Hi everyone,
I am manually calling the ApplyGiftVoucher function to apply a gift voucher, but I am receiving errors when doing so. I am making sure to supply the proper parameters:
ApplyGiftVoucher("{{voucher.code}}",{{orderId}},0);
The response status code is 200 when ApplyGiftVoucher is called, but it receives this in the response body:
null; r.error = {"Message":"Specified cast is not valid.","Type":"System.InvalidCastException"};/*
This is causing the following javascript error:
Uncaught TypeError: Cannot read property '0' of null
at ApplyGiftVoucher (Java_OnlineShopping.js?vs=b2333.r510325-phase1:1)
at HTMLDocument.<anonymous> (OrderRetrievev2.aspx:386)
at c (jquery.js:4)
at Object.fireWith [as resolveWith] (jquery.js:4)
at Function.ready (jquery.js:4)
at HTMLDocument.q (jquery.js:4)
This code WAS working when we deployed it. We were alerted by our client that it wasn't working around 2 weeks ago. Does anybody have any ideas as to why this might be broken now?
web2creative​
I logged this with support as a bug at the beginning of August. Bug ID is BCB-4197249
I found the gift voucher was applying in the back end to the order, but firing a malformed response (as you also discovered).
I'm currently dealing with it by using a try {} catch {} and triggering a reload on the cart when it catches the error.
You are awesome. That worked like a charm.
Hi there mrgumbyman, thanks for your valuable input this is exactly what I am experiencing, and having spoken to Adobe it is still an issue that is being "worked" on.
I am not great with scripting and wondered if you minded posting the code you used to catch the error and refresh the page so that I could sort it out in the short term until Adobe have sorted it properly.
Thanks in advance for your help.
(function($) {
// only run where gift voucher can be applied
if (typeof ApplyGiftVoucher !== 'function') return;
// Assign built-in function to a local var
var fnc = ApplyGiftVoucher;
// Re-assign built-in function name to custom method
ApplyGiftVoucher = function () {
// As of 2017-08-08 there exists a bug with response given by the built in method
// surround with a try catch-catch block to avoid blocking other scripts
try {
fnc.apply(this, arguments);
} catch (e) {
// Assume it worked, and trigger a cart reload
$('#cart').find('input,select').first().trigger('change');
console.error(e.message);
})(jQuery);
I'm using jQuery because it's available... hopefully for you too
Hi mrgumbyman​ worked like a charm! thanks so much for posting this so quickly.
The giftvoucher is giving an error:
TypeError: i.value is null[Weitere Informationen] Java_OnlineShopping.js:1:6677
ApplyGiftVoucher http://creastix.ch/CatalystScripts/Java_OnlineShopping.js:1:6677
onchange http://creastix.ch/OrderRetrievev2.aspx:1:1
We tested this with different BC pages and could always detect the same error.
An error due to individual programming can be excluded.
After entering the code, it is not processed. Only when the page is refreshed, the code amount will be charged.
Does this concern the same topic as described here?
Yes, same bug
