2 Replies Latest reply on Aug 21, 2017 9:43 PM by pdfUser1
    fonts issue
    pdfUser1 Level 1
      Is there a javascript that can access "use local fonts" in the Preference window? I want the user to uncheck that option so all the fonts I used in the creation of the form will be used. At this point I just don't want any pop out windows saying, "Helevetica Bold cannot be used" (something like that). I'm trying to figure this out. I thought, all the fonts I selected to use in the form creation would be available. The only thing I can think of is to uncheck the "use local font" option. Any other suggestions out there?
        • 1. Re: fonts issue
          Joel_Geraci Adobe Community Professional
          You can't... but "use local font" wouldn't help you in this case anyway.
          Because filling a form is considered "authoring" in that the entire font needs to be embedded for it to work correctly, only fonts with the right license can be embedded for form filling. Checking "use local font" will simply tell Acrobat/Reader that it is to use the local system font for fonts with the same name rather than extracting the embedded font. It has nothing to do with form authoring.
          • 2. Re: fonts issue
            pdfUser1 Level 1
            Thanks for getting back to me, Joel. I thought when you select a font to use it automatically gets embedded so the user will then see the document as it was created and not change the appearance. I tried to view my doc on a different computer and so I get the message I mentioned in my previous post ("Helevetica Bold cannot be used"). So my question is, what do I have to do to get the fonts I used to embed?
