I have tried literally everything I know how to do. I have Antares Autotune 7 and I pasted the VST in every folder I could think of (Steinberg, VSTPlugins, Audition>plugins>vst3, Audition>plugins>commons, antares folder etc.) and I'll scan, and it never appears. I tried checking the "rescan existing plugins" (or whatever its called) box to no avail. It works fine in Audacity, but it won't come up in Audition. Any ideas/fixes?
It is unlikely to work if it is a 32bit plugin as Au is 64bit
I think that fx needs to send timing info back and forth to Au and I don't think Au supports that
I don't know whether it will work or not, but there's definitely an uprade available for Autotune 7 64-bit, and at the very least, that's the version you'd need to run:
I cant get the upgrade, stuck with my antares auto tune 7
You can try jBridge to load your 32bit vsts
I checked, it seems to be 32 bit, any way to get around it?
