3 Replies Latest reply on Jan 17, 2009 2:22 AM by SiamJai
    .Gif image reallly bad quality
    icekingxxx
      ok so i made a .Gig image using fire works and its looks really good when i preview it with a transparent backgound.
      but as soon as i export it. the quality changes tremendously. any one have this problem that knows how to fix this?
      here is the links to the images. that shows both stile frames of the .gifs
      http://i44.tinypic.com/znaqsg.png
        • 1. Re: .Gif image reallly bad quality
          Level 7
          Anti aliasing doesn't work with transparent backgrounds. You'll get the
          best result by exporting it with a background color that matches the
          page you will be using it on.
          Linda Rathgeber - Adobe Community Expert
          http://www.adobe.com/communities/experts/members/8.html
          • 2. Re: .Gif image reallly bad quality
            Level 7
            Most likely you need to specify a different matte color when you do the
            export.
            ATB,
            Sam
            "icekingxxx" <webforumsuser@macromedia.com> wrote in message
            news:gjbvtb$h9a$1@forums.macromedia.com...
            > i
            > note: the background is transparent but it turns out bad.
            > http://i41.tinypic.com/biw2h5.jpg
            > here is my gif rendered with black background looks good.
            > http://i41.tinypic.com/nyahwg.gif
            • 3. Re: .Gif image reallly bad quality
              SiamJai Level 2
              Sometimes you can get good results by choosing Alpha Transparency and no matte color in the Export Preview window, but that can slightly increase the filesize.
              If that doesn't work, then your best bet is to follow the advice mentioned above.
