When I try to move an item into a different bin I get a popup essentially telling me I can't do that (see image below - red circle with slash). This appears to happen after I select a bunch of elements in a timeline and PreComp them but I can't be sure. This absolutely destroys any ability to work. I can't get around it and even worse it seems to infect old saves as well. Any and all help is appreciated!
The problem seems to be with my dual monitor setup. If I have the project panel on my second monitor there's a large portion of the bins I can't drag to, BUT if I drag the file to the right most part of the bin window it works.
Just solved it... hopefully.
I went to Edit > Preferences > Media & Disk Cache > and chose Empty Disk Cache and Clean Database & Cache
I then restarted my comp. Hopefully that works if you have the same issue.
Are you using the Selection Tool? Sometimes, if you have the Hand Tool selected you cannot do regular tasks
No that's not it. Also, I seem to have spoken too soon. The problem is back and I didn't PreComp anything. I solved it again temporarily by clearing my caches and restarting but I didn't find the underlying issue.
Hi DParsons,
Is this issue still affecting you? Please let us know.
Kevin
I finished the project and haven't experience it in any new ones yet so no new cases to report.
Thanks for reporting back, dparsons85.
Kevin
It's been happening again for the past month. Can't figure it out. Just now I imported one AE project into another and after that I couldn't move any files. Any suggestions Kevin? I'm using AE 14.2.1.34 on Windows 10
I have the same problem - including moving layer orders in the comp window too - it was fine but it seems like a bug in AE 2020 - if i drag to my default monitor it works again for dragging in project panel and reordering layers - it is because the project I am working on is a bit heavy with illustrator files - but its definitely a bug in AE 2020 I've never encountered on previous versions
Seems to bee a dual monitor issue indeed. I fixed it by swapping the 'home' monitor in the finder preferences (Mac).
1. In the finder go to System Preferences > Displays
2. Drag the white bar at the top indicating the home screen accross to the other screen.
