13 Replies Latest reply on Sep 20, 2017 4:53 AM by semihaltntas
    FAILURE: Build failed with an exception.
    mohammadm73101301
      Build Date: 2017-08-24 08:35:15 +0000
      PLUGIN OUTPUT
      Fetching plugin "cordova-plugin-device@~1.1.6" via npm
      Installing "cordova-plugin-device" at "1.1.6" for android
      Fetching plugin "cordova-plugin-console@~1.0.7" via npm
      Installing "cordova-plugin-console" at "1.0.7" for android
      Fetching plugin "cordova-plugin-splashscreen@~4.0.3" via npm
      Installing "cordova-plugin-splashscreen" at "4.0.3" for android
      Fetching plugin "cordova-plugin-statusbar@~2.2.3" via npm
      Installing "cordova-plugin-statusbar" at "2.2.3" for android
      Fetching plugin "cordova-plugin-dialogs@~1.3.3" via npm
      Installing "cordova-plugin-dialogs" at "1.3.3" for android
      Fetching plugin "cordova-plugin-inappbrowser@~1.7.1" via npm
      Installing "cordova-plugin-inappbrowser" at "1.7.1" for android
      Fetching plugin "cordova-plugin-geolocation@~2.4.3" via npm
      Installing "cordova-plugin-geolocation" at "2.4.3" for android
      Fetching plugin "cordova-plugin-compat@^1.0.0" via npm
      Installing "cordova-plugin-compat" at "1.1.0" for android
      Fetching plugin "ionic-plugin-keyboard@~2.2.1" via npm
      Installing "ionic-plugin-keyboard" at "2.2.1" for android
      Fetching plugin "cordova-plugin-barcodescanner@^0.7.2" via npm
      Installing "cordova-plugin-barcodescanner" at "0.7.2" for android
      Plugin dependency "cordova-plugin-compat@1.1.0" already fetched, using that version.
      Dependent plugin "cordova-plugin-compat" already installed on android.
      COMPILE OUTPUT
      Subproject Path: CordovaLib
      Configuration on demand is an incubating feature.
      Incremental java compilation is an incubating feature.
      [Fatal Error] :13:352: The value of the attribute "prefix="xmlns",localpart="android",rawname="xmlns:android"" is invalid. Prefixed namespace bindings may not be empty.
      * What went wrong:
      A problem occurred configuring root project 'project'.
      > Exception while parsing the supplied manifest file /project/AndroidManifest.xml
      * Try:
      Run with --stacktrace option to get the stack trace. Run with --info or --debug option to get more log output.
      BUILD FAILED
      Total time: 1.236 secs
      Error: /project/gradlew: Command failed with exit code 1 Error output:
      * What went wrong:
      * Try:
        at ChildProcess.whenDone (/project/cordova/node_modules/cordova-common/src/superspawn.js:169:23)
        at emitTwo (events.js:106:13)
        at ChildProcess.emit (events.js:191:7)
        at maybeClose (internal/child_process.js:877:16)
        at Process.ChildProcess._handle.onexit (internal/child_process.js:226:5)
        • 1. Re: FAILURE: Build failed with an exception.
          kerrishotts Adobe Employee
          Are you using PhoneGap Build?
          • 2. Re: FAILURE: Build failed with an exception.
            mohammadm73101301 Level 1
            the probem was in cordova-plugin-barcodescanner    i  forgot some config in config.xml but to find where is the problem it take long time
            thanks
            • 3. Re: FAILURE: Build failed with an exception.
              tanerochris
              HI, I'm having the same problem. How did you go about it ? I added
              <config-file target="AndroidManifest.xml" parent="/*" mode="merge">
                <uses-permission android:name="android.permission.CAMERA" />
                <uses-feature android:name="android.hardware.camera" />
                <uses-feature android:name="android.hardware.camera.autofocus" />
              </config-file>
              in config ,but it doesn't solve the problem. Thanks
              • 5. Re: FAILURE: Build failed with an exception.
                cordova barcode scanner need special configs in config.xml i did it and the problem solved
                • 6. Re: FAILURE: Build failed with an exception.
                  driverd71202277
                  Can you tell us how please!
                  • 7. Re: FAILURE: Build failed with an exception.
                    accounto56613983 Level 1
                    I use the following in config.xml and still get the problem. Strange that it was working on PGB until last week....
                    <plugin name="cordova-plugin-barcodescanner" spec="0.7.0">
                            <variable name="CAMERA_USAGE_DESCRIPTION" value="This app requires access to the camera to scan the App URL."/>
                    </plugin>
                    Please indicate what exact configs worked for you and on what cli of PGB?
                    • 8. Re: FAILURE: Build failed with an exception.
                      i think this is the first thing required
                      <plugin name="cordova-plugin-camera" spec="~2.1.1" />
                      second thing if not work  use this plugin
                      phonegap plugin add phonegap-plugin-barcodescanner
                      GitHub - phonegap/phonegap-plugin-barcodescanner: cross-platform BarcodeScanner for Cordova / PhoneGap
                      try this
                      i put every thing its same plugin
                      https://www.sitepoint.com/scanning-qr-code-cordova/
                      • 9. Re: FAILURE: Build failed with an exception.
                        if  not work paste your config.xml
                        • 10. Re: FAILURE: Build failed with an exception.
                          Thanks for the feedback mohammadm73101301, but changing my version from "0.7.0" to "0.7.1" solved the problem. Version "0.7.2" also gives the same problem.
                          • 11. Re: FAILURE: Build failed with an exception.
                            you are welcome  i am not expert in this its first application i faced problem in phonegap building then found all the plugin i used is the default plugin  in phonegap building but the barcodescanner is not
                            so going to find the solution i founded phonegap barcode scanner  why not use the plugin for phonegap i said in mined but follow steps this time i found some configs i forgot to do it in cordova plugin
                            its work with me
                            i did not change any thing in my code its same plugin but different  setting in config.xml (not sure)
                            • 12. Re: FAILURE: Build failed with an exception.
                              alexanderz22245786
                              This is how I've solved it.
                              1. Open plugins/cordova-plugin-barcode-scanner/plugin.xml and delete all records xmlns:android=""
                              2. Open  platforms/android/android.json and delete all xmlns:android=\"\"
                              3. Do the same in platforms/android/AndroidManifest.xml
                              xmlns:android can't be empty like error tells us:
                              • 13. Re: FAILURE: Build failed with an exception.
                                semihaltntas
                                Same Problem Help me Pls
                                <?xml version="1.0" encoding="UTF-8"?>
                                <widget xmlns = "http://www.w3.org/ns/widgets"
                                xmlns:gap = "http://phonegap.com/ns/1.0"
                                id = "com.kerzzpos.mobileplus"
                                version = "3.1.1">
                                <name>Kerzz POS Plus</name>
                                <description>
                                Demo App
                                </description>
                                <author href="http://www.kerzzpos.com"
                                email="demo@gmail.com">
                                Demo App
                                </author>
                                <content src="index.html" />
                                <access origin="*" />
                                   <plugin name="phonegap-plugin-barcodescanner" source="npm"/>
                                   <plugin name="cordova-plugin-statusbar" spec="~2.2.3" />
                                   <plugin name="cordova-plugin-device" spec="~1.1.4" source="npm" />
                                <preference name="SplashScreenDelay" value="6000" />
                                <preference name="StatusBarOverlaysWebView" value="false"/>
                                <preference name="StatusBarBackgroundColor" value="#000000"/>
                                <preference name="StatusBarStyle" value="blackopaque" />
                                <preference name="Fullscreen" value="true" />
                                <preference name="AndroidLaunchMode" value="singleInstance" />
                                      <preference name="DisallowOverscroll" value="true" />
                                <preference name="KeepRunning" value="true" />
                                <preference name="auto-hide-splash-screen" value="false"/>
                                    <preference name="phonegap-version"           value="cli-6.5.0" />
                                    <preference name="permissions"                value="none"/>
                                    <preference name="orientation"                value="portrait" />
                                    <preference name="target-device"              value="universal" />
                                    <preference name="fullscreen"                 value="true" />
                                    <preference name="webviewbounce"              value="true" />
                                    <preference name="prerendered-icon"           value="true" />
                                    <preference name="stay-in-webview"            value="true" />
                                    <preference name="detect-data-types"          value="true" />
                                    <preference name="exit-on-suspend"            value="false" />
                                    <preference name="show-splash-screen-spinner" value="true" />
                                    <preference name="auto-hide-splash-screen"    value="true" />
                                    <preference name="disable-cursor"             value="false" />
                                    <preference name="android-minSdkVersion"      value="12"/>
                                    <preference name="android-installLocation"    value="auto" />
                                    <!-- iPhone 6 / 6+ -->
                                    <icon src="images/appico/icon-60@3x.png" gap:platform="ios" width="180" height="180" />
                                    <!-- iPhone / iPod Touch  -->
                                    <icon src="images/appico/icon-60.png" gap:platform="ios" width="60" height="60" />
                                    <icon src="images/appico/icon-60@2x.png" gap:platform="ios" width="120" height="120" />
                                    <!-- iPad -->
                                    <icon src="images/appico/icon-76.png" gap:platform="ios" width="76" height="76" />
                                    <icon src="images/appico/icon-76@2x.png" gap:platform="ios" width="152" height="152" />
                                    <!-- Settings Icon -->
                                    <icon src="images/appico/icon-small.png" gap:platform="ios" width="29" height="29" />
                                    <icon src="images/appico/icon-small@2x.png" gap:platform="ios" width="58" height="58" />
                                    <!-- Spotlight Icon -->
                                    <icon src="images/appico/icon-40.png" gap:platform="ios" width="40" height="40" />
                                    <icon src="images/appico/icon-40@2x.png" gap:platform="ios" width="80" height="80" />
                                    <icon src="images/appico/icon.png" gap:platform="ios" width="57" height="57" />
                                    <icon src="images/appico/icon@2x.png" gap:platform="ios" width="114" height="114" />
                                    <!-- iPad -->
                                    <icon src="images/appico/icon-72.png" gap:platform="ios" width="72" height="72" />
                                    <icon src="images/appico/icon-72@2x.png" gap:platform="ios" width="144" height="144" />
                                    <!-- iPhone Spotlight and Settings Icon -->
                                    <!-- iPad Spotlight and Settings Icon -->
                                    <icon src="images/appico/icon-50.png" gap:platform="ios" width="50" height="50" />
                                    <icon src="images/appico/icon-50@2x.png" gap:platform="ios" width="100" height="100" />
                                    <icon src="images/appico/icon.png" />
                                    <icon src="images/appico/icon.png" gap:platform="android" gap:density="ldpi" />
                                    <icon src="images/appico/icon.png" gap:platform="android" gap:density="mdpi" />
                                    <icon src="images/appico/icon.png" gap:platform="android" gap:density="hdpi" />
                                    <icon src="images/appico/icon.png" gap:platform="android" gap:density="xhdpi" />
                                  <gap:splash src="images/appico/Splash.png"  />
                                  <!-- iPhone and iPod touch -->
                                  <gap:splash src="images/appico/Splash.png" gap:platform="ios" width="320" height="480" />
                                  <gap:splash src="images/appico/Splash.png" gap:platform="ios" width="640" height="960" />
                                  <gap:splash gap:platform="ios" height="480" src="images/ios/Default.png" width="320" />
                                  <gap:splash gap:platform="ios" height="960" src="images/ios/Default@2x.png" width="640 " />
                                  <!-- iPhone 5 / iPod Touch (5th Generation) -->
                                <!--  <gap:splash src="images/appico/Splash.png" gap:platform="ios" width="640" height="1136" /> -->
                                <gap:splash gap:platform="ios" height="1136" src="images/ios/Default-568h@2x.png" width="640" />
                                  <!-- iPhone 6 -->
                                  <gap:splash src="images/appico/Splash.png" gap:platform="ios" width="750" height="1334" />
                                  <gap:splash src="images/appico/Splash.png" gap:platform="ios" width="1242" height="2208" />
                                  <gap:splash src="images/appico/Splash.png" gap:platform="ios" width="2208" height="1242" />
                                  <gap:splash gap:platform="ios" height="1334" src="images/ios/Default-667h@2x.png" width="750" />
                                  <gap:splash gap:platform="ios" height="2208" src="images/ios/Default-736h@3x.png" width="1242" />
                                  <!-- iPad -->
                                  <gap:splash src="images/appico/Splash.png" gap:platform="ios" width="768" height="1024" />
                                  <gap:splash src="images/appico/Splash.png" gap:platform="ios" width="1024" height="768" />
                                  <!-- Retina iPad -->
                                  <gap:splash src="images/appico/Splash.png" gap:platform="ios" width="1536" height="2048" />
                                  <gap:splash src="images/appico/Splash.png" gap:platform="ios" width="2048" height="1536" />
                                  <gap:config-file platform="ios" parent="UIViewControllerBasedStatusBarAppearance" overwrite="true">
                                    <false/>
                                </gap:config-file>
                                <!-- <plugin name="cordova-plugin-whitelist"  source="npm" version="5.4.0" /> -->
                                <plugin name="cordova-plugin-whitelist" spec="~1.3.1" />
                                <allow-intent href="*" />
                                <allow-navigation href="*" />
                                </widget>
