2 Replies Latest reply on Jul 1, 2008 1:20 AM by K_G_
    could not write file .project
    K_G_
      Hi, i need help.
      I have a lot of components in a workspace but when i want to make a reference into them flexbuilder send me next error-messaje:
      could not write file d:\......\.project
      i have seen and this file is not an "only read" file, and i have permission to write it...
      I have also copy this proyect, and test it in other computer...
      Could you help me?
      Thanks in advance
        • 1. Re: could not write file .project
          Gregory Lafrance Level 6
          Is this an AIR app? Could you provide a more detailed description of the scenario and what the problem is, including simplified sample code.
          • 2. Re: could not write file .project
            K_G_ Level 1
            I have a flex 3 workspace with a lot of components (libraries). I need to import one of this components(library 1) from another one(library 2), to register a cairmgorn event in library 2´s controller.
            When i click with the rigtht button over library 2, and select in the menu, properties option, then select proyect references and then select library 1, when i press ok, flex send me the error, "could not write file /library2.../.project"
            because of that error when i restart my flexbuilder, no any reference is in my library 2 component.
            Also, if i try to select propertys, flex library build path, and then library path tab, i add proyect and select library 1 component, flex let me select it, and press ok, but doesn't let me use hes propertys and components, like i not doing anything, and when i restart my flex builder, this library path has dissapear.
            Thanks in advance.
