When I use the Adobe Export PDF app, I can select multiple pdf files and convert them in batch mode to excel files. it seems to confer each separate pdf to it's own excel file. I can live with that but would prefer to have them all converted to one excel file (with a tab for each pdf). Is there a way to do this?
Not possible.
Not possible.
You can merge the data in all of them to a single Excel spreadsheet, but not as independent sheets.
I have not been able to merge them into on sheet. I can select all the PDF's and convert, but it creates a separate sheet for each pdf. Did you find a way to put them all in one excel file?
Are you talking about actually converting the files to Excel, or about exporting the data from them? If the former then I misunderstood you, and it's not possible.
