Hello!
I'd like to start a script to resize my artboard (in my case, just one for document) based on Center-Bottom reference point.
Example: my file originally have 200x100mm and I want to change to 230x140mm without moving any content.
reason: I work with a lot of label that change the page size only depending of which manufacturer. (I will build a database inside the script after).
Any clue will be appreciated.
Hi
Thanks a lot for the article indication which was very helpful, but I found another article Re: Is it possible to resize all artboards at once the way you used to be able to do in document set-up? by CarlosCanto​ that brought me this:
...#target Illustrator
// script.name = resizeArtboards_CS4andUp.jsx;
// script.description = resizes all artboards;
// script.requirement = one document with at least one artboard;
// script.parent = carlos canto // 11/4/12;
// script.elegant = false;
You can reference below article.
https://forums.adobe.com/message/5770566
However, previouse one based Top-Left position and you have to calculate and set to Bottom-Center.
Hi
Thanks a lot for the article indication which was very helpful, but I found another article Re: Is it possible to resize all artboards at once the way you used to be able to do in document set... by CarlosCanto​ that brought me this:
#target Illustrator
if (app.documents.length > 0) {
//alert("more than 0");
var idoc = app.activeDocument;
var title = "Resize All Artboards";
var width = Number(Window.prompt ("Enter New Artboard Width in points", 400, title));
var height = Number(Window.prompt ("Enter New Artboard Height in points", 250, title));
for (i=0; i<idoc.artboards.length; i++) {
var abBounds = idoc.artboards.artboardRect;// left, top, right, bottom
var ableft = abBounds[0]; // 0
var abtop = abBounds[1]; // 612
var abwidth = abBounds[2] - ableft; // 792 // width
var abheight = abtop- abBounds[3]; // 0 // height
var abctrx = abwidth/2+ableft;
var abctry = abtop-abheight;//edited from original
var ableft = abctrx-width/2;
var abtop = abctry+height;//edited from original
var abright = abctrx+width/2;
var abbottom = abBounds[3]; //edited from original
idoc.artboards.artboardRect = [ableft, abtop, abright, abbottom];
else {
alert ("there are no open documents");
I hope it helps somebody else with the same question.
So what if I went to set the artboard to inches instead of point and what If I want it to center from the middle?
