4 Replies Latest reply on Aug 30, 2017 12:03 PM by soulglowdeej
    What have I done wrong with this IF statement?
    soulglowdeej Level 1
      I'm trying to get a certain buttons to appear depending on score returned in a  given box...but it's not working.
      I can get it to work when there are fewer options and threescore is a > thing, but equal to and more options, I'm struggling with.
      Can anyone see where i've gone wrong?
      var nResult = this.getField("score").value;
      if ( nResult = 200 ) {
      this.getField("adventure_seeker").display = display.hidden;
      this.getField("mountain_climber").display = display.hidden;
      this.getField("deep_diver").display = display.visible;
      this.getField("JOINT AS_MC").display = display.hidden;
      this.getField("JOINT AS_DD").display = display.hidden;
      this.getField("JOINT DD_MC").display = display.hidden;
      this.getField("no_score").display = display.hidden;
      else if ( nResult = 160 ) {
      else if ( nResult = 151 ) {
      else if ( nResult = 40 ) {
      this.getField("adventure_seeker").display = display.visible;
      this.getField("deep_diver").display = display.hidden;
      else if ( nResult = 31 ) {
      else if ( nResult = 80 ) {
      else if ( nResult = 71 ) {
      else if ( nResult = 4 ) {
      this.getField("mountain_climber").display = display.visible;
      else if ( nResult = 13 ) {
      else if ( nResult = 53 ) {
      else if ( nResult = 62 ) {
      else if ( nResult = 22 ) {
      this.getField("JOINT AS_MC").display = display.visible;
      else if ( nResult = 102 ) {
      this.getField("JOINT AS_DD").display = display.visible;
      else if ( nResult = 120 ) {
      this.getField("JOINT DD_MC").display = display.visible;
      else {
      this.getField("no_score").display = display.visible;
      Thanks in advance
        • 1. Re: What have I done wrong with this IF statement?
          Ah, this is an easy one because we've all done this, over and over...
          Means something but not at all what you think. The test for equality is not one equals sign but two.
          if ( nResult == 200 )
          and throughout.
          • 2. Re: What have I done wrong with this IF statement?
            wooo hoooo!!! Thanks Test Screen Name! I can breathe again
            • 3. Re: What have I done wrong with this IF statement?
              You could also set the display to all the fields to hidden and then only switch the needed field to visible for a given score. JavaScript also has the "switch" statement so one does not need to use the nested if statement.
              switch(this.getField("score").valueAsString)
              case "200":
              break;
              case "160":
              case "151":
              break
              case "40":
              case "31":
              case "80":
              case "71":
              break;
              case "4":
              case "13":
              case "53":
              case "62":
              break;
              case "22":
              case "102":
              break;
              case "120":
              break;
              default:
              break;
              } // end switch score;
              This cuts down on the number of lines to code by starting with a known state and changing the minimum of fields and uses a compound case statement to reduce the amount of redundant code. This could also be done with the "if" statement by using a complex logical statement use the logical OR operator.
              • 4. Re: What have I done wrong with this IF statement?
                Hi gkaiseril,
                I think I understand this approach - thanks for the info!
