2 Replies Latest reply on Jun 30, 2008 3:46 AM by Karl_Sigiscar_1971
    ArrayCollection
    GeorgeWS Level 1
      I have an arraycollection, Called myPrices. I just want to display the Product number from the arraycollection. I dont know the syntax.
      This gets me [Object.object]
      <mx:Text text="{myPrices}"/>
      If I make a datagrid and make one column be PWDL01 I get the record I want.
      How can I show the PWDL01 in the text?
      There is only one record in the array but a bunch of fields
      George
        • 1. Re: ArrayCollection
          LinkMc
          hi George,
          you are getting object object, because it is returning an object.
          to get a specific item from the object within the datagrid
          mydata.selectedItem.mydatacolumn - id of my datagrid is mydata and the column information I want to display is mydataColumn.
          Now you can say this too.
          mydata.getItemAt(0).mydatacolumn - this will return the item in the 0 position of the data grid. remember that arrays are 0 or zero based, meaning they start at 0 instead of one.
          now if I wanted to get this from my array Collection I would call:
          myarrayCollection.getItemAt(0).mydatacolumn
          • 2. Re: ArrayCollection
            Karl_Sigiscar_1971 Level 3
            If you use DTOs instead of Objects, cast the object you get from your array collection so you can access properties using autocompletion, e.g:
            (myPrices.getItemAt(0) as Product).PWDL01
            To get the PWDL01 in the text:
            <mx:Text text="{(myPrices.getItemAt(0) as Product).PWDL01}"/>
