1 Reply Latest reply on Aug 15, 2017 12:34 PM by thebenrobb
    Complete Data Elements
    dorgan Level 1
      Is there a way to store Objects as Data Elements?  The reason I ask is we have a current data layer that we utilize and I would like to only define one data element call it model, then when populating extension values populate them as "%model%.attribute"  is there a way to do this?
        • 1. Re: Complete Data Elements
          thebenrobb Adobe Employee
          You can store objects as data elements, but you can't access them with the
          %model%.attribute
          pattern because everything outside of the %% is interpreted as literal text.
          And you can't use
          %model.attribute%
          because people actually use '.' in their data element names and we can't support both ways of doing it.  And our developers are sad about that.
          If you're doing this inside of custom code, then you can do something like
          _satellite.getVar('mydataelement').attribute
          to get access to those attributes.
