1 Reply Latest reply on Aug 24, 2017 7:04 AM by c.pfaffenbichler
    Select brush from tool preset and then delete whole tool preset?
    silkwinter
      Hello,
      I am trying to create a script that will append a Tool Preset with brushes in the existing tools, select certain brush (in this case brush_one) and delete the rest loaded (appended). I know how to do it with separate brushes saved each in a Tool Preset, but the idea here is to save up HDD space. The other thing is saving space in the script by creating one step for each function of brushes.
      This is the code I am trying to achieve as a good result, but without success. Instead selecting brush_one, it selects brush_two and doesn't delete neither brush_one nor brush_two after selection:
      function brush_one() {
          function step1(enabled, withDialog) {
              if (enabled != undefined && !enabled) {
                  return;
              var dialogMode = withDialog ? DialogModes.ALL : DialogModes.NO;
              var desc1 = new ActionDescriptor();
              var ref1 = new ActionReference();
              var desc2 = new ActionDescriptor();
              var ref2 = new ActionReference();
              var desc3 = new ActionDescriptor();
              var ref3 = new ActionReference();
              var desc4 = new ActionDescriptor();
              var ref4 = new ActionReference();
              var desc5 = new ActionDescriptor();
              var ref5 = new ActionReference();
              ref1.putProperty(cTID("Prpr"), sTID("toolPreset"));
              ref1.putEnumerated(cTID("capp"), cTID("Ordn"), cTID("Trgt"));
              ref3.putEnumerated(sTID("toolPreset"), cTID("Ordn"), cTID("Trgt"));
              ref5.putEnumerated(sTID("toolPreset"), cTID('Ordn'), cTID('Trgt'));
              desc1.putReference(cTID("null"), ref1);
              desc1.putPath(cTID("T   "), new File(app.path + "/Presets/Tools/brushes.tpl"));
              desc3.putReference(cTID("null"), ref3);
              desc5.putReference(cTID('null'), ref5);
              ref2.putName(sTID("toolPreset"), "brush_one");
              ref4.putName(sTID("toolPreset"), "brush_two");
              desc1.putBoolean(cTID("Appe"), true);
              desc2.putReference(cTID("null"), ref2);
              desc4.putReference(cTID('null'), ref4);
              executeAction(cTID("setd"), desc1, dialogMode);
              executeAction(cTID("slct"), desc2, dialogMode);
              executeAction(cTID('slct'), desc4, dialogMode);
              executeAction(cTID("Dlt "), desc3, dialogMode);
              executeAction(cTID('Dlt '), desc5, dialogMode);
          step1();
      Please, will someone present me a solution to this problem, obviously I am a bad programmer.
      Thank you very much in advance,
      James
