• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Export Layer Comps PNG No Color Profile
Community Beginner ,
Aug 22, 2017 Aug 22, 2017
I am using the layer comps to file export function but when I check include ICC profile, it strips the file.
I am specifically talking about the PNG export. When I save a layer comp Manually going through FILE > Save > PNG the file saves with color profile.
When I use Layer Comps to File I select
PNG - 8 or PNG - 24 neither work
Check Include ICC profile
Check Transparency
any idea how to change this? Would make exporting a lot easier than setting it up so that it goes through the save as menu everytime.
Views
674
Translate
Translate
Report
Report
Community guidelines
community guidelines
Adobe
LEGEND ,
Presumably the underlying script hasn't been properly updated or there is a bug. In the first case updating the script to include the dialog options would solve the issue.
Mylenium
Votes
Translate
Translate
Report
Report
Community Expert ,
Aug 23, 2017 Aug 23, 2017
Hello, what is the version of Photoshop that you are using? (to pinpoint which version might have a bug, if there is one)
Votes
Translate
Translate
Report
Report
photoshop CC
2015.1.2
20160113.r.355 x64
Votes
Translate
Translate
Report
Report
Community Expert ,
Hello, I wold first try and install PsCC 2017, to see if the bug has been squashed. You can select to keep the previous version installed.
Votes
Translate
Translate
Report
Report
Oct 12, 2017 Oct 12, 2017
LATEST
Actually here is what I figured out.
I have updated to CC17 but the reason it wasn't working was because you need to go into save for web, and change the setting for PNGs in there. Once that is set, then you can use the batch or, layer comp to pngs...and they will adhere to the correct settings. If you set the settings in only the command prompts they will be over written by the save for web settings...
seems silly but thats the fix
Votes
Translate
Translate
Report
Report
