• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
custom toolbar images missing
New Here ,
Aug 17, 2017 Aug 17, 2017
I have custom toolbars for FrameMaker 2017 - originally created for FrameMaker 8 and FrameMaker 2015. I've updated the image pathway in the toolbar files (**.xml) to no avail.
This is how the toolbar is appearing. Each button is definitely working, but the images are not there.
This is the code line from the XML file - the current pathway for the image is desperation. Still didn't work.
Any help would be appreciated.
Views
603
Translate
Translate
Report
Report
Community guidelines
community guidelines
Adobe Employee ,
Aug 18, 2017 Aug 18, 2017
in FM 2017 this changed.
Have you checked this section in the FM 2017 online Help: Adobe FrameMaker (2017 release)?
Also, this blog post: 2017 Release of FrameMaker (Update 2) (see the 5th bullet point in section "User Interface").
In FM 2017 you can create your own toolbars and assign your own icons to the toolbar’s buttons. We have added a maker.ini entry (ToolbarCustomImageDir) where you can specify a custom folder for your icons.
To provide a full set of icons, you will need a total of 6 icons. Depending on the Windows Display Scaling of the user, FrameMaker 2017 automatically scales its UI in three different sizes (100%, 150% and 200%). For each of these three states you need two icons: One for the activated and one for the deactivated state of the icon. So, in total six icons. PNG is the icon required icon graphic format.
Votes
Translate
Translate
Report
Report
New Here ,
Aug 22, 2017 Aug 22, 2017
No luck.
Icons created. Placed where indicated. Added ToolbarCostomImageDir and nothing.
Votes
Translate
Translate
Report
Report
Adobe Employee ,
You do have Update 2 for FrameMaker 2017, do you?
Votes
Translate
Translate
Report
Report
New Here ,
Aug 23, 2017 Aug 23, 2017
I have assumed so. Version showing as: 14.0.2.425
Votes
Translate
Translate
Report
Report
New Here ,
Aug 25, 2017 Aug 25, 2017
LATEST
Just wanted to say that the problem has been resolved.
  • Adobe's naming for additional files is what I ended up using. I had to create two states for each button as well as three sizes for each button.
  • Finally, the location for the image files is not correct in the "Help Manual" - references '13' when it should be '14' for Frame 2017.
Votes
Translate
Translate
Report
Report
