2 Replies Latest reply on Feb 9, 2018 4:07 AM by t1350
    issues converting word files to pdf
    samantham67528827
      I recently got Adobe Acrobat 2017 and I'm trying to combine word files into a PDF off a a shared drive.  It says that no file can be created because of an unidentified error and then locks the word files for editing under my name until I restart my computer.  Please help!
        • 1. Re: issues converting word files to pdf
          Works1 Level 1
          Some users have found a workaround for a similar problem is to convert the Word files to PDFs first, then do the combining into one document. You might also try copying the files to the local C: drive on the PC before attempting to combine them (I've never seen this work, but I've seen this suggested elsewhere).
          • 2. Re: issues converting word files to pdf
            t1350 Level 1
            I started having a similar problem recently except it doesn't lock my files. And, the problem happens with the files on my local C: drive. I have to regularly combine 30-50 or 60 Word documents into a single PDF and its not realistic to make each one into a PDF file. Need a solution to this problem pretty bad.
