7 Replies Latest reply on Jun 24, 2008 6:25 PM by Noelbaland
    Sound Complete or Listener
    Level 7
      Greetings,
      I'm trying to get a simple script to work in Flash 8.
      Background:
      -a stretched out mp3 in a movieclip with a stop(); applied to the end,
      inside of that movieclip.
      -the movieclip is named.
      -the action layer above the movieclip has a stop(); at the end.
      Purpose:
      To have the playhead advance one frame
      after the music is finished playing.
      Results:
      Song finishes and remains stopped.
      Examples tried:
      myclip.onSoundComplete = function() {
      nextFrame();
      trace("media is Finished");
      or
      var myListener = new Object();
      myListener.complete = function(eventObject) {
      nextFrame();
      myclip.addEventListener("complete", myListener);
      Can someone help me?
      Regards,
      Toe Cutter
        • 1. Re: Sound Complete or Listener
          Noelbaland Level 1
          Hello there,
          "-a stretched out mp3 in a movieclip with a stop(); applied to the end,
          inside of that movieclip."
          Since you have the sound stretched out along the timeline you should just add a _root.nextFrame(); under the stop(); at the end. That will advance your main timeline by one frame.
          Or is there something else that happens?
          • 2. Re: Sound Complete or Listener
            Level 7
            Hi Noelbaland,
            Thank you for responding. I understand what you have suggested. I'll try
            this and respond again ASAP.
            Regards,
            ToeCutter
            "Noelbaland" <webforumsuser@macromedia.com> wrote in message
            news:g3d4il$9oh$1@forums.macromedia.com...
            > Hello there,
            > add
            > main
            • 3. Re: Sound Complete or Listener
              Level 7
              Hi again,
              I tried that and here is what happens:
              The sound plays, but the image on the root that should be seen while the
              audio in the MC plays. Why does the image disappear?
              -ToeCutter
              "Toe Cutter" <newsgroup@macromedia.com> wrote in message
              news:g3eeko$qj5$1@forums.macromedia.com...
              > Hi Noelbaland,
              > Regards,
              > ToeCutter
              >> Hello there,
              >> add
              >> your main
              • 4. Re: Sound Complete or Listener
                Noelbaland Level 1
                Hello there,
                Can you put the image inside the mc with the mp3 in it? If so, make sure to stretch the image's timeline out to the same as the mp3.
                If that doesn't work can you tell me a little more about how you have your main timeline set-up?
                • 5. Re: Sound Complete or Listener
                  Level 7
                  Hi Noelbaland,
                  I don't know why I had an issue with the main timeline image not showing up
                  while
                  the MP3 in the MC was playing, but after I tried sticking the image in the
                  MC
                  (it worked in this case) and then cleared the frames in the image layer,
                  the maintimeline seemed to show the image again. WEIRD!
                  Perhaps the blank layer above the MP3 layer is necessary in the MC?
                  Anyway, now that it is showing the image, I'm still stuck on the
                  Actionscript.
                  Here is what I have:
                  Main timeline is meant to play a slide with an MP3. (There are 9 of these
                  slide/MP3 sets)
                  The image is on the main timeline with a "stop();" in the actions layer
                  after each image. The sound layer on the main timeline is where the MC of
                  MP3 goes
                  and it is in there where I applied your script and additional trials and
                  errors.
                  Here are some of the terrible things I was trying:
                  stop();
                  //_root.nextFrame();
                  //_root.Frame("394");
                  gotoAndPlay(this._parent(394));
                  (Sidenote: the main timeline has the stop applied to frame 393)
                  Another thing I tried was this:
                  mySound_mc = new Sound();
                  mySound_mc.attachSound("burlington");
                  mySound_mc.start();
                  mySound_mc.onSoundComplete = function () {
                  // Intro's done. Display the chapter1 menu.
                  _level0.gotoAndStop("mall02");
                  Please advise.
                  Thank you,
                  ToeCutter
                  news:g3pga7$50d$1@forums.macromedia.com...
                  > Hello there,
                  > to
                  > Thanks
                  • 6. Re: Sound Complete or Listener
                    Level 7
                    Well, nothing is quite as satisfying than stumbling upon the truth. Thank
                    you Noelbaland for pointing me in the right direction because here is what
                    worked:
                    stopAllSounds();
                    _root.gotoAndPlay(394);
                    Yeehaaw!
                    Regards,
                    ToeCutter
                    news:g3r6n3$2ht$1@forums.macromedia.com...
                    > Hi Noelbaland,
                    > up while
                    > MC
                    > Actionscript.
                    > slide/MP3 sets)
                    > MP3 goes
                    > errors.
                    > stop();
                    > mySound_mc.start();
                    > Please advise.
                    > Thank you,
                    > ToeCutter
                    >> Hello there,
                    >> to
                    >> your
                    >> Thanks
                    • 7. Re: Sound Complete or Listener
                      Noelbaland Level 1
                      Hello Toe Cutter,
                      Glad you found the solution and I could be of help!
