22 Replies Latest reply on Aug 31, 2017 12:35 AM by kglad
    swapping symbols on click and displaying work online
    suckboi Level 1
      Hi.  I have two questions.  First is probably a no brainer... but How do I display my work created in Animate CC online without exporting the animation to a video or .gif  file?  I see that when I publish, I have a bunch of options that ultimately provide me with a js doc, html doc, and an images folder with either what looks like a sprite of all my layers or each layer indivdually depending on the choice selected.  When I open the html file pulshed, it works fine just as it does when I test it in Animate CC.  However, if I try to but the html and js file in codepen or codepen or jsfiddle... I've tried a bunch... I can't seem to get it to work.  Even if I add an image tag link to the images in my file hosted somewhere online...  So  what's the gest way to showcase your work?  Mine has an interactive element so I'd like to display the code as is...
      Second. Below is a gif of my project next to the actual product (I am cloning for a portfolio example).  Every moving portion is its own symbol wIthin one larger, all enompassing symbol.  But notice how the video of the actual product, once tapped, changes the colors of the buildings, planes, etc.  I assume this is super easy to do give all my layers are seperate and I can think of a couple ways to do workarounds... but I want to learn how this should be done within animate...
      so I want to add something like an onClick(event) that swaps the symbols that need to change color in some way.  I'm thinkng this could either happen by actually triggering the colors to change, it could hide the orange buildings and reveal the purple ones that have the exact same motion path and are running the same motion... just hidden.  I have no idea the best way!  I am very new to Animate... but want the colors to changes every time the screen is clicked without restarting the animation or anything.  Thanks!!  Here's a gif of my work next to a video of the actual working app.  Then below that is my ciurrent html and js files I'm publishing.
      GIF COMPARISON
      HTML
          <!DOCTYPE html>
              NOTES:
              1. All tokens are represented by '$' sign in the template.
              2. You can write your code only wherever mentioned.
              3. All occurrences of existing tokens will be replaced by their appropriate values.
              4. Blank lines will be removed automatically.
              5. Remove unnecessary comments before creating your template.
          <html>
          <head>
          <meta charset="UTF-8">
          <meta name="authoring-tool" content="Adobe_Animate_CC">
          <title>metraaaa</title>
          <!-- write your code here -->
          <script src="https://code.createjs.com/createjs-2015.11.26.min.js"></script>
          <script src="metraaaa.js"></script>
          <script>
          var canvas, stage, exportRoot, anim_container, dom_overlay_container, fnStartAnimation;
          function init() {
              canvas = document.getElementById("canvas");
              anim_container = document.getElementById("animation_container");
              dom_overlay_container = document.getElementById("dom_overlay_container");
              var comp=AdobeAn.getComposition("A26828080B9749C3AB98ECB4AC46FD1C");
              var lib=comp.getLibrary();
              var loader = new createjs.LoadQueue(false);
              loader.addEventListener("fileload", function(evt){handleFileLoad(evt,comp)});
              loader.addEventListener("complete", function(evt){handleComplete(evt,comp)});
              loader.loadManifest(lib.properties.manifest);
          function handleFileLoad(evt, comp) {
              var images=comp.getImages();
              if (evt && (evt.item.type == "image")) { images[evt.item.id] = evt.result; }
          function handleComplete(evt,comp) {
              //This function is always called, irrespective of the content. You can use the variable "stage" after it is created in token create_stage.
              var ss=comp.getSpriteSheet();
              var queue = evt.target;
              var ssMetadata = lib.ssMetadata;
              for(i=0; i<ssMetadata.length; i++) {
                  ss[ssMetadata[i].name] = new createjs.SpriteSheet( {"images": [queue.getResult(ssMetadata[i].name)], "frames": ssMetadata[i].frames} )
              var preloaderDiv = document.getElementById("_preload_div_");
              preloaderDiv.style.display = 'none';
              canvas.style.display = 'block';
              exportRoot = new lib.metraaaa();
              stage = new lib.Stage(canvas);
              stage.addChild(exportRoot);
              //Registers the "tick" event listener.
              fnStartAnimation = function() {
                  createjs.Ticker.setFPS(lib.properties.fps);
                  createjs.Ticker.addEventListener("tick", stage);
              //Code to support hidpi screens and responsive scaling.
              function makeResponsive(isResp, respDim, isScale, scaleType) {
                  var lastW, lastH, lastS=1
                  window.addEventListener('resize', resizeCanvas);
                  resizeCanvas();
                  function resizeCanvas() {
                      var w = lib.properties.width, h = lib.properties.height;
                      var iw = window.innerWidth, ih=window.innerHeight;
                      var pRatio = window.devicePixelRatio || 1, xRatio=iw/w, yRatio=ih/h, sRatio=1;
                      if(isResp) {
                          if((respDim=='width'&&lastW==iw) || (respDim=='height'&&lastH==ih)) {
                              sRatio = lastS;
                          else if(!isScale) {
                              if(iw<w || ih<h)
                                  sRatio = Math.min(xRatio, yRatio);
                          else if(scaleType==1) {
                          else if(scaleType==2) {
                              sRatio = Math.max(xRatio, yRatio);
                      canvas.width = w*pRatio*sRatio;
                      canvas.height = h*pRatio*sRatio;
                      canvas.style.width = anim_container.style.width = dom_overlay_container.style.width = preloaderDiv.style.width = w*sRatio+'px';
                      canvas.style.height = anim_container.style.height = dom_overlay_container.style.height = preloaderDiv.style.height = h*sRatio+'px';
                      stage.scaleX = pRatio*sRatio;
                      stage.scaleY = pRatio*sRatio;
                      lastW = iw; lastH = ih; lastS = sRatio;
              makeResponsive(true,'both',true,2);
              AdobeAn.compositionLoaded(lib.properties.id);
              fnStartAnimation();
          </script>
          </head>
          <body onload="init();" style="margin:0px;">
              <div id="animation_container" style="background-color:rgba(255, 255, 255, 1.00); width:750px; height:1334px">
                  <canvas id="canvas" width="750" height="1334" style="position: absolute; display: none; background-color:rgba(255, 255, 255, 1.00);"></canvas>
                  <div id="dom_overlay_container" style="pointer-events:none; overflow:hidden; width:750px; height:1334px; position: absolute; left: 0px; top: 0px; display: none;">
                  </div>
              </div>
              <div id='_preload_div_' style='display: inline-block; height:1334px; width: 750px; vertical-align=middle;position:absolute;left:0px;top:0px;text-align: center;'>   <span style='display: inline-block; height: 100%; vertical-align: middle;'></span>  <img src=images/_preloader.gif style='vertical-align: middle; max-height: 100%'/></div>
          </body>
          </html>
      AND JS
      (function (cjs, an) {
      var p; // shortcut to reference prototypes
      var lib={};var ss={};var img={};
      lib.webFontTxtInst = {};
      var loadedTypekitCount = 0;
      var loadedGoogleCount = 0;
      var gFontsUpdateCacheList = [];
      var tFontsUpdateCacheList = [];
      lib.ssMetadata = [
              {name:"metraaaa_atlas_", frames: [[7075,0,277,287],[5571,355,1056,125],[6629,252,200,200],[5571,0,750,353],[0,0,5569,517],[6831,289,421,75],[3020,519,4327,240],[0,519,3018,361],[6323,0,750,250],[5571,482,750,13]]}
      lib.updateListCache = function (cacheList) {
          for(var i = 0; i < cacheList.length; i++) {
              if(cacheList[i].cacheCanvas)
                  cacheList[i].updateCache();
      lib.addElementsToCache = function (textInst, cacheList) {
          var cur = textInst;
          while(cur != null && cur != exportRoot) {
              if(cacheList.indexOf(cur) != -1)
                  break;
              cur = cur.parent;
          if(cur != exportRoot) {
              var cur2 = textInst;
              var index = cacheList.indexOf(cur);
              while(cur2 != null && cur2 != cur) {
                  cacheList.splice(index, 0, cur2);
                  cur2 = cur2.parent;
                  index++;
          else {
              cur = textInst;
                  cacheList.push(cur);
                  cur = cur.parent;
      lib.gfontAvailable = function(family, totalGoogleCount) {
          lib.properties.webfonts[family] = true
          var txtInst = lib.webFontTxtInst && lib.webFontTxtInst[family] || [];
          for(var f = 0; f < txtInst.length; ++f)
              lib.addElementsToCache(txtInst[f], gFontsUpdateCacheList);
          loadedGoogleCount++;
          if(loadedGoogleCount == totalGoogleCount) {
              lib.updateListCache(gFontsUpdateCacheList);
      lib.tfontAvailable = function(family, totalTypekitCount) {
              lib.addElementsToCache(txtInst[f], tFontsUpdateCacheList);
          loadedTypekitCount++;
          if(loadedTypekitCount == totalTypekitCount) {
              lib.updateListCache(tFontsUpdateCacheList);
      // symbols:
      (lib.BanePlane = function() {
          this.spriteSheet = ss["metraaaa_atlas_"];
          this.gotoAndStop(0);
      }).prototype = p = new cjs.Sprite();
      (lib.baneTrain = function() {
          this.gotoAndStop(1);
      (lib.giphy_0 = function() {
          this.gotoAndStop(2);
      (lib.Layer5 = function() {
          this.gotoAndStop(3);
      (lib.orangeBs = function() {
          this.gotoAndStop(4);
      (lib.orangePlane = function() {
          this.gotoAndStop(5);
      (lib.OrangeStatues = function() {
          this.gotoAndStop(6);
      (lib.sky = function() {
          this.gotoAndStop(7);
      (lib.top = function() {
          this.gotoAndStop(8);
      (lib.tracks = function() {
          this.gotoAndStop(9);
      // helper functions:
      function mc_symbol_clone() {
          var clone = this._cloneProps(new this.constructor(this.mode, this.startPosition, this.loop));
          clone.gotoAndStop(this.currentFrame);
          clone.paused = this.paused;
          clone.framerate = this.framerate;
          return clone;
      function getMCSymbolPrototype(symbol, nominalBounds, frameBounds) {
          var prototype = cjs.extend(symbol, cjs.MovieClip);
          prototype.clone = mc_symbol_clone;
          prototype.nominalBounds = nominalBounds;
          prototype.frameBounds = frameBounds;
          return prototype;
      (lib.Symbol8 = function(mode,startPosition,loop) {
          this.initialize(mode,startPosition,loop,{});
          // Layer 1
          this.instance = new lib.BanePlane();
          this.instance.parent = this;
          this.instance.setTransform(1268,28);
          this.instance_1 = new lib.orangePlane();
          this.instance_1.parent = this;
          this.instance_1.setTransform(2537,0);
          this.instance_2 = new lib.orangePlane();
          this.instance_2.parent = this;
          this.timeline.addTween(cjs.Tween.get({}).to({state:[{t:this.instance_2},{t:this.instance_1},{t:this.instance}]}).wait(1));
      }).prototype = getMCSymbolPrototype(lib.Symbol8, new cjs.Rectangle(0,0,2958,315), null);
      (lib.Symbol5 = function(mode,startPosition,loop) {
          // Layer 1
          this.instance = new lib.sky();
          this.timeline.addTween(cjs.Tween.get(this.instance).wait(1));
      }).prototype = getMCSymbolPrototype(lib.Symbol5, new cjs.Rectangle(0,0,3018,361), null);
      (lib.Symbol4 = function(mode,startPosition,loop) {
          // Layer 1
          this.instance = new lib.OrangeStatues();
      }).prototype = getMCSymbolPrototype(lib.Symbol4, new cjs.Rectangle(0,0,4327,240), null);
      (lib.Symbol3 = function(mode,startPosition,loop) {
          // Layer 1
          this.instance = new lib.orangeBs();
      }).prototype = getMCSymbolPrototype(lib.Symbol3, new cjs.Rectangle(0,0,5569,517), null);
      (lib.Symbol2 = function(mode,startPosition,loop) {
          // Layer 1
          this.instance = new lib.baneTrain();
          this.instance.setTransform(0,180);
          this.instance_1 = new lib.giphy_0();
          this.instance_1.setTransform(165,0);
          this.timeline.addTween(cjs.Tween.get({}).to({state:[{t:this.instance_1},{t:this.instance}]}).wait(1));
      }).prototype = getMCSymbolPrototype(lib.Symbol2, new cjs.Rectangle(0,0,1056,305), null);
      (lib.tRAINNNNNBANE = function(mode,startPosition,loop) {
          // Layer 1
          this.instance = new lib.Symbol2();
          this.instance.setTransform(528,152.5,1,1,0,0,0,528,152.5);
          this.timeline.addTween(cjs.Tween.get(this.instance).wait(1).to({x:532},0).wait(1).to({x:536},0).wait(1).to({x:540},0).wait(1).to({x:544},0).wait(1).to({x:548},0).wait(1).to({x:552},0).wait(1).to({x:556},0).wait(1).to({x:560},0).wait(1).to({x:564},0).wait(1).to({x:568},0).wait(1).to({x:572},0).wait(1).to({x:576},0).wait(1).to({x:580},0).wait(1).to({x:584},0).wait(1).to({x:588},0).wait(1).to({x:592},0).wait(1).to({x:596},0).wait(1).to({x:600},0).wait(1).to({x:604},0).wait(1).to({x:608},0).wait(1).to({x:612},0).wait(1).to({x:616},0).wait(1).to({x:620},0).wait(1).to({x:624},0).wait(1).to({x:628},0).wait(1).to({x:632},0).wait(1).to({x:636},0).wait(1).to({x:640},0).wait(1).to({x:644},0).wait(1).to({x:648},0).wait(1).to({x:652},0).wait(1).to({x:656},0).wait(1).to({x:660},0).wait(1).to({x:664},0).wait(1).to({x:668},0).wait(1).to({x:672},0).wait(1).to({x:676},0).wait(1).to({x:680},0).wait(1).to({x:684},0).wait(1).to({x:688},0).wait(1).to({x:692},0).wait(1).to({x:696},0).wait(1).to({x:700},0).wait(1).to({x:704},0).wait(1).to({x:708},0).wait(1).to({x:712},0).wait(1).to({x:716},0).wait(1).to({x:720},0).wait(1).to({x:724},0).wait(1).to({x:728},0).wait(1).to({x:732},0).wait(1).to({x:736},0).wait(1).to({x:740},0).wait(1).to({x:744},0).wait(1).to({x:748},0).wait(1).to({x:752},0).wait(1).to({x:756},0).wait(1).to({x:760},0).wait(1).to({x:764},0).wait(1).to({x:768},0).wait(1).to({x:772},0).wait(1).to({x:776},0).wait(1).to({x:780},0).wait(1).to({x:784},0).wait(1).to({x:788},0).wait(1).to({x:792},0).wait(1).to({x:796},0).wait(1).to({x:800},0).wait(1).to({x:804},0).wait(1).to({x:808},0).wait(1).to({x:812},0).wait(1).to({x:816},0).wait(1).to({x:820},0).wait(1).to({x:824},0).wait(1).to({x:828},0).wait(1).to({x:832},0).wait(1).to({x:836},0).wait(1).to({x:840},0).wait(1).to({x:844},0).wait(1).to({x:848},0).wait(1).to({x:852},0).wait(1).to({x:856},0).wait(1).to({x:860},0).wait(1).to({x:864},0).wait(1).to({x:868},0).wait(1).to({x:872},0).wait(1).to({x:876},0).wait(1).to({x:880},0).wait(1).to({x:884},0).wait(1).to({x:888},0).wait(1).to({x:892},0).wait(1).to({x:896},0).wait(1).to({x:900},0).wait(1).to({x:904},0).wait(1).to({x:908},0).wait(1).to({x:912},0).wait(1).to({x:916},0).wait(1).to({x:920},0).wait(1).to({x:924},0).wait(1).to({x:928},0).wait(1).to({x:932},0).wait(1).to({x:936},0).wait(1).to({x:940},0).wait(1).to({x:944},0).wait(1).to({x:948},0).wait(1).to({x:952},0).wait(1).to({x:956},0).wait(1).to({x:960},0).wait(1).to({x:964},0).wait(1).to({x:968},0).wait(1).to({x:972},0).wait(1).to({x:976},0).wait(1).to({x:979.9},0).wait(1).to({x:983.9},0).wait(1).to({x:987.9},0).wait(1).to({x:991.9},0).wait(1).to({x:995.9},0).wait(1).to({x:1000},0).wait(1).to({x:1004},0).wait(1));
      }).prototype = p = new cjs.MovieClip();
      p.nominalBounds = new cjs.Rectangle(0,0,1056,305);
      (lib.Symbol1 = function(mode,startPosition,loop) {
          // Layer 1
          this.instance = new lib.tRAINNNNNBANE();
          this.instance.setTransform(528,159.5,1,1,0,0,0,528,152.5);
          this.timeline.addTween(cjs.Tween.get(this.instance).wait(61));
      p.nominalBounds = new cjs.Rectangle(0,7,1056,305);
      (lib.statues = function(mode,startPosition,loop) {
          // statues
          this.instance = new lib.Symbol4();
          this.instance.setTransform(2163.5,120,1,1,0,0,0,2163.5,120);
          this.timeline.addTween(cjs.Tween.get(this.instance).wait(1).to({x:2156.5},0).wait(1).to({x:2149.4},0).wait(1).to({x:2142.3},0).wait(1).to({x:2135.2},0).wait(1).to({x:2128.1},0).wait(1).to({x:2121},0).wait(1).to({x:2114},0).wait(1).to({x:2106.9},0).wait(1).to({x:2099.8},0).wait(1).to({x:2092.7},0).wait(1).to({x:2085.6},0).wait(1).to({x:2078.5},0).wait(1).to({x:2071.5},0).wait(1).to({x:2064.4},0).wait(1).to({x:2057.3},0).wait(1).to({x:2050.2},0).wait(1).to({x:2043.1},0).wait(1).to({x:2036},0).wait(1).to({x:2029},0).wait(1).to({x:2021.9},0).wait(1).to({x:2014.8},0).wait(1).to({x:2007.7},0).wait(1).to({x:2000.6},0).wait(1).to({x:1993.5},0).wait(1).to({x:1986.5},0).wait(1).to({x:1979.4},0).wait(1).to({x:1972.3},0).wait(1).to({x:1965.2},0).wait(1).to({x:1958.1},0).wait(1).to({x:1951.1},0).wait(1).to({x:1944},0).wait(1).to({x:1936.9},0).wait(1).to({x:1929.8},0).wait(1).to({x:1922.7},0).wait(1).to({x:1915.6},0).wait(1).to({x:1908.5},0).wait(1).to({x:1901.5},0).wait(1).to({x:1894.4},0).wait(1).to({x:1887.3},0).wait(1).to({x:1880.2},0).wait(1).to({x:1873.1},0).wait(1).to({x:1866},0).wait(1).to({x:1859},0).wait(1).to({x:1851.9},0).wait(1).to({x:1844.8},0).wait(1).to({x:1837.7},0).wait(1).to({x:1830.6},0).wait(1).to({x:1823.5},0).wait(1).to({x:1816.5},0).wait(1).to({x:1809.4},0).wait(1).to({x:1802.3},0).wait(1).to({x:1795.2},0).wait(1).to({x:1788.1},0).wait(1).to({x:1781},0).wait(1).to({x:1774},0).wait(1).to({x:1766.9},0).wait(1).to({x:1759.8},0).wait(1).to({x:1752.7},0).wait(1).to({x:1745.6},0).wait(1).to({x:1738.5},0).wait(1).to({x:1731.5},0).wait(1).to({x:1724.4},0).wait(1).to({x:1717.3},0).wait(1).to({x:1710.2},0).wait(1).to({x:1703.1},0).wait(1).to({x:1696},0).wait(1).to({x:1689},0).wait(1).to({x:1681.9},0).wait(1).to({x:1674.8},0).wait(1).to({x:1667.7},0).wait(1).to({x:1660.6},0).wait(1).to({x:1653.5},0).wait(1).to({x:1646.5},0).wait(1).to({x:1639.4},0).wait(1).to({x:1632.3},0).wait(1).to({x:1625.2},0).wait(1).to({x:1618.1},0).wait(1).to({x:1611},0).wait(1).to({x:1604},0).wait(1).to({x:1596.9},0).wait(1).to({x:1589.8},0).wait(1).to({x:1582.7},0).wait(1).to({x:1575.6},0).wait(1).to({x:1568.5},0).wait(1).to({x:1561.5},0).wait(1).to({x:1554.4},0).wait(1).to({x:1547.3},0).wait(1).to({x:1540.2},0).wait(1).to({x:1533.1},0).wait(1).to({x:1526},0).wait(1).to({x:1518.9},0).wait(1).to({x:1511.9},0).wait(1).to({x:1504.8},0).wait(1).to({x:1497.7},0).wait(1).to({x:1490.6},0).wait(1).to({x:1483.5},0).wait(1).to({x:1476.4},0).wait(1).to({x:1469.4},0).wait(1).to({x:1462.3},0).wait(1).to({x:1455.2},0).wait(1).to({x:1448.1},0).wait(1).to({x:1441},0).wait(1).to({x:1433.9},0).wait(1).to({x:1426.9},0).wait(1).to({x:1419.8},0).wait(1).to({x:1412.7},0).wait(1).to({x:1405.6},0).wait(1).to({x:1398.5},0).wait(1).to({x:1391.4},0).wait(1).to({x:1384.4},0).wait(1).to({x:1377.3},0).wait(1).to({x:1370.2},0).wait(1).to({x:1363.1},0).wait(1).to({x:1356},0).wait(1).to({x:1348.9},0).wait(1).to({x:1341.9},0).wait(1).to({x:1334.8},0).wait(1).to({x:1327.7},0).wait(1).to({x:1320.6},0).wait(1).to({x:1313.5},0).wait(1).to({x:1306.4},0).wait(1).to({x:1299.4},0).wait(1).to({x:1292.3},0).wait(1).to({x:1285.2},0).wait(1).to({x:1278.1},0).wait(1).to({x:1271},0).wait(1).to({x:1263.9},0).wait(1).to({x:1256.9},0).wait(1).to({x:1249.8},0).wait(1).to({x:1242.7},0).wait(1).to({x:1235.6},0).wait(1).to({x:1228.5},0).wait(1).to({x:1221.4},0).wait(1).to({x:1214.4},0).wait(1).to({x:1207.3},0).wait(1).to({x:1200.2},0).wait(1).to({x:1193.1},0).wait(1).to({x:1186},0).wait(1).to({x:1178.9},0).wait(1).to({x:1171.9},0).wait(1).to({x:1164.8},0).wait(1).to({x:1157.7},0).wait(1).to({x:1150.6},0).wait(1).to({x:1143.5},0).wait(1).to({x:1136.4},0).wait(1).to({x:1129.4},0).wait(1).to({x:1122.3},0).wait(1).to({x:1115.2},0).wait(1).to({x:1108.1},0).wait(1).to({x:1101},0).wait(1).to({x:1093.9},0).wait(1).to({x:1086.9},0).wait(1).to({x:1079.8},0).wait(1).to({x:1072.7},0).wait(1).to({x:1065.6},0).wait(1).to({x:1058.5},0).wait(1).to({x:1051.4},0).wait(1).to({x:1044.4},0).wait(1).to({x:1037.3},0).wait(1).to({x:1030.2},0).wait(1).to({x:1023.1},0).wait(1).to({x:1016},0).wait(1).to({x:1008.9},0).wait(1).to({x:1001.9},0).wait(1).to({x:994.8},0).wait(1).to({x:987.7},0).wait(1).to({x:980.6},0).wait(1).to({x:973.5},0).wait(1).to({x:966.4},0).wait(1).to({x:959.4},0).wait(1).to({x:952.3},0).wait(1).to({x:945.2},0).wait(1).to({x:938.1},0).wait(1).to({x:931},0).wait(1).to({x:923.9},0).wait(1).to({x:916.9},0).wait(1).to({x:909.8},0).wait(1).to({x:902.7},0).wait(1).to({x:895.6},0).wait(1));
      p.nominalBounds = new cjs.Rectangle(0,0,4327,240);
      (lib.sky_1 = function(mode,startPosition,loop) {
          // Layer 1
          this.instance = new lib.Symbol5();
          this.instance.setTransform(1509,180.5,1,1,0,0,0,1509,180.5);
          this.timeline.addTween(cjs.Tween.get(this.instance).wait(1).to({x:1505.3},0).wait(1).to({x:1501.6},0).wait(1).to({x:1497.8},0).wait(1).to({x:1494.1},0).wait(1).to({x:1490.4},0).wait(1).to({x:1486.6},0).wait(1).to({x:1482.9},0).wait(1).to({x:1479.1},0).wait(1).to({x:1475.4},0).wait(1).to({x:1471.7},0).wait(1).to({x:1467.9},0).wait(1).to({x:1464.2},0).wait(1).to({x:1460.4},0).wait(1).to({x:1456.7},0).wait(1).to({x:1453},0).wait(1).to({x:1449.2},0).wait(1).to({x:1445.5},0).wait(1).to({x:1441.7},0).wait(1).to({x:1438},0).wait(1).to({x:1434.3},0).wait(1).to({x:1430.5},0).wait(1).to({x:1426.8},0).wait(1).to({x:1423},0).wait(1).to({x:1419.3},0).wait(1).to({x:1415.6},0).wait(1).to({x:1411.8},0).wait(1).to({x:1408.1},0).wait(1).to({x:1404.3},0).wait(1).to({x:1400.6},0).wait(1).to({x:1396.9},0).wait(1).to({x:1393.1},0).wait(1).to({x:1389.4},0).wait(1).to({x:1385.6},0).wait(1).to({x:1381.9},0).wait(1).to({x:1378.2},0).wait(1).to({x:1374.4},0).wait(1).to({x:1370.7},0).wait(1).to({x:1367},0).wait(1).to({x:1363.2},0).wait(1).to({x:1359.5},0).wait(1).to({x:1355.7},0).wait(1).to({x:1352},0).wait(1).to({x:1348.3},0).wait(1).to({x:1344.5},0).wait(1).to({x:1340.8},0).wait(1).to({x:1337},0).wait(1).to({x:1333.3},0).wait(1).to({x:1329.6},0).wait(1).to({x:1325.8},0).wait(1).to({x:1322.1},0).wait(1).to({x:1318.3},0).wait(1).to({x:1314.6},0).wait(1).to({x:1310.9},0).wait(1).to({x:1307.1},0).wait(1).to({x:1303.4},0).wait(1).to({x:1299.6},0).wait(1).to({x:1295.9},0).wait(1).to({x:1292.2},0).wait(1).to({x:1288.4},0).wait(1).to({x:1284.7},0).wait(1).to({x:1280.9},0).wait(1).to({x:1277.2},0).wait(1).to({x:1273.5},0).wait(1).to({x:1269.7},0).wait(1).to({x:1266},0).wait(1).to({x:1262.2},0).wait(1).to({x:1258.5},0).wait(1).to({x:1254.8},0).wait(1).to({x:1251},0).wait(1).to({x:1247.3},0).wait(1).to({x:1243.6},0).wait(1).to({x:1239.8},0).wait(1).to({x:1236.1},0).wait(1).to({x:1232.3},0).wait(1).to({x:1228.6},0).wait(1).to({x:1224.9},0).wait(1).to({x:1221.1},0).wait(1).to({x:1217.4},0).wait(1).to({x:1213.6},0).wait(1).to({x:1209.9},0).wait(1).to({x:1206.2},0).wait(1).to({x:1202.4},0).wait(1).to({x:1198.7},0).wait(1).to({x:1194.9},0).wait(1).to({x:1191.2},0).wait(1).to({x:1187.5},0).wait(1).to({x:1183.7},0).wait(1).to({x:1180},0).wait(1).to({x:1176.2},0).wait(1).to({x:1172.5},0).wait(1).to({x:1168.8},0).wait(1).to({x:1165},0).wait(1).to({x:1161.3},0).wait(1).to({x:1157.5},0).wait(1).to({x:1153.8},0).wait(1).to({x:1150.1},0).wait(1).to({x:1146.3},0).wait(1).to({x:1142.6},0).wait(1).to({x:1138.8},0).wait(1).to({x:1135.1},0).wait(1).to({x:1131.4},0).wait(1).to({x:1127.6},0).wait(1).to({x:1123.9},0).wait(1).to({x:1120.2},0).wait(1).to({x:1116.4},0).wait(1).to({x:1112.7},0).wait(1).to({x:1108.9},0).wait(1).to({x:1105.2},0).wait(1).to({x:1101.5},0).wait(1).to({x:1097.7},0).wait(1).to({x:1094},0).wait(1).to({x:1090.2},0).wait(1).to({x:1086.5},0).wait(1).to({x:1082.8},0).wait(1).to({x:1079},0).wait(1).to({x:1075.3},0).wait(1).to({x:1071.5},0).wait(1).to({x:1067.8},0).wait(1).to({x:1064.1},0).wait(1).to({x:1060.3},0).wait(1).to({x:1056.6},0).wait(1).to({x:1052.8},0).wait(1).to({x:1049.1},0).wait(1).to({x:1045.4},0).wait(1).to({x:1041.6},0).wait(1).to({x:1037.9},0).wait(1).to({x:1034.1},0).wait(1).to({x:1030.4},0).wait(1).to({x:1026.7},0).wait(1).to({x:1022.9},0).wait(1).to({x:1019.2},0).wait(1).to({x:1015.4},0).wait(1).to({x:1011.7},0).wait(1).to({x:1008},0).wait(1).to({x:1004.2},0).wait(1).to({x:1000.5},0).wait(1).to({x:996.8},0).wait(1).to({x:993},0).wait(1).to({x:989.3},0).wait(1).to({x:985.5},0).wait(1).to({x:981.8},0).wait(1).to({x:978.1},0).wait(1).to({x:974.3},0).wait(1).to({x:970.6},0).wait(1).to({x:966.8},0).wait(1).to({x:963.1},0).wait(1).to({x:959.4},0).wait(1).to({x:955.6},0).wait(1).to({x:951.9},0).wait(1).to({x:948.1},0).wait(1).to({x:944.4},0).wait(1).to({x:940.7},0).wait(1).to({x:936.9},0).wait(1).to({x:933.2},0).wait(1).to({x:929.4},0).wait(1).to({x:925.7},0).wait(1).to({x:922},0).wait(1).to({x:918.2},0).wait(1).to({x:914.5},0).wait(1).to({x:910.7},0).wait(1).to({x:907},0).wait(1).to({x:903.3},0).wait(1).to({x:899.5},0).wait(1).to({x:895.8},0).wait(1).to({x:892},0).wait(1).to({x:888.3},0).wait(1).to({x:884.6},0).wait(1).to({x:880.8},0).wait(1).to({x:877.1},0).wait(1).to({x:873.4},0).wait(1).to({x:869.6},0).wait(1).to({x:865.9},0).wait(1).to({x:862.1},0).wait(1).to({x:858.4},0).wait(1).to({x:854.7},0).wait(1).to({x:850.9},0).wait(1).to({x:847.2},0).wait(1).to({x:843.4},0).wait(1).to({x:839.7},0).wait(1).to({x:836},0).wait(1).to({x:832.2},0).wait(1).to({x:828.5},0).wait(1).to({x:824.7},0).wait(1).to({x:821},0).wait(1).to({x:817.3},0).wait(1).to({x:813.5},0).wait(1).to({x:809.8},0).wait(1).to({x:806},0).wait(1).to({x:802.3},0).wait(1).to({x:798.6},0).wait(1).to({x:794.8},0).wait(1).to({x:791.1},0).wait(1).to({x:787.3},0).wait(1).to({x:783.6},0).wait(1).to({x:779.9},0).wait(1).to({x:776.1},0).wait(1).to({x:772.4},0).wait(1).to({x:768.6},0).wait(1).to({x:764.9},0).wait(1).to({x:761.2},0).wait(1).to({x:757.4},0).wait(1).to({x:753.7},0).wait(1).to({x:750},0).wait(1).to({x:746.2},0).wait(1).to({x:742.5},0).wait(1).to({x:738.7},0).wait(1).to({x:735},0).wait(1).to({x:731.3},0).wait(1).to({x:727.5},0).wait(1).to({x:723.8},0).wait(1).to({x:720},0).wait(1).to({x:716.3},0).wait(1).to({x:712.6},0).wait(1).to({x:708.8},0).wait(1).to({x:705.1},0).wait(1).to({x:701.3},0).wait(1).to({x:697.6},0).wait(1).to({x:693.9},0).wait(1).to({x:690.1},0).wait(1).to({x:686.4},0).wait(1).to({x:682.6},0).wait(1).to({x:678.9},0).wait(1).to({x:675.2},0).wait(1).to({x:671.4},0).wait(1).to({x:667.7},0).wait(1).to({x:663.9},0).wait(1).to({x:660.2},0).wait(1).to({x:656.5},0).wait(1).to({x:652.7},0).wait(1).to({x:649},0).wait(1).to({x:645.2},0).wait(1).to({x:641.5},0).wait(1).to({x:637.8},0).wait(1).to({x:634},0).wait(1).to({x:630.3},0).wait(1).to({x:626.6},0).wait(1).to({x:622.8},0).wait(1).to({x:619.1},0).wait(1).to({x:615.3},0).wait(1).to({x:611.6},0).wait(1).to({x:607.9},0).wait(1).to({x:604.1},0).wait(1).to({x:600.4},0).wait(1).to({x:596.6},0).wait(1).to({x:592.9},0).wait(1).to({x:589.2},0).wait(1).to({x:585.4},0).wait(1).to({x:581.7},0).wait(1).to({x:577.9},0).wait(1).to({x:574.2},0).wait(1).to({x:570.5},0).wait(1).to({x:566.7},0).wait(1).to({x:563},0).wait(1).to({x:559.2},0).wait(1).to({x:555.5},0).wait(1).to({x:551.8},0).wait(1).to({x:548},0).wait(1).to({x:544.3},0).wait(1).to({x:540.5},0).wait(1).to({x:536.8},0).wait(1).to({x:533.1},0).wait(1).to({x:529.3},0).wait(1).to({x:525.6},0).wait(1).to({x:521.8},0).wait(1).to({x:518.1},0).wait(1).to({x:514.4},0).wait(1).to({x:510.6},0).wait(1).to({x:506.9},0).wait(1).to({x:503.1},0).wait(1));
      p.nominalBounds = new cjs.Rectangle(0,0,3018,361);
      (lib.planes = function(mode,startPosition,loop) {
          // Layer 1
          this.instance = new lib.Symbol8();
          this.instance.setTransform(1479,157.5,1,1,0,0,0,1479,157.5);
          this.timeline.addTween(cjs.Tween.get(this.instance).wait(1).to({x:1472},0).wait(1).to({x:1464.9},0).wait(1).to({x:1457.8},0).wait(1).to({x:1450.7},0).wait(1).to({x:1443.6},0).wait(1).to({x:1436.6},0).wait(1).to({x:1429.5},0).wait(1).to({x:1422.4},0).wait(1).to({x:1415.3},0).wait(1).to({x:1408.2},0).wait(1).to({x:1401.1},0).wait(1).to({x:1394.1},0).wait(1).to({x:1387},0).wait(1).to({x:1379.9},0).wait(1).to({x:1372.8},0).wait(1).to({x:1365.7},0).wait(1).to({x:1358.6},0).wait(1).to({x:1351.6},0).wait(1).to({x:1344.5},0).wait(1).to({x:1337.4},0).wait(1).to({x:1330.3},0).wait(1).to({x:1323.2},0).wait(1).to({x:1316.1},0).wait(1).to({x:1309.1},0).wait(1).to({x:1302},0).wait(1).to({x:1294.9},0).wait(1).to({x:1287.8},0).wait(1).to({x:1280.7},0).wait(1).to({x:1273.6},0).wait(1).to({x:1266.6},0).wait(1).to({x:1259.5},0).wait(1).to({x:1252.4},0).wait(1).to({x:1245.3},0).wait(1).to({x:1238.2},0).wait(1).to({x:1231.1},0).wait(1).to({x:1224.1},0).wait(1).to({x:1217},0).wait(1).to({x:1209.9},0).wait(1).to({x:1202.8},0).wait(1).to({x:1195.7},0).wait(1).to({x:1188.6},0).wait(1).to({x:1181.6},0).wait(1).to({x:1174.5},0).wait(1).to({x:1167.4},0).wait(1).to({x:1160.3},0).wait(1).to({x:1153.2},0).wait(1).to({x:1146.1},0).wait(1).to({x:1139.1},0).wait(1).to({x:1132},0).wait(1).to({x:1124.9},0).wait(1).to({x:1117.8},0).wait(1).to({x:1110.7},0).wait(1).to({x:1103.6},0).wait(1).to({x:1096.6},0).wait(1).to({x:1089.5},0).wait(1).to({x:1082.4},0).wait(1).to({x:1075.3},0).wait(1).to({x:1068.2},0).wait(1).to({x:1061.1},0).wait(1).to({x:1054.1},0).wait(1).to({x:1047},0).wait(1).to({x:1039.9},0).wait(1).to({x:1032.8},0).wait(1).to({x:1025.7},0).wait(1).to({x:1018.6},0).wait(1).to({x:1011.6},0).wait(1).to({x:1004.5},0).wait(1).to({x:997.4},0).wait(1).to({x:990.3},0).wait(1).to({x:983.2},0).wait(1).to({x:976.1},0).wait(1).to({x:969.1},0).wait(1).to({x:962},0).wait(1).to({x:954.9},0).wait(1).to({x:947.8},0).wait(1).to({x:940.7},0).wait(1).to({x:933.6},0).wait(1).to({x:926.6},0).wait(1).to({x:919.5},0).wait(1).to({x:912.4},0).wait(1).to({x:905.3},0).wait(1).to({x:898.2},0).wait(1).to({x:891.1},0).wait(1).to({x:884.1},0).wait(1).to({x:877},0).wait(1).to({x:869.9},0).wait(1).to({x:862.8},0).wait(1).to({x:855.7},0).wait(1).to({x:848.6},0).wait(1).to({x:841.6},0).wait(1).to({x:834.5},0).wait(1).to({x:827.4},0).wait(1).to({x:820.3},0).wait(1).to({x:813.2},0).wait(1).to({x:806.1},0).wait(1).to({x:799.1},0).wait(1).to({x:792},0).wait(1).to({x:784.9},0).wait(1).to({x:777.8},0).wait(1).to({x:770.7},0).wait(1).to({x:763.6},0).wait(1).to({x:756.6},0).wait(1).to({x:749.5},0).wait(1).to({x:742.4},0).wait(1).to({x:735.3},0).wait(1).to({x:728.2},0).wait(1).to({x:721.1},0).wait(1).to({x:714.1},0).wait(1).to({x:707},0).wait(1).to({x:699.9},0).wait(1).to({x:692.8},0).wait(1).to({x:685.7},0).wait(1).to({x:678.7},0).wait(1).to({x:671.6},0).wait(1).to({x:664.5},0).wait(1).to({x:657.4},0).wait(1).to({x:650.3},0).wait(1).to({x:643.2},0).wait(1).to({x:636.1},0).wait(1).to({x:629.1},0).wait(1).to({x:622},0).wait(1).to({x:614.9},0).wait(1).to({x:607.8},0).wait(1).to({x:600.7},0).wait(1).to({x:593.6},0).wait(1).to({x:586.6},0).wait(1).to({x:579.5},0).wait(1).to({x:572.4},0).wait(1).to({x:565.3},0).wait(1).to({x:558.2},0).wait(1).to({x:551.1},0).wait(1).to({x:544.1},0).wait(1).to({x:537},0).wait(1).to({x:529.9},0).wait(1).to({x:522.8},0).wait(1).to({x:515.7},0).wait(1).to({x:508.6},0).wait(1).to({x:501.6},0).wait(1).to({x:494.5},0).wait(1).to({x:487.4},0).wait(1).to({x:480.3},0).wait(1).to({x:473.2},0).wait(1).to({x:466.1},0).wait(1).to({x:459.1},0).wait(1).to({x:452},0).wait(1).to({x:444.9},0).wait(1).to({x:437.8},0).wait(1).to({x:430.7},0).wait(1).to({x:423.6},0).wait(1).to({x:416.6},0).wait(1).to({x:409.5},0).wait(1).to({x:402.4},0).wait(1).to({x:395.3},0).wait(1).to({x:388.2},0).wait(1).to({x:381.1},0).wait(1).to({x:374.1},0).wait(1).to({x:367},0).wait(1).to({x:359.9},0).wait(1).to({x:352.8},0).wait(1).to({x:345.7},0).wait(1).to({x:338.6},0).wait(1).to({x:331.6},0).wait(1).to({x:324.5},0).wait(1).to({x:317.4},0).wait(1).to({x:310.3},0).wait(1).to({x:303.2},0).wait(1).to({x:296.1},0).wait(1).to({x:289.1},0).wait(1).to({x:282},0).wait(1).to({x:274.9},0).wait(1).to({x:267.8},0).wait(1).to({x:260.7},0).wait(1).to({x:253.6},0).wait(1).to({x:246.6},0).wait(1).to({x:239.5},0).wait(1).to({x:232.4},0).wait(1).to({x:225.3},0).wait(1).to({x:218.2},0).wait(1).to({x:211.1},0).wait(1).to({x:204.1},0).wait(1).to({x:197.1},0).wait(1).to({x:190},0).wait(1).to({x:183},0).wait(1).to({x:175.9},0).wait(1).to({x:168.9},0).wait(1).to({x:161.8},0).wait(1).to({x:154.8},0).wait(1).to({x:147.7},0).wait(1).to({x:140.7},0).wait(1).to({x:133.6},0).wait(1).to({x:126.6},0).wait(1).to({x:119.5},0).wait(1).to({x:112.5},0).wait(1).to({x:105.4},0).wait(1).to({x:98.4},0).wait(1).to({x:91.3},0).wait(1).to({x:84.3},0).wait(1).to({x:77.2},0).wait(1).to({x:70.2},0).wait(1).to({x:63.1},0).wait(1).to({x:56.1},0).wait(1).to({x:49},0).wait(1).to({x:42},0).wait(1).to({x:34.9},0).wait(1).to({x:27.9},0).wait(1).to({x:20.8},0).wait(1).to({x:13.8},0).wait(1).to({x:6.7},0).wait(1).to({x:-0.3},0).wait(1).to({x:-7.4},0).wait(1).to({x:-14.4},0).wait(1).to({x:-21.5},0).wait(1).to({x:-28.5},0).wait(1).to({x:-35.6},0).wait(1).to({x:-42.6},0).wait(1).to({x:-49.7},0).wait(1).to({x:-56.7},0).wait(1).to({x:-63.8},0).wait(1).to({x:-70.8},0).wait(1).to({x:-77.9},0).wait(1).to({x:-84.9},0).wait(1).to({x:-92},0).wait(1).to({x:-99},0).wait(1).to({x:-106.1},0).wait(1).to({x:-113.1},0).wait(1).to({x:-120.2},0).wait(1).to({x:-127.2},0).wait(1).to({x:-134.3},0).wait(1).to({x:-141.3},0).wait(1).to({x:-148.4},0).wait(1).to({x:-155.4},0).wait(1).to({x:-162.5},0).wait(1).to({x:-169.5},0).wait(1).to({x:-176.6},0).wait(1).to({x:-183.6},0).wait(1).to({x:-190.7},0).wait(1).to({x:-197.7},0).wait(1).to({x:-204.8},0).wait(1).to({x:-211.8},0).wait(1).to({x:-218.9},0).wait(1).to({x:-225.9},0).wait(1).to({x:-233},0).wait(1).to({x:-240},0).wait(1).to({x:-247.1},0).wait(1).to({x:-254.1},0).wait(1).to({x:-261.2},0).wait(1).to({x:-268.2},0).wait(1).to({x:-275.3},0).wait(1).to({x:-282.3},0).wait(1).to({x:-289.4},0).wait(1).to({x:-296.4},0).wait(1).to({x:-303.5},0).wait(1).to({x:-310.5},0).wait(1).to({x:-317.6},0).wait(1).to({x:-324.6},0).wait(1).to({x:-331.7},0).wait(1).to({x:-338.7},0).wait(1).to({x:-345.8},0).wait(1).to({x:-352.8},0).wait(1).to({x:-359.9},0).wait(1).to({x:-366.9},0).wait(1).to({x:-374},0).wait(1).to({x:-381},0).wait(1).to({x:-388.1},0).wait(1).to({x:-395.1},0).wait(1).to({x:-402.2},0).wait(1).to({x:-409.2},0).wait(1).to({x:-416.3},0).wait(1).to({x:-423.3},0).wait(1).to({x:-430.3},0).wait(1).to({x:-437.4},0).wait(1).to({x:-444.4},0).wait(1).to({x:-451.5},0).wait(1).to({x:-458.5},0).wait(1).to({x:-465.6},0).wait(1).to({x:-472.6},0).wait(1).to({x:-479.7},0).wait(1).to({x:-486.7},0).wait(1).to({x:-493.8},0).wait(1).to({x:-500.8},0).wait(1).to({x:-507.9},0).wait(1).to({x:-514.9},0).wait(1).to({x:-522},0).wait(1).to({x:-529},0).wait(1).to({x:-536.1},0).wait(1).to({x:-543.1},0).wait(1).to({x:-550.2},0).wait(1).to({x:-557.2},0).wait(1).to({x:-564.3},0).wait(1).to({x:-571.3},0).wait(1).to({x:-578.4},0).wait(1).to({x:-585.4},0).wait(1).to({x:-592.5},0).wait(1).to({x:-599.5},0).wait(1).to({x:-606.6},0).wait(1).to({x:-613.6},0).wait(1).to({x:-620.7},0).wait(1).to({x:-627.7},0).wait(1).to({x:-634.8},0).wait(1).to({x:-641.8},0).wait(1).to({x:-648.9},0).wait(1).to({x:-655.9},0).wait(1).to({x:-663},0).wait(1).to({x:-670},0).wait(1).to({x:-677.1},0).wait(1).to({x:-684.1},0).wait(1).to({x:-691.2},0).wait(1).to({x:-698.2},0).wait(1).to({x:-705.3},0).wait(1).to({x:-712.3},0).wait(1).to({x:-719.4},0).wait(1).to({x:-726.4},0).wait(1).to({x:-733.5},0).wait(1).to({x:-740.5},0).wait(1).to({x:-747.6},0).wait(1).to({x:-754.6},0).wait(1).to({x:-761.7},0).wait(1).to({x:-768.7},0).wait(1).to({x:-775.8},0).wait(1).to({x:-782.8},0).wait(1).to({x:-789.9},0).wait(1).to({x:-796.9},0).wait(1).to({x:-804},0).wait(1).to({x:-811},0).wait(1).to({x:-818.1},0).wait(1).to({x:-825.1},0).wait(1).to({x:-832.2},0).wait(1).to({x:-839.2},0).wait(1).to({x:-846.3},0).wait(1).to({x:-853.3},0).wait(1).to({x:-860.4},0).wait(1).to({x:-867.4},0).wait(1).to({x:-874.5},0).wait(1).to({x:-881.5},0).wait(1).to({x:-888.6},0).wait(1).to({x:-895.6},0).wait(1).to({x:-902.7},0).wait(1).to({x:-909.7},0).wait(1).to({x:-916.8},0).wait(1).to({x:-923.8},0).wait(1).to({x:-930.9},0).wait(1).to({x:-937.9},0).wait(1).to({x:-945},0).wait(1).to({x:-952},0).wait(1).to({x:-959.1},0).wait(1).to({x:-966.1},0).wait(1).to({x:-973.2},0).wait(1).to({x:-980.2},0).wait(1).to({x:-987.3},0).wait(1).to({x:-994.3},0).wait(1).to({x:-1001.4},0).wait(1).to({x:-1008.4},0).wait(1).to({x:-1015.5},0).wait(1).to({x:-1022.5},0).wait(1).to({x:-1029.6},0).wait(1).to({x:-1036.6},0).wait(1).to({x:-1043.7},0).wait(1).to({x:-1050.7},0).wait(1).to({x:-1057.8},0).wait(1));
      p.nominalBounds = new cjs.Rectangle(0,0,2958,315);
      (lib.buildings = function(mode,startPosition,loop) {
          // buidlings
          this.instance = new lib.Symbol3();
          this.instance.setTransform(2784.5,258.5,1,1,0,0,0,2784.5,258.5);
          this.timeline.addTween(cjs.Tween.get(this.instance).wait(1).to({x:2780.1},0).wait(1).to({x:2775.7},0).wait(1).to({x:2771.3},0).wait(1).to({x:2766.8},0).wait(1).to({x:2762.4},0).wait(1).to({x:2758},0).wait(1).to({x:2753.6},0).wait(1).to({x:2749.1},0).wait(1).to({x:2744.7},0).wait(1).to({x:2740.3},0).wait(1).to({x:2735.9},0).wait(1).to({x:2731.4},0).wait(1).to({x:2727},0).wait(1).to({x:2722.6},0).wait(1).to({x:2718.1},0).wait(1).to({x:2713.7},0).wait(1).to({x:2709.3},0).wait(1).to({x:2704.9},0).wait(1).to({x:2700.4},0).wait(1).to({x:2696},0).wait(1).to({x:2691.6},0).wait(1).to({x:2687.2},0).wait(1).to({x:2682.7},0).wait(1).to({x:2678.3},0).wait(1).to({x:2673.9},0).wait(1).to({x:2669.4},0).wait(1).to({x:2665},0).wait(1).to({x:2660.6},0).wait(1).to({x:2656.2},0).wait(1).to({x:2651.7},0).wait(1).to({x:2647.3},0).wait(1).to({x:2642.9},0).wait(1).to({x:2638.5},0).wait(1).to({x:2634},0).wait(1).to({x:2629.6},0).wait(1).to({x:2625.2},0).wait(1).to({x:2620.8},0).wait(1).to({x:2616.3},0).wait(1).to({x:2611.9},0).wait(1).to({x:2607.5},0).wait(1).to({x:2603},0).wait(1).to({x:2598.6},0).wait(1).to({x:2594.2},0).wait(1).to({x:2589.8},0).wait(1).to({x:2585.3},0).wait(1).to({x:2580.9},0).wait(1).to({x:2576.5},0).wait(1).to({x:2572.1},0).wait(1).to({x:2567.6},0).wait(1).to({x:2563.2},0).wait(1).to({x:2558.8},0).wait(1).to({x:2554.3},0).wait(1).to({x:2549.9},0).wait(1).to({x:2545.5},0).wait(1).to({x:2541.1},0).wait(1).to({x:2536.6},0).wait(1).to({x:2532.2},0).wait(1).to({x:2527.8},0).wait(1).to({x:2523.4},0).wait(1).to({x:2518.9},0).wait(1).to({x:2514.5},0).wait(1).to({x:2510.1},0).wait(1).to({x:2505.7},0).wait(1).to({x:2501.2},0).wait(1).to({x:2496.8},0).wait(1).to({x:2492.4},0).wait(1).to({x:2487.9},0).wait(1).to({x:2483.5},0).wait(1).to({x:2479.1},0).wait(1).to({x:2474.7},0).wait(1).to({x:2470.2},0).wait(1).to({x:2465.8},0).wait(1).to({x:2461.4},0).wait(1).to({x:2457},0).wait(1).to({x:2452.5},0).wait(1).to({x:2448.1},0).wait(1).to({x:2443.7},0).wait(1).to({x:2439.2},0).wait(1).to({x:2434.8},0).wait(1).to({x:2430.4},0).wait(1).to({x:2426},0).wait(1).to({x:2421.5},0).wait(1).to({x:2417.1},0).wait(1).to({x:2412.7},0).wait(1).to({x:2408.3},0).wait(1).to({x:2403.8},0).wait(1).to({x:2399.4},0).wait(1).to({x:2395},0).wait(1).to({x:2390.5},0).wait(1).to({x:2386.1},0).wait(1).to({x:2381.7},0).wait(1).to({x:2377.3},0).wait(1).to({x:2372.8},0).wait(1).to({x:2368.4},0).wait(1).to({x:2364},0).wait(1).to({x:2359.6},0).wait(1).to({x:2355.1},0).wait(1).to({x:2350.7},0).wait(1).to({x:2346.3},0).wait(1).to({x:2341.9},0).wait(1).to({x:2337.4},0).wait(1).to({x:2333},0).wait(1).to({x:2328.6},0).wait(1).to({x:2324.1},0).wait(1).to({x:2319.7},0).wait(1).to({x:2315.3},0).wait(1).to({x:2310.9},0).wait(1).to({x:2306.4},0).wait(1).to({x:2302},0).wait(1).to({x:2297.6},0).wait(1).to({x:2293.2},0).wait(1).to({x:2288.7},0).wait(1).to({x:2284.3},0).wait(1).to({x:2279.9},0).wait(1).to({x:2275.4},0).wait(1).to({x:2271},0).wait(1).to({x:2266.6},0).wait(1).to({x:2262.2},0).wait(1).to({x:2257.7},0).wait(1).to({x:2253.3},0).wait(1).to({x:2248.9},0).wait(1).to({x:2244.5},0).wait(1).to({x:2240},0).wait(1).to({x:2235.6},0).wait(1).to({x:2231.2},0).wait(1).to({x:2226.8},0).wait(1).to({x:2222.3},0).wait(1).to({x:2217.9},0).wait(1).to({x:2213.5},0).wait(1).to({x:2209},0).wait(1).to({x:2204.6},0).wait(1).to({x:2200.2},0).wait(1).to({x:2195.8},0).wait(1).to({x:2191.3},0).wait(1).to({x:2186.9},0).wait(1).to({x:2182.5},0).wait(1).to({x:2178.1},0).wait(1).to({x:2173.6},0).wait(1).to({x:2169.2},0).wait(1).to({x:2164.8},0).wait(1).to({x:2160.3},0).wait(1).to({x:2155.9},0).wait(1).to({x:2151.5},0).wait(1).to({x:2147.1},0).wait(1).to({x:2142.6},0).wait(1).to({x:2138.2},0).wait(1).to({x:2133.8},0).wait(1).to({x:2129.4},0).wait(1).to({x:2124.9},0).wait(1).to({x:2120.5},0).wait(1).to({x:2116.1},0).wait(1).to({x:2111.7},0).wait(1).to({x:2107.2},0).wait(1).to({x:2102.8},0).wait(1).to({x:2098.4},0).wait(1).to({x:2093.9},0).wait(1).to({x:2089.5},0).wait(1).to({x:2085.1},0).wait(1).to({x:2080.7},0).wait(1).to({x:2076.2},0).wait(1).to({x:2071.8},0).wait(1).to({x:2067.4},0).wait(1).to({x:2063},0).wait(1).to({x:2058.5},0).wait(1).to({x:2054.1},0).wait(1).to({x:2049.7},0).wait(1).to({x:2045.2},0).wait(1).to({x:2040.8},0).wait(1).to({x:2036.4},0).wait(1).to({x:2032},0).wait(1).to({x:2027.5},0).wait(1).to({x:2023.1},0).wait(1).to({x:2018.7},0).wait(1).to({x:2014.3},0).wait(1).to({x:2009.8},0).wait(1).to({x:2005.4},0).wait(1).to({x:2001},0).wait(1).to({x:1996.5},0).wait(1).to({x:1992.1},0).wait(1).to({x:1987.7},0).wait(1).to({x:1983.3},0).wait(1).to({x:1978.8},0).wait(1).to({x:1974.4},0).wait(1).to({x:1970},0).wait(1).to({x:1965.6},0).wait(1).to({x:1961.1},0).wait(1).to({x:1956.7},0).wait(1).to({x:1952.3},0).wait(1).to({x:1947.9},0).wait(1).to({x:1943.4},0).wait(1).to({x:1939},0).wait(1).to({x:1934.6},0).wait(1).to({x:1930.1},0).wait(1).to({x:1925.7},0).wait(1).to({x:1921.3},0).wait(1).to({x:1916.9},0).wait(1).to({x:1912.4},0).wait(1).to({x:1908},0).wait(1).to({x:1903.6},0).wait(1).to({x:1899.2},0).wait(1).to({x:1894.7},0).wait(1).to({x:1890.3},0).wait(1).to({x:1885.9},0).wait(1).to({x:1881.4},0).wait(1).to({x:1877},0).wait(1).to({x:1872.6},0).wait(1).to({x:1868.2},0).wait(1).to({x:1863.7},0).wait(1).to({x:1859.3},0).wait(1).to({x:1854.9},0).wait(1).to({x:1850.5},0).wait(1).to({x:1846},0).wait(1).to({x:1841.6},0).wait(1).to({x:1837.2},0).wait(1).to({x:1832.8},0).wait(1).to({x:1828.3},0).wait(1).to({x:1823.9},0).wait(1).to({x:1819.5},0).wait(1).to({x:1815},0).wait(1).to({x:1810.6},0).wait(1).to({x:1806.2},0).wait(1).to({x:1801.8},0).wait(1).to({x:1797.3},0).wait(1).to({x:1792.9},0).wait(1).to({x:1788.5},0).wait(1).to({x:1784.1},0).wait(1).to({x:1779.6},0).wait(1).to({x:1775.2},0).wait(1).to({x:1770.8},0).wait(1).to({x:1766.3},0).wait(1).to({x:1761.9},0).wait(1).to({x:1757.5},0).wait(1).to({x:1753.1},0).wait(1).to({x:1748.6},0).wait(1).to({x:1744.2},0).wait(1).to({x:1739.8},0).wait(1).to({x:1735.4},0).wait(1).to({x:1730.9},0).wait(1).to({x:1726.5},0).wait(1).to({x:1722.1},0).wait(1).to({x:1717.7},0).wait(1).to({x:1713.2},0).wait(1).to({x:1708.8},0).wait(1).to({x:1704.4},0).wait(1).to({x:1699.9},0).wait(1).to({x:1695.5},0).wait(1).to({x:1691.1},0).wait(1).to({x:1686.7},0).wait(1).to({x:1682.2},0).wait(1).to({x:1677.8},0).wait(1).to({x:1673.4},0).wait(1).to({x:1669},0).wait(1).to({x:1664.5},0).wait(1).to({x:1660.1},0).wait(1).to({x:1655.7},0).wait(1).to({x:1651.2},0).wait(1).to({x:1646.8},0).wait(1).to({x:1642.4},0).wait(1).to({x:1638},0).wait(1).to({x:1633.5},0).wait(1).to({x:1629.1},0).wait(1).to({x:1624.7},0).wait(1).to({x:1620.3},0).wait(1).to({x:1615.8},0).wait(1).to({x:1611.4},0).wait(1).to({x:1607},0).wait(1).to({x:1602.5},0).wait(1).to({x:1598.1},0).wait(1).to({x:1593.7},0).wait(1).to({x:1589.3},0).wait(1).to({x:1584.8},0).wait(1).to({x:1580.4},0).wait(1).to({x:1576},0).wait(1).to({x:1571.6},0).wait(1).to({x:1567.1},0).wait(1).to({x:1562.7},0).wait(1).to({x:1558.3},0).wait(1).to({x:1553.9},0).wait(1).to({x:1549.4},0).wait(1).to({x:1545},0).wait(1).to({x:1540.6},0).wait(1).to({x:1536.1},0).wait(1).to({x:1531.7},0).wait(1).to({x:1527.3},0).wait(1).to({x:1522.9},0).wait(1).to({x:1518.4},0).wait(1).to({x:1514},0).wait(1).to({x:1509.6},0).wait(1).to({x:1505.2},0).wait(1).to({x:1500.7},0).wait(1).to({x:1496.3},0).wait(1).to({x:1491.9},0).wait(1).to({x:1487.4},0).wait(1).to({x:1483},0).wait(1).to({x:1478.6},0).wait(1).to({x:1474.2},0).wait(1).to({x:1469.7},0).wait(1).to({x:1465.3},0).wait(1).to({x:1460.9},0).wait(1).to({x:1456.5},0).wait(1).to({x:1452},0).wait(1).to({x:1447.6},0).wait(1).to({x:1443.2},0).wait(1).to({x:1438.8},0).wait(1).to({x:1434.3},0).wait(1).to({x:1429.9},0).wait(1).to({x:1425.5},0).wait(1).to({x:1421},0).wait(1).to({x:1416.6},0).wait(1).to({x:1412.2},0).wait(1).to({x:1407.8},0).wait(1).to({x:1403.3},0).wait(1).to({x:1398.9},0).wait(1).to({x:1394.5},0).wait(1).to({x:1390.1},0).wait(1).to({x:1385.6},0).wait(1).to({x:1381.2},0).wait(1).to({x:1376.8},0).wait(1).to({x:1372.3},0).wait(1).to({x:1367.9},0).wait(1).to({x:1363.5},0).wait(1).to({x:1359.1},0).wait(1).to({x:1354.6},0).wait(1).to({x:1350.2},0).wait(1).to({x:1345.8},0).wait(1).to({x:1341.4},0).wait(1).to({x:1336.9},0).wait(1).to({x:1332.5},0).wait(1).to({x:1328.1},0).wait(1).to({x:1323.7},0).wait(1).to({x:1319.2},0).wait(1).to({x:1314.8},0).wait(1).to({x:1310.4},0).wait(1).to({x:1305.9},0).wait(1).to({x:1301.5},0).wait(1).to({x:1297.1},0).wait(1).to({x:1292.7},0).wait(1).to({x:1288.2},0).wait(1).to({x:1283.8},0).wait(1).to({x:1279.4},0).wait(1).to({x:1275},0).wait(1).to({x:1270.5},0).wait(1).to({x:1266.1},0).wait(1).to({x:1261.7},0).wait(1).to({x:1257.2},0).wait(1).to({x:1252.8},0).wait(1).to({x:1248.4},0).wait(1).to({x:1244},0).wait(1).to({x:1239.5},0).wait(1).to({x:1235.1},0).wait(1).to({x:1230.7},0).wait(1).to({x:1226.3},0).wait(1).to({x:1221.8},0).wait(1).to({x:1217.4},0).wait(1).to({x:1213},0).wait(1).to({x:1208.5},0).wait(1).to({x:1204.1},0).wait(1).to({x:1199.7},0).wait(1).to({x:1195.3},0).wait(1).to({x:1190.8},0).wait(1).to({x:1186.4},0).wait(1).to({x:1182},0).wait(1).to({x:1177.6},0).wait(1).to({x:1173.1},0).wait(1).to({x:1168.7},0).wait(1).to({x:1164.3},0).wait(1).to({x:1159.9},0).wait(1).to({x:1155.4},0).wait(1).to({x:1151},0).wait(1).to({x:1146.6},0).wait(1).to({x:1142.1},0).wait(1).to({x:1137.7},0).wait(1).to({x:1133.3},0).wait(1).to({x:1128.9},0).wait(1).to({x:1124.4},0).wait(1).to({x:1120},0).wait(1).to({x:1115.6},0).wait(1).to({x:1111.2},0).wait(1).to({x:1106.7},0).wait(1).to({x:1102.3},0).wait(1).to({x:1097.9},0).wait(1).to({x:1093.4},0).wait(1).to({x:1089},0).wait(1).to({x:1084.6},0).wait(1).to({x:1080.2},0).wait(1).to({x:1075.7},0).wait(1).to({x:1071.3},0).wait(1).to({x:1066.9},0).wait(1).to({x:1062.5},0).wait(1).to({x:1058},0).wait(1).to({x:1053.6},0).wait(1).to({x:1049.2},0).wait(1).to({x:1044.8},0).wait(1).to({x:1040.3},0).wait(1).to({x:1035.9},0).wait(1).to({x:1031.5},0).wait(1).to({x:1027},0).wait(1).to({x:1022.6},0).wait(1).to({x:1018.2},0).wait(1).to({x:1013.8},0).wait(1).to({x:1009.3},0).wait(1).to({x:1004.9},0).wait(1).to({x:1000.5},0).wait(1).to({x:996.1},0).wait(1).to({x:991.6},0).wait(1).to({x:987.2},0).wait(1).to({x:982.8},0).wait(1).to({x:978.3},0).wait(1).to({x:973.9},0).wait(1).to({x:969.5},0).wait(1).to({x:965.1},0).wait(1).to({x:960.6},0).wait(1).to({x:956.2},0).wait(1).to({x:951.8},0).wait(1).to({x:947.4},0).wait(1).to({x:942.9},0).wait(1).to({x:938.5},0).wait(1).to({x:934.1},0).wait(1).to({x:929.6},0).wait(1));
      p.nominalBounds = new cjs.Rectangle(0,0,5569,517);
      (lib.trainNbane = function(mode,startPosition,loop) {
          // Layer 1
          this.instance = new lib.Symbol1();
          this.instance.setTransform(528,156,1,1,0,0,0,528,156);
          this.timeline.addTween(cjs.Tween.get(this.instance).wait(1).to({regX:766,regY:159.5,x:777.3,y:159.5},0).wait(1).to({x:788.5},0).wait(1).to({x:799.8},0).wait(1).to({x:811},0).wait(1).to({x:822.3},0).wait(1).to({x:833.5},0).wait(1).to({x:844.8},0).wait(1).to({x:856},0).wait(1).to({x:867.3},0).wait(1).to({x:878.5},0).wait(1).to({x:889.8},0).wait(1).to({x:901},0).wait(1).to({x:912.3},0).wait(1).to({x:923.6},0).wait(1).to({x:934.8},0).wait(1).to({x:946.1},0).wait(1).to({x:957.3},0).wait(1).to({x:968.6},0).wait(1).to({x:979.8},0).wait(1).to({x:991.1},0).wait(1).to({x:1002.3},0).wait(1).to({x:1013.6},0).wait(1).to({x:1024.8},0).wait(1).to({x:1036.1},0).wait(1).to({x:1047.3},0).wait(1).to({x:1058.6},0).wait(1).to({x:1069.8},0).wait(1).to({x:1081.1},0).wait(1).to({x:1092.4},0).wait(1).to({x:1103.6},0).wait(1).to({x:1114.9},0).wait(1).to({x:1126.1},0).wait(1).to({x:1137.4},0).wait(1).to({x:1148.6},0).wait(1).to({x:1159.9},0).wait(1).to({x:1171.1},0).wait(1).to({x:1182.4},0).wait(1).to({x:1193.7},0).wait(1).to({x:1204.9},0).wait(1).to({x:1216.2},0).wait(1).to({x:1227.4},0).wait(1).to({x:1238.7},0).wait(1).to({x:1249.9},0).wait(1).to({x:1261.2},0).wait(1).to({x:1272.4},0).wait(1).to({x:1283.7},0).wait(1).to({x:1294.9},0).wait(1).to({x:1306.2},0).wait(1).to({x:1317.4},0).wait(1).to({x:1328.7},0).wait(1).to({x:1340},0).wait(1).to({x:1351.2},0).wait(1).to({x:1362.5},0).wait(1).to({x:1373.7},0).wait(1).to({x:1385},0).wait(1).to({x:1396.2},0).wait(1).to({x:1407.5},0).wait(1).to({x:1418.7},0).wait(1).to({x:1430},0).wait(1).to({x:1441.2},0).wait(1).to({x:1452.5},0).wait(1).to({x:1463.8},0).wait(1).to({x:1475},0).wait(1).to({x:1486.3},0).wait(1).to({x:1497.5},0).wait(1).to({x:1508.8},0).wait(1).to({x:1520},0).wait(1).to({x:1531.3},0).wait(1).to({x:1542.5},0).wait(1).to({x:1553.8},0).wait(1).to({x:1565},0).wait(1).to({x:1576.3},0).wait(1).to({x:1587.5},0).wait(1).to({x:1598.8},0).wait(1).to({x:1610.1},0).wait(1).to({x:1621.3},0).wait(1).to({x:1632.6},0).wait(1).to({x:1643.8},0).wait(1).to({x:1655.1},0).wait(1).to({x:1666.3},0).wait(1).to({x:1677.6},0).wait(1).to({x:1688.8},0).wait(1).to({x:1700.1},0).wait(1).to({x:1711.3},0).wait(1).to({x:1722.6},0).wait(1).to({x:1733.8},0).wait(1).to({x:1745.1},0).wait(1).to({x:1756.4},0).wait(1).to({x:1767.6},0).wait(1).to({x:1778.9},0).wait(1).to({x:1790.1},0).wait(1).to({x:1801.4},0).wait(1).to({x:1812.6},0).wait(1).to({x:1823.9},0).wait(1).to({x:1835.1},0).wait(1).to({x:1846.4},0).wait(1).to({x:1857.6},0).wait(1).to({x:1868.9},0).wait(1).to({x:1880.2},0).wait(1).to({x:1891.4},0).wait(1).to({x:1902.7},0).wait(1).to({x:1913.9},0).wait(1).to({x:1925.2},0).wait(1).to({x:1936.4},0).wait(1).to({x:1947.7},0).wait(1).to({x:1958.9},0).wait(1).to({x:1970.2},0).wait(1).to({x:1981.4},0).wait(1).to({x:1992.7},0).wait(1).to({x:2003.9},0).wait(1).to({x:2015.2},0).wait(1).to({x:2026.5},0).wait(1).to({x:2037.7},0).wait(1).to({x:2049},0).wait(1).to({x:2060.2},0).wait(1).to({x:2071.5},0).wait(1).to({x:2082.7},0).wait(1).to({x:2094},0).wait(1).to({x:2589.3},0).wait(1));
      (lib.train = function(mode,startPosition,loop) {
          // Layer 3
          this.instance = new lib.trainNbane();
          this.instance.setTransform(528,-31,1,1,0,0,0,528,156);
      }).prototype = getMCSymbolPrototype(lib.train, new cjs.Rectangle(0,-180,1056,305), null);
      (lib.appwindow = function(mode,startPosition,loop) {
          // timeline functions:
          this.frame_0 = function() {
              var tl = this
              createjs.Ticker.addEventListener('tick',showDate);
              function showDate(event) {
                  var myDate = new Date();
                var theMonth = myDate.getMonth();
                      //increment month by 1 since it is 0 indexed
                      theMonth = (theMonth + 1).toString();
                  var theDay = myDate.getDate().toString();
                var theYear = myDate.getFullYear();
                      //pull the last two digits of the year
                      theYear = theYear.toString().substr(-2);
                //if month is 1-9 pad right with a 0 for two digits
                if (theMonth.length === 1)
               theMonth = "0" + theMonth;
                //if day is between 1-9 pad right with a 0 for two digits
                if (theDay.length === 1)
               theDay = "0" + theDay;
              tl.theDate.text =theMonth+"/"+theDay+"/"+theYear;
              var tl = this
              createjs.Ticker.addEventListener('tick',showTimeSeconds);
              function showTimeSeconds(event) {
              var myTimeSeconds = new Date();
              var theSeconds=myTimeSeconds.getSeconds();
              var theMinutes=myTimeSeconds.getMinutes();
              var theHours=myTimeSeconds.getHours();
              var ampm;
              //Displays am/pm depending on the current hour.
              if (theHours>=12) {
               ampm="PM";
              } else {
               ampm="AM";
              //This subtracts 12 from the hour when it greater than 13.
              if (theHours>=13) {
               theHours=theHours-12;
              if (theHours==0) {
               theHours=theHours+12;
              //Adds '0' if there is only one digit.
              //if (String(theHours).length == 1) {
              // theHours="0"+theHours;
              if (String(theMinutes).length == 1) {
               theMinutes="0"+theMinutes;
              if (String(theSeconds).length == 1) {
               theSeconds="0"+theSeconds;
              //Displays the time in the dynamic text field.
              tl.theTimeSeconds.text =theHours+":"+theMinutes+":"+theSeconds+ampm;
              //tl.theTime.text =theHours+":"+theMinutes+" "+ampm;
              var tl = this
              createjs.Ticker.addEventListener('tick',showTime);
              function showTime(event) {
              var myTime = new Date();
              var theSeconds=myTime.getSeconds();
              var theMinutes=myTime.getMinutes();
              var theHours=myTime.getHours();
              var ampm;
              if (theHours>=12) {
               ampm="PM";
              } else {
               ampm="AM";
              if (theHours>=13) {
              if (theHours==0) {
              //if (String(theSeconds).length == 1) {
              // theSeconds="0"+theSeconds;
              //tl.thatTime.text =theHours+":"+theMinutes+":"+theSeconds+" "+ampm;
          // actions tween:
          this.timeline.addTween(cjs.Tween.get(this).call(this.frame_0).wait(1000));
          // theDate
          this.theDate = new cjs.Text("", "bold 70px 'Helvetica'", "#FFFFFF");
          this.theDate.name = "theDate";
          this.theDate.lineHeight = 72;
          this.theDate.lineWidth = 283;
          this.theDate.parent = this;
          this.theDate.setTransform(435.8,150.6);
          this.timeline.addTween(cjs.Tween.get(this.theDate).wait(1000));
          // theTimeSeconds
          this.theTimeSeconds = new cjs.Text("", "bold 70px 'Helvetica'", "#FFFFFF");
          this.theTimeSeconds.name = "theTimeSeconds";
          this.theTimeSeconds.textAlign = "right";
          this.theTimeSeconds.lineHeight = 72;
          this.theTimeSeconds.lineWidth = 388;
          this.theTimeSeconds.parent = this;
          this.theTimeSeconds.setTransform(417,150.6);
          this.timeline.addTween(cjs.Tween.get(this.theTimeSeconds).wait(1000));
          // time
          this.theTime = new cjs.Text("", "26px 'Helvetica'", "#FFFFFF");
          this.theTime.name = "theTime";
          this.theTime.textAlign = "center";
          this.theTime.lineHeight = 28;
          this.theTime.lineWidth = 140;
          this.theTime.parent = this;
          this.theTime.setTransform(375,11.1);
          this.timeline.addTween(cjs.Tween.get(this.theTime).wait(1000));
          // top
          this.instance = new lib.top();
          this.timeline.addTween(cjs.Tween.get(this.instance).wait(1000));
          // train
          this.instance_1 = new lib.train();
          this.instance_1.setTransform(-528,905.5,1,1,0,0,0,528,62.5);
          this.timeline.addTween(cjs.Tween.get(this.instance_1).wait(1000));
          // tracks
          this.instance_2 = new lib.tracks();
          this.instance_2.setTransform(0,968);
          this.timeline.addTween(cjs.Tween.get(this.instance_2).wait(1000));
          // OrangeStatutes
          this.orangeStatues = new lib.statues();
          this.orangeStatues.parent = this;
          this.orangeStatues.setTransform(156.5,848,1,1,0,0,0,2163.5,120);
          this.timeline.addTween(cjs.Tween.get(this.orangeStatues).wait(1000));
          // ORANGEPLANE copy
          this.oragnePanes = new lib.planes();
          this.oragnePanes.parent = this;
          this.oragnePanes.setTransform(1235,616.5,1,1,0,0,0,1479,157.5);
          this.timeline.addTween(cjs.Tween.get(this.oragnePanes).wait(1000));
          // Orangebuidlings
          this.orangeBuildings = new lib.buildings();
          this.orangeBuildings.parent = this;
          this.orangeBuildings.setTransform(1817.5,647.5,1,1,0,0,0,2784.5,258.5);
          this.timeline.addTween(cjs.Tween.get(this.orangeBuildings).wait(1000));
          // sky
          this.instance_3 = new lib.sky_1();
          this.instance_3.parent = this;
          this.instance_3.setTransform(1509,430.5,1,1,0,0,0,1509,180.5);
          this.timeline.addTween(cjs.Tween.get(this.instance_3).wait(1000));
          // Bottom
          this.instance_4 = new lib.Layer5();
          this.instance_4.parent = this;
          this.instance_4.setTransform(0,981);
          this.timeline.addTween(cjs.Tween.get(this.instance_4).wait(1000));
      p.nominalBounds = new cjs.Rectangle(-2007,0,6609,1334);
      // stage content:
      (lib.metraaaa = function(mode,startPosition,loop) {
          // app-window
          this.instance = new lib.appwindow();
          this.instance.setTransform(375,667,1,1,0,0,0,375,667);
          // background
          this.shape = new cjs.Shape();
          this.shape.graphics.f("#FFFFFF").s().p("Eg6lBoOMAAAjQbMB1LAAAMAAADQbg");
          this.shape.setTransform(375,667);
          this.timeline.addTween(cjs.Tween.get(this.shape).wait(1));
      p.nominalBounds = new cjs.Rectangle(-1632,667,6609,1334);
      // library properties:
      lib.properties = {
          width: 750,
          height: 1334,
          fps: 26,
          color: "#FFFFFF",
          opacity: 1.00,
          webfonts: {},
          manifest: [
              {src:"images/metraaaa_atlas_.png", id:"metraaaa_atlas_"}
          preloads: []
      // bootstrap callback support:
      (lib.Stage = function(canvas) {
          createjs.Stage.call(this, canvas);
      }).prototype = p = new createjs.Stage();
      p.setAutoPlay = function(autoPlay) {
          this.tickEnabled = autoPlay;
      p.play = function() { this.tickEnabled = true; this.getChildAt(0).gotoAndPlay(this.getTimelinePosition()) }
      p.stop = function(ms) { if(ms) this.seek(ms); this.tickEnabled = false; }
      p.seek = function(ms) { this.tickEnabled = true; this.getChildAt(0).gotoAndStop(lib.properties.fps * ms / 1000); }
      p.getDuration = function() { return this.getChildAt(0).totalFrames / lib.properties.fps * 1000; }
      p.getTimelinePosition = function() { return this.getChildAt(0).currentFrame / lib.properties.fps * 1000; }
      an.bootcompsLoaded = an.bootcompsLoaded || [];
      if(!an.bootstrapListeners) {
          an.bootstrapListeners=[];
      an.bootstrapCallback=function(fnCallback) {
          an.bootstrapListeners.push(fnCallback);
          if(an.bootcompsLoaded.length > 0) {
              for(var i=0; i<an.bootcompsLoaded.length; ++i) {
                  fnCallback(an.bootcompsLoaded[i]);
      an.compositions = an.compositions || {};
      an.compositions['A26828080B9749C3AB98ECB4AC46FD1C'] = {
          getStage: function() { return exportRoot.getStage(); },
          getLibrary: function() { return lib; },
          getSpriteSheet: function() { return ss; },
          getImages: function() { return img; }
      an.compositionLoaded = function(id) {
          an.bootcompsLoaded.push(id);
          for(var j=0; j<an.bootstrapListeners.length; j++) {
              an.bootstrapListeners[j](id);
      an.getComposition = function(id) {
          return an.compositions[id];
      })(createjs = createjs||{}, AdobeAn = AdobeAn||{});
      var createjs, AdobeAn;
