:1 // ensure that the Agent does not open an other parralell socket
Then for each http request you create to be executed within the session (including the beginSession and endSession) you pass that Agent as parameter :
RequestOptions = {
hostname: server.hostname,
port: server.port,
path: server.path,
method: 'POST',
headers: {
'Content-Type': 'text/xml;charset=UTF-8',
'Content-Length': Buffer.byteLength(postData),
'Connection': 'Keep-Alive',
'SOAPAction':'""'
agent:keepAliveAgent
For any new session, you just create a new http.Agent ...
