4 Replies Latest reply on Jul 1, 2008 7:29 AM by Applied CD
    _system.milliseconds is negative?
    Applied CD Level 1
      I’ve got a giant array of audio sample data (glFreqData[sampleTime]), about 1700 samples, 16 frequency bins per sample. I’m using the following code to convert system time to a sample time index however on some machines I’m getting a negative sample index. My guess is that _system.milliseconds is exceeding maxInteger but I don’t see any documentation on what to expect when that happens (if you do the math, _system.milliseconds will exceed maxInt in just under 25 hours). I can easily flip the sign but when the time is negative, is the system counting up (toward 0), or down (increasingly negative)?
      mySample = ((_system.milliseconds/100) mod glFreqData.count) + 1
        • 1. Re: _system.milliseconds is negative?
          Level 7
          I think I have a different calculator than you, but for me, the
          maxInteger comes out to just under 25 days... not hours.
          put the maxInteger
          -- 2147483647
          theSeconds=the maxinteger/1000
          put theSeconds
          -- 2147483
          theMinutes=theSeconds/60
          put theMinutes
          -- 35791
          theHours=theMinutes/60
          put theHours
          -- 596
          theDays=theHours/24
          put theDays
          -- 24
          All of which is neither here nor there. You can try to make the
          milliseconds a float, but I doubt that would help. I don't know what
          Director would do if the milliseconds goes beyond that. Often when a
          number that should be an integer goes beyond the maxInteger, it turns
          into -2147483647 (negative maxinteger) and stays that way. I have never
          had trouble using the milliseconds, and I have used it on some long term
          kiosks that stayed up for as long as Windows would stay up without
          crashing. If you are having trouble with it, you may want to make your
          calculations based on a variable that is set by a timer or timeout
          object so it can be reset if it gets too high.
          • 2. Re: _system.milliseconds is negative?
            Level 7
            -- the issue ---
            Assuming you are on windows (should be the same on mac, but not so familiar
            with mac internals) the milliseconds returns the result of the windows API
            GetTickCount() function.
            This function returns an unsigned long (32 bit) value. The range of such a
            value is 0-4294967295 (4GB). So, after about 49 days, this value will reset
            to 0, and continue from there.
            Furthermore, when converting the value to a signed long -as director is
            doing- you get a negative value after half that time (25 days, not hours).
            You can convert the negative value to a positive float by using:
            if (val < 0) then val=float(the maxinteger)*2+2 + val
            put the maxinteger
            -- 2147483647
            put float(the maxinteger)*2+2 + ( the maxinteger +1 )
            -- 2147483648.0000
            put float(the maxinteger)*2+2 + (-1)
            -- 4294967295.0000
            You can also workaround the timer reset issue, by comparing the last value
            to a previous one.. However:
            -- solution --
            I had created a small Xtra a while ago, that returned high precission
            (sub-milliseconds accuracy) time as a float number.
            I believe this should solve your problem. So, if you are on windows, mail me
            to send it to you. info at (reverse >) gr. rtr.
            increasingly negative up to -1, 0, 1, 2...
            "Applied CD" <webforumsuser@macromedia.com> wrote in message
            news:g4bn7t$mkq$1@forums.macromedia.com...
            > I?ve got a giant array of audio sample data (glFreqData[sampleTime]),
            > about
            > 1700 samples, 16 frequency bins per sample. I?m using the following code
            > to
            > convert system time to a sample time index however on some machines I?m
            > getting
            > exceeding
            > maxInteger but I don?t see any documentation on what to expect when that
            > just
            > is
            • 3. Re: _system.milliseconds is negative?
              Level 7
              Mike Blaustein wrote:
              > Often when a
              > into -2147483647 (negative maxinteger)...
              Off-by-one error!
              put the maxinteger+1
              -- -2147483648
              > ...and stays that way.
              Huh?
              OP: there's a technote on the issue:
              http://www.adobe.com/go/tn_16259
              Andrew
              • 4. Re: _system.milliseconds is negative?
                Applied CD Level 1
                Thanks all. That tech note should really be part of the documentation. Sorry about the math, yeah it’s 25 days, not hours. For my own purposes I only need to count out regular beats at 1/10 second intervals until my data set runs out, then start over.
                The following should work for me. I know there’s a chance of repeated beats transitioning from – to + and again at + to – however this small glitch occurs at the millisecond level, far below the resolution of my data set. Also, I know the abs() shouldn’t be necessary but mySample is used as a list index so now I’m being paranoid and want to be sure it’s never negative.
