• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
ACR 9.12 Won't sync settings
New Here ,
Aug 27, 2017 Aug 27, 2017
Having trouble with Camera Raw 9.12.0.784  using Windows 7 - 64
Just today I am trying to edit and tweak 1800 Canon .cr2 files and when I select more than one file in ACR and choose "Sync Settings" as I always do, ACR doesn't change the settings of the other files selected. This also happens if I save an adjustment preset then choose more than one file to Apply preset to. IF I choose one file at a time it will usually change that file using Apply preset, but no matter how many files chosen Sync settings will not work.
This happens when going to ACR through Bridge as well as through Photoshop.
I have uninstalled and then re-installed Photoshop and Bridge through CC. Once reinstalled, I was able to sync 8 files but then immediately sync quite working again.
Views
628
Translate
Translate
Report
Report
Community guidelines
community guidelines
Adobe Employee , Sep 06, 2017 Sep 06, 2017
Hi Gregw,
Please follow these steps and let us know if it helps:
1. Update to the latest version of Bridge.
Download the latest Bridge update by going to Help > Updates or from the Adobe website at http://www.adobe.com/downloads/updates.html.
2. Reset preferences, reset the default workspace and purge the cache.
You can also purge the cache by doing the following:
Choose Edit > Preferences (Windows) or Bridge > Preferences (Mac OS).
Select the Cache panel.
Click Purge Cache.
Or, you can manually purge th
Votes
Translate
Translate
Adobe Employee ,
Hi Gregw,
Click Purge Cache.
Or, you can manually purge the cache by doing the following:
Look at Location and note the path for the Cache folder.
In the Finder, navigate to the Cache folder.
Drag the Cache folder to the Trash (Mac OS).
3. Reset the permissions of Application Support Folder:
In top menu Bar -> Go->Go to folder
Type in ~\Library
Select Application Support right click get info and Under sharing Permissions please change all permission to read and write.
Regards,
Sahil
Votes
Translate
Translate
Report
Report
New Here ,
Jan 11, 2018 Jan 11, 2018
LATEST
Can you elaborate on step 3? I don't understand... Sounds like a MAC-only step, and I'm on Windows. I've done steps 1 and 2 and still have the issue described by the original poster..
Votes
Translate
Translate
Report
Report
