• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
How to make a brush where a create a brush where there is a outer line in white?
New Here ,
Aug 22, 2017 Aug 22, 2017
Hi
It wanted to start with printing some illustrations, but my printer is kind of bad, and so the intersected thin lines in some illustrations would appear as blob.
This can be solved with a brush where there is a white outline, so no line is truly intersected.
How can I do this, without drawing white lines on the intersection or raising the intersections a bit?
Is there any solid brush with a white outline, if not is it possible to do one?
Cheers,
Raquel
Views
663
Translate
Translate
Report
Report
Community guidelines
community guidelines
Community Expert , Oct 06, 2017 Oct 06, 2017
You can create a white thicker stroke  in the Appearance panel below the black stroke.
Create a Graphic Style and apply it to the strokes.
Votes
Translate
Translate
Adobe
LEGEND ,
What Adobe software are you using? You've inadvertently posted in the non-support, non-specific Forum Lounge. Let us know what you're using and a moderator can move your post to a software-specific, support forum.
Votes
Translate
Translate
Report
Report
New Here ,
Oct 05, 2017 Oct 05, 2017
Sorry, my bad
Illustrator CC 20.1.0
Votes
Translate
Translate
Report
Report
Community Expert ,
https://forums.adobe.com/people/raquel+sofiam24090220  wrote
Sorry, my bad
Should we move this to the Illustrator forum?
Votes
Translate
Translate
Report
Report
Community Expert ,
I’ve moved this to Illustrator.
Mike
Votes
Translate
Translate
Report
Report
LEGEND ,
This is not possible to do. However the good news is that you don't need it to be able to be done.
You should be able to just use whatever brush/tool you normally use. Convert it to a path and add a white stroke to it.
If that doesn't work, could you provide some screenshots of what you are trying to do?
Votes
Translate
Translate
Report
Report
New Here ,
Hi, thanks Brad
but, does that mean I have to add an white stroke manually to each intersections? because I have thousands!
Or maybe I am not understanding
Votes
Translate
Translate
Report
Report
Community Expert ,
Votes
Translate
Translate
Report
Report
New Here ,
then I guess I can save that as a personalise brush, right?
That might work
THANKS!
Votes
Translate
Translate
Report
Report
Community Expert ,
LATEST
Yes you can apply a Graphic style to existing paths or create a brush with the 2 strokes method.
Votes
Translate
Translate
Report
Report
