8 Replies Latest reply on Aug 22, 2017 2:54 AM by SuperMerlin
    Placing layer in exact position related to canvas.
    andyf65867865 Level 1
      Could you make a sample JavaScript code how to position a layer in exact position related to the canvas (whole image)?
      For example, there is an image 600x600px dimensions. This image contains a 'Layer 1' which is 100x200px.
      We need to place the 'Layer 1' in the coordinates of x=300px and y=300px related to the top left corner of the canvas.
        • 1. Re: Placing layer in exact position related to canvas.
          SuperMerlin Level 5
          #target photoshop;
          if(documents.length) main();
          function main(){
          var X = 300; //Top left
          var Y = 300; //Top left
          try{
          var doc = app.activeDocument;
          app.displayDialogs = DialogModes.NO;
          var strtRulerUnits = app.preferences.rulerUnits;
          var strtTypeUnits = app.preferences.typeUnits;
          app.preferences.rulerUnits = Units.PIXELS;
          app.preferences.typeUnits = TypeUnits.PIXELS;
          activeDocument.activeLayer = activeDocument.artLayers.getByName("Layer 1");
          var LB = activeDocument.activeLayer.bounds;
          activeDocument.activeLayer.translate(X-LB[0].value,Y-LB[1].value);
          }catch(e){alert(e + "\nLine number = " + e.line);}
          finally{
          app.preferences.rulerUnits = strtRulerUnits;
          app.preferences.typeUnits = strtTypeUnits;
          2 people found this helpful
          • 2. Re: Placing layer in exact position related to canvas.
            geppettol66959005 Level 3
            A trivial question
            How do i get the x  and y coordinates.
            • 3. Re: Placing layer in exact position related to canvas.
              Here is a script I posted sever times.  The script places a watermark/logo image file into the active document resizes the Watermark relative to the document's height then positions the water mark in one of the bottom corners with some margin size.  The first few variables in the script set most of the size and positioning options.  Its not hard to read the code.
              #target photoshop;
              app.bringToFront();
              var logoFile = "~/Desktop/JJMack.png"; // Watermark file should be large for resize down works better than up
              var LogoSize = 10;                     // percent of document height to resize Watermark to
              var LogoMargin = 1;                    // percent of Document height the Watermark should have as a margin
              var BottomLetf = false;                // false = Bottom Right true Bottom Left
              placeWatermark(logoFile, LogoSize, LogoMargin);  // Place Watermark into the bottom of the document
              function placeWatermark(Image,Size,Margin){
                 if(!documents.length) return;                       // if no document return
                 try{
                    var doc = app.activeDocument;                    // set Doc object to active document
                    app.displayDialogs = DialogModes.NO;             // Dialog off
                    var strtRulerUnits = app.preferences.rulerUnits; // Save Users ruler units
                    var strtTypeUnits = app.preferences.typeUnits;   // Save Users Type units
                    app.preferences.rulerUnits = Units.PIXELS;       // work with pixels
                    app.preferences.typeUnits = TypeUnits.PIXELS;    // work with pixels
                    var fileObj = new File(Image);                   // the passed file
                    if(!fileObj.exists){                             // If file does not exits tell user
                       alert(fileObj.name  + " does not exist!");
                       return;
                    placeFile(fileObj);                              // Place in file the Watermark png file
                    activeDocument.activeLayer.resize(100 ,100,AnchorPosition.MIDDLECENTER); // Insure Place did not scale layer
                    var SB = activeDocument.activeLayer.bounds;      // get layers bounds
                    var layerHeight = SB[3] - SB[1];                 // get layers height
                    var resizePercent = (100/layerHeight)*(Size/100*doc.height.value); // Percent to resize by
                    activeDocument.activeLayer.resize(resizePercent ,resizePercent,AnchorPosition.MIDDLECENTER);  // Resize width and height by percentage
                    SB = activeDocument.activeLayer.bounds;          // get resized layers bounds
                    activeDocument.activeLayer.translate(-SB[0].value,-SB[1].value); // Move resized layer to top left canvas corner
                    var LayerWidth = (SB[2].value - SB[0].value);    // get resized layers width
                    var LayerHeight = (SB[3].value - SB[1].value);   // get resized layers height
                    marginSize = Margin/100*doc.height.value;        // Margin size
                    // move resized watermark into the document lower right corner with some margin or lower left
                    if  ( BottomLetf) {activeDocument.activeLayer.translate(marginSize,( doc.height.value -marginSize - LayerHeight));}
                    else {activeDocument.activeLayer.translate((doc.width.value -marginSize - LayerWidth),( doc.height.value -marginSize - LayerHeight));}
                 catch(e) { alert(e + ': on line ' + e.line); }       // inform user of error
                 finally{
                    app.preferences.rulerUnits = strtRulerUnits;      // Restore user ruler units
                    app.preferences.typeUnits = strtTypeUnits;        // Restore user type units
              function placeFile(placeFile) {
                  var desc21 = new ActionDescriptor();
                  desc21.putPath( charIDToTypeID('null'), new File(placeFile) );
                  desc21.putEnumerated( charIDToTypeID('FTcs'), charIDToTypeID('QCSt'), charIDToTypeID('Qcsa') );
                  var desc22 = new ActionDescriptor();
                  desc22.putUnitDouble( charIDToTypeID('Hrzn'), charIDToTypeID('#Pxl'), 0.000000 );
                  desc22.putUnitDouble( charIDToTypeID('Vrtc'), charIDToTypeID('#Pxl'), 0.000000 );
                  desc21.putObject( charIDToTypeID('Ofst'), charIDToTypeID('Ofst'), desc22 );
                  executeAction( charIDToTypeID('Plc '), desc21, DialogModes.NO );
              • 4. Re: Placing layer in exact position related to canvas.
                SuperMerlin Level 5
                To get the active layer details.
                #target photoshop;
                alert("Left = " +LB[0].value + " Top = " + LB[1].value + " Right = " + LB[2].value + " Bottom = " + LB[3].value);
                • 5. Re: Placing layer in exact position related to canvas.
                  I noticed that if the document and another dimension the square is positioned at another point
                  Can not you use rulers in percent?
                  • 7. Re: Placing layer in exact position related to canvas.
                    SuperMerlin
                    I can not get it to work
                    You could set an example
                    Thank you
                    • 8. Re: Placing layer in exact position related to canvas.
                      SuperMerlin Level 5
                      That example requires you have an open document with a layer named "Layer 1"
                      This example create a document and a layer, fills a section of that layer and moves it so that the top left is positioned at X = 300 Y = 300
                      #target photoshop;
                      main();
                      function main(){
                      try{
                          // X & Y is where the the layer is to be moved to.
                      //create a new document
                      var doc = app.documents.add(1800, 1200, 300, null, NewDocumentMode.RGB, DocumentFill.WHITE);
                      //create a new layer
                      doc.artLayers.add();
                      //make a selection
                      doc.selection.select([[600,400],[800,400],[800,800],[600,800]], SelectionType.REPLACE, 0, false);
                      //create a colour
                      var Red = new SolidColor;
                      Red.rgb.hexValue = "ff0000";
                      //set foreground colour to red
                      app.foregroundColor = Red;
                      //fill selection
                      doc.selection.fill(app.foregroundColor);
                      //deselect
                      doc.selection.deselect();
                      // get bounds of active layer
                      //move layer to X,Y as defined above
                      //get bounds to display position of the layer
                      //display X and Y of top left corner of layer
                      alert("Top X is " + LB[0].value + "\nTop Y is " +LB[1].value);
                      finally{
