12 Replies Latest reply on Aug 21, 2017 11:22 PM by Abambo
    Photoshop compresses all files in PSD format
    Leevz
      Hi! I need a help. Photoshop compresses all files in PSD format. Text and photos look very rasterized. Until today everything worked well. But after I save the picture, the quality is again good. Quality is bad only when I open a file in Photoshop. I already have reinstalled Photoshop, it doesnt help. Who knows what the problem is? Example in the attached screenshot1.png
        • 1. Re: Photoshop compresses all files in PSD format
          Stephen_A_Marsh Adobe Community Professional
          The posted example in PNG, not PSD.
          PSD uses a *lossless* compression, that does not affect image quality.
          I don’t believe that the problem is with Photoshop.
          What is the original document size in pixels, width and depth?
          What is the width and depth size in pixels that you are saving to?
          What file format are you saving to?
          How are you viewing the final images saved from Photoshop?
          Please add any other information that may be of help to those interested in trying to help you.
          • 2. Re: Photoshop compresses all files in PSD format
            Abambo Adobe Community Professional
            looks like bad antialiasing. Do you use GPU acceleration? Look into this: Troubleshoot Photoshop graphics processor (GPU) and graphics driver issues . Switch GPU acceleration of for a quick test.
            Also: save your file as JPEG (good quality) and look at the JPEG using your OS tools, not Photoshop. Is the picture Ok?
            I do not think that it is a Photoshop issue. I suspect a problem with your graphics card or a wrong resolution settings.
            • 3. Re: Photoshop compresses all files in PSD format
              Trevor.Dennis Adobe Community Professional (Moderator)
              Good advice so far, but I wonder if it is a Cache levels issue?  That would give the noisy image affect, but I don't know if that is just a display issue and that  the image would save OK.
              • 4. Re: Photoshop compresses all files in PSD format
                Trevor may be onto something… If this image is just a screenshot, ensure that you are viewing the file in Photoshop at 100% zoom (1:1).
                • 5. Re: Photoshop compresses all files in PSD format
                  Leevz Level 1
                  1) I know this is not PSD, but its a SCREENSHOT as the photoshop opens psd;
                  2) It's not about the document, Photshop compresses PSD files with any sizes. But if you're interested in the size of the entire template it is equal to 1920x10 000 pixels. Sizes of screenshot are 1421x904;
                  3) To save photos, I use PNG, but it does not matter, any format that I save becomes normal (not compressed). PSD files look like compressed only in Photshop;
                  4) I view the final photos through a standard Windows 10 application (I dont know name, may be Windows 10 Photos?);
                  5) Photoshop compresses only PSD files, with JPG, PNG and so on everything is normal. But if I try to create a new text in Photoshop, it again looks compressed. After I save and open outside of Photoshop everything is normal again
                  • 6. Re: Photoshop compresses all files in PSD format
                    Leevz Level 1
                    PSD files look compressed only in Photoshop. I had the GPU turned off. But after your comment, I turned it on and PSD files are again normally displayed. Not perfect of course, but much better. First attached screenshot - with the GPU turned off, second - with the GPU turned on. (These are screenshots of how Photoshop sees files)1.png2.png
                    • 7. Re: Photoshop compresses all files in PSD format
                      There are good reasons that I ask these questions, so thank you for the answers!
                      I don’t believe that this is helpful. Can you provide a dropbox or other file sharing link to the PSD. As this is a screenshot, how do we know that the viewing magnification is not compromising the integrity of the display? Is the screenshot at 100% zoom level, or some odd size zoom? What happens if you do zoom into 100%?
                      Ah, so it would appear that this is not 100% or 1:1, that some sort of onscreen display resize has taken place.
                      Duplicate your original file, then resize the duplicate using bicubic interpolation down to 1421x904px, you should see better quality. Photoshop screen redraw only uses a “quick and dirty” resize algorithm, unlike a proper resize/resample using a method such as bicbic.
                      Using the term “compressed” is not helping here, there are both lossy (visually damaging) and lossless (visually non damaging) and PSD format uses lossless compression, which is not the issue here.
                      OK, but what about when viewing the PSD files at 100% magnification?
                      • 8. Re: Photoshop compresses all files in PSD format
                        At what display magnification are these screenshots taken at?
                        • 9. Re: Photoshop compresses all files in PSD format
                          You do not see that information on your pictures.
                          You need to look here:
                          • 10. Re: Photoshop compresses all files in PSD format
                            Leevz Level 1
                            118% magnification. It's not enough for so compressed a text. You can download the PSD template from here - https://freebiesbug.com/psd-freebies/mogo-free-one-page-psd-template/  I already redownloaded the template, the problem is not in it
                            • 11. Re: Photoshop compresses all files in PSD format
                              Again, PSD lossless compression has nothing to do with this.
                              118% magnification.
                              I don’t understand how a 1920px wide original that has a screenshot generated at 1421px wide ends up having a magnification value of 118%?
                              The GPU OFF vs. GPU ON screenshots are not at the same magnification, here we can see that the elements are different sizes:
                              I’ll download the PSD and try to see what is going on…
                              • 12. Re: Photoshop compresses all files in PSD format
                                118% magnification on smaller images may create your effect. Important are magnification levels of 100% (no magnification) and 200% or 400% for appreciating JPEG compression artefacts an precision works.
