0 Replies Latest reply on Aug 24, 2017 8:30 AM by samuelel62866604
    set jcr properties with js
    samuelel62866604
      Hi guys,
      i'm using cq5.5 and i need to retrieve a property inside the loadcontent of a dialog, i can do it with the following code:
      loadcontent="function(comp) {
         var properties = CQ.shared.HTTP.eval(CQ.shared.HTTP.noCaching(dlg.path+'.-1.json'));
         if(properties.myVar== undefined)
                   properties.myVar= '0';
      Now i need to update the value of myVar and save it inside the jcr:content
      Is there a way to do it?
      I can create for example something like this (it is a pseudocode):
      var panel = comp.findParentByType('panel');
      var myVar = new CQ.form.TextField({
           type:textField,
      myVar.setValue('0');
      myVar.hide();
      panel.add(myVar);
      but i suppose that exist a simpler way...
      In particular i need also to set a property inside the parent page and i cant do it with the previous approach.
