3 Replies Latest reply on Nov 16, 2017 2:15 PM by Naoki-Hada
    Increment Opacity and Flow
    Gelicider
      I'm trying to make a script to increment Opacity and Flow. I jumbled together the script fromRe: Is it possible to script brush opacity?  and Re: brush opacity for scripting
      Opacity Increment:
      function SetPaintBrush(opacity) {
        var idset = stringIDToTypeID( "set" );
        var desc226 = new ActionDescriptor();
        var idnull = stringIDToTypeID( "null" );
        var ref170 = new ActionReference();
          var idPbTl = stringIDToTypeID( "paintbrushTool" );
          ref170.putClass( idPbTl );
          desc226.putReference( idnull, ref170 );
          var id12 = stringIDToTypeID( "to" );
          var desc5 = new ActionDescriptor();
          // opacity
          var id13 = stringIDToTypeID( "opacity" );
          var id14 = stringIDToTypeID( "percentUnit" );
        desc5.putUnitDouble( id13, id14, opacity );
          var id18 = stringIDToTypeID( "null" );
          desc226.putObject( id12, id18, desc5 );
        executeAction( idset, desc226, DialogModes.NO );
      function BrushOpacityGet()
        var ref = new ActionReference();
        ref.putEnumerated(charIDToTypeID("capp"),
                          charIDToTypeID("Ordn"),
                          charIDToTypeID("Trgt")
        var AD = executeActionGet(ref);
        AD = AD.getObjectValue(stringIDToTypeID("currentToolOptions"));
        return(AD.getInteger(stringIDToTypeID("opacity")));
      opacity = BrushOpacityGet();
      var op = opacity+5;
      SetPaintBrush(op);
      Flow Increment:
      function SetPaintBrush(flow) {
          // flow
          var id19 = stringIDToTypeID( "flow" );
        desc5.putUnitDouble( id19, id14, flow );
        return(AD.getInteger(stringIDToTypeID("flow")));
      flow = BrushOpacityGet();
      var flo = flow+5;
      SetPaintBrush(flo);
      It almost works, but there's two major issues on the script
      1. It turns on Shape Dynamics and Scattering and turns off any other parameters (Transfer, Dual Brush, etc.)
      2. The script is pretty slow the first time it runs
      Anyone know what is causing this, and how to fix it?
      Any help will be appreciated!
        • 1. Re: Increment Opacity and Flow
          Davide_Barranca Adobe Community Professional
          very likely problem #2 (the slowness of the first time run) is due to the fact that the BrushOpacityGet is getting the entire Application's descriptor (which contains lots of information that you don't really need). The following implementation gets the tool only, so it should be faster:
            ref.putProperty (stringIDToTypeID ("property"), stringIDToTypeID ("tool")); // Gets only the "tool"
          Let me think about problem #1...
          Davide
          2 people found this helpful
          • 2. Re: Increment Opacity and Flow
            tomzag Level 3
            This is also a big problem for me. As I can see "Scattering" and "Smoothing" will be turned on, all others off.
            I'm using this function (found in the forum here):
                function SetPaintBrush(mode, opacity, flow, penopacity, pensize, penair) {
                    var idset = stringIDToTypeID("set");
                    var idnull = stringIDToTypeID("null");
                    var idPbTl = stringIDToTypeID("paintbrushTool");
                    ref170.putClass(idPbTl);
                    desc226.putReference(idnull, ref170);
                    var id12 = stringIDToTypeID("to");
                    // opacity
                    var id13 = stringIDToTypeID("opacity");
                    var id14 = stringIDToTypeID("percentUnit");
                    desc5.putUnitDouble(id13, id14, opacity);
                    // blend mode
                    var id15 = stringIDToTypeID("mode");
                    var id16 = stringIDToTypeID("blendModel");
                    var id17 = stringIDToTypeID(mode);
                    desc5.putEnumerated(id15, id16, id17);
                    // flow
                    var id19 = stringIDToTypeID("flow");
                    desc5.putUnitDouble(id19, id14, flow);
                    // pressure for opacity
                    desc5.putBoolean(stringIDToTypeID("usePressureOverridesOpacity"), penopacity);
                    // pressure for size
                    desc5.putBoolean(stringIDToTypeID("usePressureOverridesSize"), pensize);
                    // enable air brush
                    desc5.putBoolean(stringIDToTypeID("repeat"), penair);
                    var id18 = stringIDToTypeID("null");
                    desc226.putObject(id12, id18, desc5);
                    executeAction(idset, desc226, DialogModes.NO);
            It happens the same.
            • 3. Re: Increment Opacity and Flow
              Naoki-Hada Level 1
              tomzag Gelicider
              I had same issue.
              r-bin 's code at following thread seems working without resetting issue.
              Re: [Q] Is accessible (get/set) for Brush Settings' Lock features?
              Thank you,
              Naoki
