I've been setting up my character in Photoshop with the main animation in mind to be just mouth movements (lip sync). Watching Okay Samurai's
Am I missing something?
Sam (:
That should work - just make sure you have the lip sync behavior added and armed.
See Red Clay Lips on http://adobe.com/go/chexamples as a good example to follow.
Thanks for replying so fast, I'm not too sure what you mean by added and armed or how to find out if they are or not. Also, I downloaded the red lips and its noticed that I added it in my CH history window, but it hasn't seemed to have done anything in either the puppet, scene or properties window.
With the red lips:
Make sure the puppet is selected in the project panel (upper left).
Click "Add to new scene" below.
Check to make sure the microphone icon is on under the webcam and that the bar next to it is turning green when you talk.
Check to make sure under the webcam in the properties panel, the "lip sync" behavior has a red dot next to it.
If you do all these steps, the lips should swap out while you talk.
