say I have 1000 jpegs. I want to load 0001-0010 into layers, create a smart object from them then run an action.
I then want to load 0002-0011 and repeat, spitting out a new jpeg sequence
Does anyone know if there is a script out there that I can use as a starting point for this? I'm happy to hack and learn bits as I go, but starting absolutely from scratch is a bit daunting. I know a little javascript and I used to used lingo (anyone remember that!?)
How hard can it be ?
Sounds doable, but need more info:
1. Should each imported layer be converted to Smart Object, or the entire set should be Smart Object?
2. What should happen after you apply action? Should it save & close the document?
3 What do you mean by spitting out a new jpeg sequence ?
hi tomas thanks for responding
1. one smart object (the plan is to apply smart object stack modes)
2 & 3: Document should be exported to jpeg and closed (that's what I mean by spitting out new sequence). ie if the original images were 0001.jpg - 1000.jpg, the new sequence would be the same but saved somewhere else.
I guess this would need to work from bridge and have all the images sent as a batch.
why not save psds? because with 1000 pics tweaking the psds is not viable - all the tweaking needs to be done in the action
