I am using Photoshop to open an MPO image from a stereo camera (Fuji W3). If I choose to edit the results, it displays two images side by side, but I seem to have to modify them separately. Is there a way to link the two so a change in levels, color, etc. made to one is duplicated exactly on the other as well?
Only way I can think of is to create all the corrections using adjustment layers, then copying those layers to the other file. Or creating a LUT and applying that to the other file.
Simple answer... Use an Adjustment Layer, and make sure it is affecting all layers below. MPOs are layered jpegs. This answer works if you are seeing the two layers in a single file side by side.
