0 Replies Latest reply on Aug 28, 2017 2:08 AM by monikad21174897
    How add trim marks and bleed to PDF MultiExporter.jsx
      I am using MultiExporter.jsx
      An Illustrator script for exporting layers and/or artboards into separate files (PNG8 / PNG24 / EPS / PDF / SVG / JPG / …
      I would like to add this options when saving multiple artboards to separate PDFs:
      - trim marks
      - bleed: always 3 mm or: use document bleed settings
      I managed to add trim marks but it makes bleed bigger than the desired 3mm
      else if ( this.format == 'PDF' ) {
                  options = new PDFSaveOptions();
                  options.compatibility = PDFCompatibility.ACROBAT5;
                  options.generateThumbnails = true;
                  options.preserveEditability = false;
                  options.trimMarks = true;
      Any ideas?
      Thank you so much,
