• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Gap between adjacent gradient mesh points in circular object and intersection issues
New Here ,
Aug 17, 2017 Aug 17, 2017
HI everyone!
I’m not good at Adobe Illustrator and knew about gradient mesh (how I can use them) only a few days ago. Now I would like to have closed metal ring, which was created using gradient mesh. I’ve done it using this technique https://design.tutsplus.com/tutorials/quick-tip-how-to-tame-the-gradient-mesh--vector-3697
But, unfortunately,
1.  When I’m trying to bring points closer to each other using maximum of zooming a gap between two adjecent points of ring appears https://d.pr/i/bfKstG (here blue rectangle is a background)
2. When I’m trying to join endpoints of ring nothing has happening.
3. When I’m trying to intersect points of gradient mesh part of this mesh disappearing. Like on this screenshot https://d.pr/i/Pqgdxi
So my question is how I can make this ring “closed” or maybe without a gap between points?
The original file is here
Thank you very much!
Views
252
Translate
Translate
Report
Report
Community guidelines
community guidelines
Community Expert , Aug 17, 2017 Aug 17, 2017
Can you try and View > Preview on CPU?
Most likely it's only a preview issue.
Votes
Translate
Translate
Adobe
Community Expert ,
Votes
Translate
Translate
Report
Report
New Here ,
Thank you very much! That was helpful
Votes
Translate
Translate
Report
Report
Community Expert ,
LATEST
You're welcome.
In case you get issues when exporting to pixel files, you might actually need to split the mesh into two parts. Those could then slightly overlap without causing the issues you currently see when overlapping parts of a single mesh.
Votes
Translate
Translate
Report
Report
