4 Replies Latest reply on Aug 29, 2017 11:41 PM by daviesdesignated
    smart objects
    kyliem26232054
      Smart objects are rastorzing without a window prompt asking me to confirm I want to rastorize the layer.
      How is this happening? Is there a quick key I'm accidentally pressing? Is it a bug?
        • 1. Re: smart objects
          Trevor.Dennis Adobe Community Professional (Moderator)
          I've not heard of this happening before.  Can you describe what is happening in more detail?
          • 2. Re: smart objects
            kyliem26232054 Level 1
            I have large comps consisting of five seperate smart objects each around 70MB each. The whole file is about 6G. I open it to do some amends, however while working on it, going in and out of the smart objects, at some point every now and then a smart object will rastorize. Maybe it's when I'm returning to the main comp? I haven't worked it out yet. Just if I don't check each smart object before I close the document, I end up with phantom rasterised layers. I look back in the history, can see the action- but I've never had a pop up window to confirm rastorization. Other colleges go to work on the file & weve lost a smart object - it flatens it within the main comp as it's cropped to that image size.
            • 3. Re: smart objects
              daviesdesignated Level 1
              If you change colour space (RGB - CMYK) it may rasterize it for you? But that usually pops up a warning.
              • 4. Re: smart objects
                You might also have a keyboard shortcut which does it and you don't realise it - I have mine set to command+shift+R so it's hard to do by accident.
