When I'm running two monitors on MacOS, the Creative Cloud menu icon at the top of the non-focused monitor doesn't dim like every other element of the menu. It sticks out like a sore thumb.
This may be a slightly unusual circumstance, though I imagine many CC users would have systems that would run into it, and at least a few of them would be bugged by a visual quirk like this.
Is this just me? Is it deliberate? If it's the oversight that I think it is, I hope Adobe's developers can address it in a (near-)future update of the CC component that renders the menu bar icon.
-Jonathan
Well, in that case, I would suggest you to Contact Customer Care, they will be able to share your screen and assist you remotely.
Hi Jonathan,
As you mentioned that Creative Cloud does not dim, try closing the Creative Cloud processed from Activity monitor and check if that helps.
You may also see: Close conflicting processes or applications interfering with Adobe Creative Cloud app update or ins...
Feel free to update the thread for any other questions.
Kanika
That did not help. I'd already rebooted before even asking the question, and killing and restarting the process didn't make a difference.
Jonathan, try turning off the sync and check if that helps.
Please see the steps:
Hope this helps!
No improvement. I also can't think of a reason that it would have helped.
I tried that and ended up directed to this forum. I'll go back through my CC team manager to see if they can file it as an issue.
I have just run into this annoying issue.....did you ever find a fix?
Hi Michael,
Are you trying to contact support? Could you please elaborate more on the issue you are facing?
Kanika
Kanika, I have exactly the issue described by Jonathan in the first post of this thread.
I was hoping he had found a fix since his last post.
I just bought a second monitor and have same problem. Still no fix?
btw the other undimmed icons are 1Password (they just told me they'll look into it) and Siri.
