Hello,
My script contains this line:
var new_dataMOVIE = {"Output File Info": {"Full Flat Path": fullFlatPathMOVIE + myCompText}};
The path it creates is correct, but when AE makes the output module it's adding a duplicate volume and subdirectory to the beginning of the path.
For example, the script builds a path that reads:
"/Volumes/ourserver/PROJECTS/ourproject/user/shot/...etc"
Which is what the actual path should be.
But after it adds the output module, the output module path now reads:
"/Volumes/PROJECTS/Volumes/ourserver/PROJECTS/ourproject/user/shot...etc"
Am I using "Full Flat Path" incorrectly?
Thanks, all, for any help.
Hard to tell without seeing the context, but outputModule accepts File object, so you could try this:
renderQueue.items[0].outputModules[1].file = File(["Output File Info"]["Full Flat Path"]);
