6 Replies Latest reply on Sep 8, 2017 3:58 AM by BKBK
    Issue in the order of display of Arabic texts in PDF file generated using ColdFusion
    Abdul L Koyappayil
      I have a query result set as given below.
      I want to display details from this query in a pattern of name1 amount1  unit1,name2 amount2 unit2,name3 amount3 unit3,name4 amount4 unit 4 and that too in RTL (Right To Left) direction since data from the query is Arabic.
      For example : please see the screen shot of pdf file.
      Issue:Order of Arabic text is not correct as expected as given in the above screenshot. Below is the code snippet I used to generate pdf but order of display is wrong.
          <cfset local.qBuckets = QueryNew("amount,name,unit","varchar,varchar,varchar") />
          <cfset Queryaddrow(local.qBuckets,4)>
          <cfset x=1>
          <cfset Querysetcell(local.qBuckets,'amount','غير محدودة',x)>
          <cfset Querysetcell(local.qBuckets,'name','لبيانات المحلية والعالمية',x)>
          <cfset Querysetcell(local.qBuckets,'unit','جيجابايت',x)>
          <cfset y=2>
          <cfset Querysetcell(local.qBuckets,'amount','600',y)>
          <cfset Querysetcell(local.qBuckets,'name','الدولية',y)>
          <cfset Querysetcell(local.qBuckets,'unit','دقيقة',y)>
          <cfset z=3>
          <cfset Querysetcell(local.qBuckets,'amount','300',z)>
          <cfset Querysetcell(local.qBuckets,'name','التجوال الوارد',z)>
          <cfset Querysetcell(local.qBuckets,'unit','دقيقة',z)>
          <cfset p=4>
          <cfset Querysetcell(local.qBuckets,'amount','غير محدودة',p)>
          <cfset Querysetcell(local.qBuckets,'name','المكالمات المحلية / الرسائل القصيرة',p)>
          <cfset Querysetcell(local.qBuckets,'unit','جيجابايت',p)>
          <cfoutput>
          <cfdocument filename="c:\arr-bill.pdf" format="pdf" overwrite="true">
          <table border="0" cellspacing="0" cellpadding="5" align="center" style="width:190mm;direction: rtl;">
          <tr>
          <td style="border-bottom:1pt solid ##000000;">
          <span style="font-size:10pt; font-weight:bold;">Red 750</span>
          <BR />
          <span style="font-size:9pt;">
          <cfset attributes.bucketSep = "">
          <cfloop query="local.qBuckets">
          #attributes.bucketSep# <span style="font-weight: bold;color:black;">#name#</span>
          #amount# #unit#
          <cfset attributes.bucketSep = ",">
          </cfloop>
          </span>
          </td>
          </tr>
          </table>
          </cfdocument>
          </cfoutput>
      Notes: Order of Arabic text is correct in HTML output (in browser). Also , the order is correct in pdf file but only when I remove the span used around the name.
      PDF generating code where order is correct
          <tr>
          <BR />
          #attributes.bucketSep# #name#
          #amount# #unit#
          </cfloop>
          </span>
          </td>
          </tr>
          </table>
          </cfdocument>
