29 Replies Latest reply on Aug 24, 2017 1:30 AM by natrev
    Duplicate and fit
    geppettol66959005 Level 2
      I have this need
      I would duplicate the document in use
      Resize to 1920px
      Return the document to the original
      And adapt it to the original document size
      Without having too much loss of quality.
        • 1. Re: Duplicate and fit
          c.pfaffenbichler Level 9
          Could you please illustrate with screenshots?
          To me it seems you want to resize an image and then resize it to the original size again – what good would that be?
          • 2. Re: Duplicate and fit
            I hope you understand
            Duplicate image
            After duplicate image
            Resize to 1024px
            Once resized to bring on original
            Fit to image without losing too much quality
            • 3. Re: Duplicate and fit
              What do you mean by
              Do you want to upscale the downsampled copy?
              • 4. Re: Duplicate and fit
                I would like to adapt it this way
                Sorry if I do not speak English well and my tongue
                • 5. Re: Duplicate and fit
                  natrev Level 3
                  Hi
                  Try this code...
                  var strtRulerUnits = app.preferences.rulerUnits;
                  var strtTypeUnits = app.preferences.typeUnits;
                  app.preferences.rulerUnits = Units.PIXELS;
                  app.preferences.typeUnits = TypeUnits.PIXELS
                  cTID = function(s) {return app.charIDToTypeID(s);};
                  sTID = function(s) {return app.stringIDToTypeID(s);};
                  if(documents.length>0) main();
                  function  main(){
                      var docRef = app.activeDocument;
                      var docname=activeDocument.name;
                      var theCopy = docRef.duplicate("Dup",true);
                      app.activeDocument=theCopy;
                      c_Res=theCopy.resolution;
                      if(theCopy.height.value>theCopy.width.value){ theCopy.resizeImage(undefined,new UnitValue(1024,'Px'),c_Res, ResampleMethod.AUTOMATIC);}
                      else{theCopy.resizeImage(new UnitValue(1024,'Px'), undefined, c_Res, ResampleMethod.AUTOMATIC);}
                      var theLayer=theCopy.backgroundLayer.duplicate();
                      theLayer.duplicate (docRef, ElementPlacement.PLACEATBEGINNING);
                      theCopy.close(SaveOptions.DONOTSAVECHANGES);
                      app.activeDocument=docRef;
                      docRef.selection.selectAll();
                      align('AdCV');
                      align('AdCH');
                      docRef.selection.deselect();
                  // Align Layer
                  function align(method) {
                    var desc = new ActionDescriptor();
                    var ref = new ActionReference();
                    ref.putEnumerated( cTID( "Lyr " ), cTID( "Ordn" ), cTID( "Trgt" ) );
                    desc.putReference( cTID( "null" ), ref );
                    desc.putEnumerated( cTID( "Usng" ), cTID( "ADSt" ), cTID( method ) );
                    try{
                    executeAction( cTID( "Algn" ), desc, DialogModes.NO );
                    }catch(e){}
                  - yajiv
                  • 6. Re: Duplicate and fit
                    You mean align to the center?
                    if so why duplicate the image and resize instead of just the Layer?
                    • 7. Re: Duplicate and fit
                      Natrev is on the right track
                      Now I want to fit the original picture
                      • 8. Re: Duplicate and fit
                        Again: What do you mean?
                        If you posted meaningful screenshots you could save some typing …
                        The task (or what you have revealed of it so far) seems close to nonsensical to me – what is the purpose of the operation?
                        • 9. Re: Duplicate and fit
                          natrev Level 3
                          Hi
                          Now, Try this code..
                          function  main(){
                              var ImgW=docRef.width.value
                              var ImgH=docRef.height.value
                              align('AdCV');
                              align('AdCH');
                              var theLayer=docRef.activeLayer;
                              var LB = theLayer.bounds;
                              var lWidth = LB[2].value - LB[0].value;
                              var lHeight = LB[3].value - LB[1].value;
                              if(lWidth>lHeight){
                                  x=(ImgW/lWidth)*100;
                                  theLayer.resize(x,x,AnchorPosition.MIDDLECENTER);
                              else{
                                  var x=(ImgH/lHeight)*100;
                          // Align Layer
                            try{
                            }catch(e){}
                          -yajiv
                          • 10. Re: Duplicate and fit
                            natrev Level 3
                            Hi
                            Try this code also..
                            function  main(){
                                docRef.flatten();
                                c_Res=docRef.resolution;
                                var theLayer=docRef.backgroundLayer.duplicate();
                                if(lWidth>lHeight){
                                    x=(1024/lWidth)*100;
                                else{
                                    var x=(1024/lHeight)*100;
                                var theLayer=docRef.layers[0];
                                docRef.activeLayer=theLayer;
                                if(lWidth>lHeight){
                                    x=(ImgW/1024)*100;
                                else{
                                    var x=(ImgH/1024)*100;
                            -yajiv
                            • 11. Re: Duplicate and fit
                              It’s nice of you to write the code but what do you think the use/benefit/aim of the procedure is?
                              • 12. Re: Duplicate and fit
                                natrev Level 3
                                Hi Chris,
                                I understood what is your saying. However what I understood, the Image size going to be reduced with same pixel dimension. That's the reason I written code.
                                -yajiv
                                • 13. Re: Duplicate and fit
                                  But would certain Filters not achieve a very similar result (with regard to damage and savings)?
                                  • 14. Re: Duplicate and fit
                                    geppettol66959005  wrote
                                    I have this need
                                    Resize to 1920px
                                    Because you wrote 1920 it leads me to believes you want to display the resized image on a  1920x1080 display.  If an  image does not have a 16:9 aspect ratio and you resize it to fit within 1920x1080 pixels there will be borders.   Photoshop has a Plug-in named Fit Image that you can record in an action and batch to resize image to fit within 1920x1080 pixels.  Menu File >Automate>Fit Image record 1920width 1080 height.  Or you can use menu Scripts>Image Processor and fill in its dialog and have it resize images to fit within 1920x1080.  I will use Fit Image to do the resize.
                                    If you do not  want boarders on images that do not have a 16:9 aspect Ratio you could try using Photoshop Content Aware Resize.   The will be distortion. Photoshop will try to preserve object it recognizes perspective,  However you should not expect square  and portrait aspect ration image to resize well into a wide 16:9 landscape Aspect ratio image.  Cropping to 16:9 also will not  work well with square and portrait images to much image content will be cropped off the resulting composition will not be acceptable.
                                    • 15. Re: Duplicate and fit
                                      Davide_Barranca Adobe Community Professional
                                      can you provide a bit of background on the rationale behind your request, please?
                                      Basically, you're downsampling an image ("Fit to Image" to a smaller size), and then upsampling it ("Fit to Image" back to the original size). Which, inherently, is going to cause a loss of quality – how much, it depends on the original image's size.
                                      In other words, what you're asking for is a "quality loss machine", but at the same time "Without having too much loss of quality" – that's the puzzling part.
                                      Davide
                                      • 16. Re: Duplicate and fit
                                        You are right in asking why this is my request
                                        I need to duplicate the document and resize it
                                        To perform operations on level masks
                                        Which then bring it on the original document and fit it into the image
                                        I think in this passage I do not have much loss of quality.
                                        Thanks for your help
                                        • 17. Re: Duplicate and fit
                                          Why would those not work on the fullers image?
                                          • 18. Re: Duplicate and fit
                                            I tried to do it on the original image
                                            But you lose too much time
                                            Then I tried it with resized image and much faster
                                            So the work I have in mind and this
                                            Duplicate in a new document
                                            reduce
                                            To do the work on the masks
                                            Bring the document to the original
                                            Fit resized photos to the original.
                                            • 19. Re: Duplicate and fit
                                              From a quality point of view what you are proposing to do seems like a bad idea.
                                              What exactly do you mean by »perform operations on level masks«?
                                              Why does it take so long, what are the original fullres images’ usual pixel dimensions and bit depths?
                                              • 20. Re: Duplicate and fit
                                                The dimensions in px 7360 × 4912 and even bigger bit16
                                                What exactly do you mean by "performing layer masks"?
                                                I mean blur on masks in various rays.
                                                • 21. Re: Duplicate and fit
                                                  Then why do you not transfer and upsample the Layer Masks instead of degrading the composite image content?
                                                  • 22. Re: Duplicate and fit
                                                    Yes it seems what they need to do is scale the layer mask they developed up in size to fit the original image. The results should be good for they seem to want to create a blurred mask in the first place. An Upsize mask should not hurt the masking quality too much. Going from 1k back to 8K is a big change in the number of pixels like 8x
                                                    • 23. Re: Duplicate and fit
                                                      natrev
                                                      Your scripts are fine
                                                      But there is a misunderstanding
                                                      It should not duplicate the image
                                                      But must duplicate the document
                                                      • 24. Re: Duplicate and fit
                                                        Have no Idea of what you would the want to mask in duplicated document resized 1920
                                                        #target photoshop;
                                                        app.bringToFront();
                                                        if (documents.length)  app.activeDocument.suspendHistory('ResizDupe1920','main()');
                                                        //                            main function                                  //
                                                        function main() {
                                                           var strtRulerUnits = app.preferences.rulerUnits; // Save Users ruler units
                                                           app.preferences.rulerUnits = Units.PIXELS;       // work with pixels
                                                           activeDocument.duplicate();                      // Duplicate Document
                                                           activeDocument.resizeImage(1920, null, null, ResampleMethod.BICUBICSMOOTHER);
                                                           app.preferences.rulerUnits = strtRulerUnits;     // Restore user ruler units
                                                        • 25. Re: Duplicate and fit
                                                          JJMack
                                                          Thank you
                                                          The first step has been made
                                                          Now it would serve another small code it should
                                                          Bring the processed document to the source document to fit it
                                                          All original image
                                                          • 26. Re: Duplicate and fit
                                                            Why what would that do for you.  You wrote about masking the 1920 document for faster performance for Photoshop is dealing with 1/8 the number of pixels the original  document has.  That you want to create a blurred mask using various blur tools.  I think you need to create that mask in the second 1920 document. Then once created you need copy that mask into the original document. Then Scale the copied mask  for the original document size.
                                                            • 27. Re: Duplicate and fit
                                                              natrev Level 3
                                                              Hi
                                                              Do you check my code? ( 9th reply of this thread )
                                                              I have posted two code one for Duplicate the image and another one for duplicate the layer.
                                                              -yajiv
                                                              • 28. Re: Duplicate and fit
        natrev
        Now I've seen it
        Thanks to everyone for help
        • 29. Re: Duplicate and fit
        natrev Level 3
        Hi geppettol66959005,
        Please mark as correct answer if the answer is fulfil your requirement.
        -yajiv
