I am facing this issue since a week, and have invested enough time in trying to rectify it through all the measures mentioned in your forums.
The file opens up , and the moment I have to cut an element from the keyboard shortcut, the AI crashes. It says "A problem caused the program to stop working correctly. Windows will close the program and notify you if a solution is available."
Now I don't understand at all what the issue is and I am almost helpless.
I work for an MNC and the IT and software support staff here also are clueless about this now.
Really looking forward to resolution.
It is causing me to lose precious project time.
Ashish
Does this happen if you create a new file draw a simple shape and cut, or might this be happening only on a file you are working on.
If this happens on all files (the windows locations are similar, but I do not work on windows anymore as the platform has too many problems):
Reset Your Preferences.
Cmd-Opt-Ctrl-Shift when restarting AI on a Mac or Alt-Crtl-Shift on a PC to reset to the defaults.
More Thorough Reset Your Preferences.
Quit Illustrator
Finder >> Shift Command G
~/Library/Preferences/Adobe Illustrator 21 Settings/en_US*/Adobe Illustrator Prefs
rename Adobe Illustrator 21 to Adobe Illustrator 21 old
Reset Your Other Preferences
Quit Illustrator
~/Library/Application Support/Adobe/Adobe Illustrator 21/
Press Win+R -> appdata -> Roaming -> Adobe -> rename folder Adobe Illustrator 20 (or 21) Settings to any other name.
This may also happens because of a font you have loaded or a non standard software from a clipboard enhancer to antivirus app. SO let us know some more about nothing you may have installed.
Hi Mike,
Thanks for writing back.
I have already tried all the options pertaining to the preferences deletion / auto-creating new preference file, etc.
As I work for a big brand, they have their own font. I have tried deleting the font and opening the illustrator, still the issue persists. So hopefully, its not a font issue as well.
I have also tried moving all the plugins in a different folder and tried adding them back one by one. that also didn't help.
There is no non-standard software as all are regulated by the company license managers.
There is nothing that I have installed on my own as even this laptop hardware is pretty new (I got it from company a week back). Dell Inspiron 5520.
So lemme know if you have any other idea about this. I will be happy to try
Please contact customer care:
This Customer Care portal is a gimmick, putting me in a circle of Forums and similar stuff, that I have already gone through, without giving clear contact details for me to reach and call out for help.
It will be much better if I receive a direct mail id or contact number.
thanks
Ashish
Are you logged into your account when using the page?
Yes.
The Creative Cloud App runs behind and can be accessed through the icon in the taskbar on the right end.
I tried quitting that and then run AI independently.
Still the CUT operation causes the AI to crash.
Sorry, I was referring tp being logged in to your account when using the "Customer Care" page.
Well Yes, I am logged in through my company id, through which I have raised this same concern.
You might need someone to log into your computer to search for the issue. I have alerted staff.
Thanks. Let me know what the process is. I will have to take necessary permissions meanwhile.
thanks
Ashish
The staff person will decide what is necessary. Please have a little patience.
I don't know when they will contact you.
How often does this happen and on all files even new ones?
Did this start immediately at a certain time or increase in occurrence. If this started after a certain date, do a system restore to before that date. Once you fix your problem create a manual restore point as windows likes this best, and a the auto ones often fail.
Check you recently installed apps, google anything suspicious or you do not recognize and follow instructors to remove.
Try creating a new user account to see if the problem exists.
There is a number of malware that for some reason causes only Illustrator to act up. Does not matter if you work for a MNC or SE, but have had success with this:
Malwarebytes | Free Cyber Security & Anti-Malware Software
As a last resort
Use the Creative Cloud Cleaner Tool to solve installation problems
then reinstall
Hi Mike,
1. It started immediately after first 2-3 days of light usage.
2. It happens on all the files, irrespective of the size of the doc.
3. Not sure if I can do a system restore. This system itself is 7 days old and regulated by the IT department.
4. No recently installed apps. the only things I installed was keyshot (that I had in the old system as well where AI was running fine)
5. Creation of new user account cant happen as there is only one Company email id on which this license is registered
6. Not sure if I can download the malware remover tool but can try the CC Cleaner tool.
Ashish
iI Ashish,
Check your control panel to see you recently installed apps. If you google something suspicious, then you can let your IT department know. Make sure any system enhancers are uninstalled from clipboard modifiers, to anti virus. The app you mentioned is a standalone app, so that should be good.
Creating a new user account should not affect your Adobe install, as you would log into the adobe club using your credentials. This way we know if the problem is in your OS folder, or users folder, cut the locations to troubleshoot in half.
Since this is a new system, do a cleaner than reinstalling may be the best route, though on windows infections can happen very quickly.
You can also try an OOBE reset.
Adobe Creative Cloud desktop app doesn't open or shows a spinning progress wheel
I did not suggest earlier as that helps slow opening, saves, or adobe cloud spinning wheel. That you have a new install leads me to suggest the OOBE reset and is quite quick and often effective. Just make sure you quit the cloud so the cached database is cleared out.
Hi Mike,
There are no additional apps/software installed.
We even tried disabling the Antivirus and tried running AI. it still crashed when I tried to CUT an artwork using Ctrl + X.
We even tried not logging in the CC app and tried running AI. It still crashed. So its not linked with account.
We ran the Adobe CC cleaner, to no use. After reinstallation, it still crashed.
No sure what is OOBE Reset. but if it is the OS reset, I might have to ask my IT Admin again to do it.
thanks
Ashish
The Link I posted describes the OOBE reset. But quit both Illustrator and the cloud app to do this properly, very important.
You want to always run the Adobe cloud with the app. Running without is what can corrupt the OOBE, and your other prefs.
Hi ashishh1986,
I've sent you a personal message, please check and respond so that we can proceed with further troubleshooting.
Regards,
Om
