3 Replies Latest reply on Aug 27, 2017 6:17 AM by theangietaylor
    set scale in pixels in After Effects using Expressions
    TimSx Level 1
      Hey everyone!
      I often set the scale in pixels, using right click on a scale, hitting Edit, and then enter scale in Pixels. How can set the scale using expressions? And generally, how do you set the units using expressions?
      returning ["200px","200px"] results in error
      Thanks for help!
        • 1. Re: set scale in pixels in After Effects using Expressions
          AE has no "units". All values are intrinsic to the property stream and use its value ranges. Scale will always be in percent. You have to employ your own math to calculate the percentages. Simple 6th grade school stuff. Most commonly people use the linear() interpolator to that effect:
          linear(targetPixels,minPixels,maxPixels,minPercent,maxPercent)
          Simply fill in your numerical values, e.g. for a 1000 px solid:
          linear(200,0,1000,0,100)
          and it will return 20% for the scale.
          Mylenium
          • 2. Re: set scale in pixels in After Effects using Expressions
            Tomas Sinkunas Adobe Community Professional
            Another approach would be to use expression. Apply this expression to scale property and adjust targetSize parameter. It will set Scale to maintain your desired pixel size.
            var targetSize = [500, 500];
            var sr = thisLayer.sourceRectAtTime(time);
            [targetSize[0] / sr.width * 100, targetSize[1] / sr.height * 100];
            • 3. Re: set scale in pixels in After Effects using Expressions
              theangietaylor Adobe Community Professional
              Another tip that will help is that you can set up Expression control sliders to adjust the target size, width and height values, this will give you slider controls that are much easier to access than opening and editing fiddly expressions.
              Just create the sliders, rename them Scale X (Pixels) and Scale Y (Pixels).
              Then make this your expression;
              X =effect("Scale X (Pixels)")("Slider");
              Y = effect("Scale Y (Pixels)")("Slider")
              var targetSize = [X, Y];
              Hope this helps :-)
              Angie Taylor
