Welcome to the updated Flash Runtime version 27 beta! We've been working on new features and fixing important bugs for Flash Player and we're looking forward to receiving feedback from our Flash Player community.
This beta release includes enhancements and bug fixes related to security, stability, performance, and device compatibility for Flash Player 27. For full details, please see our release notes.
Note:
Starting with Flash Player version 27, the user can select an audio device directly from the Flash Player Settings dialog through a newly added audio output tab. Here is the screenshot of the Audio Output user interface:
All the attached audio output devices of the system are listed in the drop-down menu. The user can select any of the available devices and once the settings dialog is closed, audio starts playing from the selected device. The selected device will be the current audio playback device for all Flash Player instances. For non-Pepper platforms, audio output selection setting is global among all browser tabs of the same process. When it is changed, all other tabs of the same process are affected.
Restriction in Chrome:
Audio Output device shares the same permissions with Microphone. So, if microphone permission is denied, audio output tab does not show the available audio devices. Also, “https:” must be used to enumerate Microphone and Audio Output devices after Chrome M60.
You can show the device names on Chrome (or Chromium based browsers such as Opera) in the following ways:
This feature is supported in Standalone and Plugin on Win/Mac/Linux except Chromebook.
With the release of Flash Player 27, developers can now select the audio output from ActionScript using the new ActionScript API - “AudioDeviceManager”. It is in sync with Flash Player's audio output settings. A UIA (User Invoked Action) restriction is applied to this API keeping in view user privacy concerns. The API can only be invoked by a user invoked action. If it is not invoked by user action, Flash Player throws a runtime error "IllegalOperationError" with error code 2176.
Use the AudioDeviceManager class to list down the audio output devices attached to a system using the property, deviceNames(). This returns an array of the attached devices. The index of the selected device from that array can then be retrieved using the selectedDeviceIndex() property. A new event introduced with this API, named AudioOutputChangeEvent.AUDIO_OUTPUT_CHANGE is dispatched to ActionScript listeners when the audio output changes. It is dispatched when the user selects a different audio device from Flash Player's setting UI (Audio Output), content setting (AudioDeviceManager.selectedDeviceIndex), or when adding/ removing the device from the system. The ActionScript client can check how the audio output change is triggered through “AudioOutputChangeEvent.reason” class.
The two reason codes are "AudioOutputChangeReason.USER_SELECTION" and "AudioOutputChangeReason.DEVICE_CHANGE".
Here is the general workflow of the API:
Sample Snippet:
var audio_device_manager:AudioDeviceManager = AudioDeviceManager.audioDeviceManager;
Select an audio output device
audio_device_manager.selectedDeviceIndex = desired_audio_output_index;
Monitor audio output change
function audioOutputChangeHandler(evt:AudioOutputChangeEvent):
void
if
(evt.reason == AudioOutputChangeReason.USER_SELECTION) {
do
something]
else
if
(evt.reason == AudioOutputChangeReason.DEVICE_CHANGE) {
do
something]
Known Issues
Authoring for Flash Player 27 and AIR 27
For system requirements of the current release of Flash Player in production, please visithttp://www.adobe.com/products/flashplayer/systemreqs/
To get the latest Beta build of Flash Player visit Adobe labs
