1 Reply Latest reply on Jun 25, 2008 4:25 PM by Garyl Woolworth
    Flex Error message
    Gene Godsey
      I used the ColdFusion Wizard to connect and use flash remoting to a data table.
      I get this error.
      (mx.rpc::Fault)#0
      errorID = 0
      faultCode = "Server.Processing"
      faultDetail = ""
      faultString = "Unable to invoke CFC - Invalid data GAR03 for CFSQLTYPE CF_SQL_INTEGER."
      message = "faultCode:Server.Processing faultString:'Unable to invoke CFC - Invalid data GAR03 for CFSQLTYPE CF_SQL_INTEGER.' faultDetail:''"
      name = "Error"
      rootCause = (null)
      Any Ideas????
        • 1. Re: Flex Error message
          Garyl Woolworth Level 1
          My best guess is that the data being sent is in the form of a string and since you are using cfqueryparam and setting a type of integer it's throwing an error because "GAR03" is not an integer. If the data you want to insert is really "GAR03" then replace the cf_sql_type with the following. cfsqltype="cf_sql_varchar"
