• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Photoshop aspect ratio is off (warped)
Community Beginner ,
Aug 14, 2017 Aug 14, 2017
Hello guys,
I was receiving an prompt whenever opening the program, apparently my aspect ratio correction was turned on, I since turned it off. Now when using the program the dimensions of fonts, shapes, images, etc.. appears to be off. For instance holding the shift key while using the lasso tool draws something closer to a oval rather than a perfect circle. As I've mentioned it appears to be affecting anything I try to manipulate using photoshop. I'm curious as to whether there's anyway to restore to the original settings of the program upon downloading or perhaps some one has a resolution to this very peculiar issue. Thanks in advance for any help with this matter.Screen Shot 2017-08-14 at 11.18.58 PM.png
Views
1.3K
Translate
Translate
Report
Report
Community guidelines
community guidelines
Community Expert , Aug 15, 2017 Aug 15, 2017
Just to be absolutely clear:
When you now create a brand new document with pixel aspect ratio correction off and with square pixels in the create document dialogue are you still seeing the aspect ratio incorrectly?
If so I would reset preferences. Go to Preferences >General>Reset Preferences on Quit and then click OK. You will then need to close and restart Photoshop.
If you are only seeing this on existing documents then turn off the aspect ratio correction and use image size (with resample) to co
Votes
Translate
Translate
Adobe
New Here ,
Votes
Translate
Translate
Report
Report
Community Expert ,
If you are only seeing this on existing documents then turn off the aspect ratio correction and use image size (with resample) to correct the ratio and resave the document.
Dave
Votes
Translate
Translate
Report
Report
Hey Dave!
Problem solved. Thank you so very much, such a relief. For whatever reason the pixel aspect ratio was set to wide screen as opposed to square as I'm accustomed to.
Best Regards,
Devin
Votes
Translate
Translate
Report
Report
LATEST
Hey Z,
I can't thank you enough, I'm such a visual person, I learn with my eyes.. I truly appreciate your assistance with this issue! The pictures were really useful.. you're a life saver
All the Best!
Devin
Votes
Translate
Translate
Report
Report
