Hello,
Could you guys help with this?
I need to create branched scenarios as per the requirement below. There are 3 types of roles in the system and based on what role someone selects, a specific set of information should display.
Slide 1 - Learner can choose one of the 3 roles shown via images / buttons (Role A, B, C)
If they select Role A, slides 2 - 9 should display.
If they select Role B, slides 10 - 14 should display plus slides 7-9.
If they select Role C, slides 15 - 20 should display plus slides 7-9 and 13-14.
Now, for Role B, is there a way to move to Slide 7 when they finish Slide 14. I do not want to duplicate slides 7-9 again and add them after Slide 14 for Role B. Same question with Role C too.
Please advise. Thanks in advance!
You can create custom navigation to handle this, don't use a default playbar nor navigation by TOC.
Some information is missing from your question:
Besides those general questions:
Hi Lilybiri. Thanks for the response. Here are some answers to your questions.
But scenario C says:
What is the sequence for this scenario? If 7-9 are always the last slides, I would consider moving those slides in the Filmstrip towards the end, will make your setup easier.
Problem will be for the backwards movement.
Within a scenario for all but first and last slide you can use a simple Next/Back button, would consider using a shape button timed for the rest of the project, which you hide on the first and the last slide of each scenario.
