4 Replies Latest reply on Sep 4, 2018 7:23 AM by connomar
    Map Not Showing in Photoshop Elements 14
    mattg16300633 Level 1
      I installed PSE 14 on a Windows 10 Pro Dell laptop.  Here's what I'm seeing.  The map is not complete and I can't seem to figure out a way to refresh it.  The photo on the left has embedded GPS data but does not appear anywhere on the map.  When I click on "Pinned", the map is also not complete and no pictures appear on the map anywhere.  It's just not working at all.
      This feature was working fine in PSE 11.  So not sure what's happened.
      Your help is much appreciated.  I really need this feature to work!
      Thanks!
      -Matt
        • 2. Re: Map Not Showing in Photoshop Elements 14
          Thank you for finding that, at least now I know there is no solution and I can stop obsessing on how to fix it.
          So is there any confirmation that this works in version 15?  I'd rather not risk wasting my money to upgrade to equally broken software.
          Forgive my sarcasm, but I doubt Adobe would support an older version(s) when they can simply direct people to spend more money.  I realize this isn't Adobe's fault.  I'm just stuck dependent on a pretty important feature that doesn't work.  :/
          • 3. Re: Map Not Showing in Photoshop Elements 14
            MichelBParis Adobe Community Professional & MVP
            As indicated in that note, that problem no longer exist in the present Elements 15.
            Elements is not the only software to be affected by that Google change.
            There is no secret that only the latest version is supported by Adobe, but there "they are exploring possible solutions"...
            Suggestion: download the trial version of PSE15 which should cover your needs for 30 days. Usually a new version is issued in September/October, so, you might wait before paying the upgrade if you decide so. Otherwise, if you pay the upgrade for Elements 15 less than one month of the availability of Elements 15, you should be good to ask for a free upgrade.
            • 4. Re: Map Not Showing in Photoshop Elements 14
              connomar Level 1
              I read this reply - Basically it's Google's Fault- and assumed that was it for Elements 14.  Then Windows 10 Update destroyed my symbolic links and Elements wouldn't work at all.  I failed to diagnose the problem before deciding to reinstall Elements.  After the re-install, Places worked again.
              As a warning though, I had to completely re catalog everything because I had failed to realize what had happened and I couldn't recover the catalog file.
