• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Copy command stops in Action
New Here ,
Aug 30, 2017 Aug 30, 2017
I was trying to make a action that uses a contact sheet then i copy and paste my watermark including a return date on it. When i run the action again on another set of photos the copy is gone, which means i cant paste. Does anybody know what could be causing this? It never happened on cs5 only on cs6.
Views
215
Translate
Translate
Report
Report
Community guidelines
community guidelines
Adobe
Community Expert ,
Gone? What are you coping to the clipboard? Did you make a selection open an image select all copy merge it to the clipboard and close the image file. What is gone? Was there a selection did copy work  or was it unavailable.  You can not paste it copy did not work. Post your action...
JJMack
Votes
Translate
Translate
Report
Report
Guide ,
It's likely that you recorded the 'Copy' as part of the action. So now when you play the action it is copying nothing and replacing what was originally in the clipboard. Try removing the Copy element from the action or re-record the action, making sure to omit the copy stage.
hope this helps,
Angie Taylor | http://www.creativecabin.co.uk
Votes
Translate
Translate
Report
Report
Community Expert ,
Aug 31, 2017 Aug 31, 2017
Please post meaningful screenshots, meaning the files open with the Layers Panel visible, the Action fully expanded in the Actions Panel, …
Copy/pasting in Actions and Scripts is usually a bad idea in my opinion.
Placing a Smart Object might be more prudent – as long as one does not remove the placed file from its original location.
Votes
Translate
Translate
Report
Report
New Here ,
Sep 01, 2017 Sep 01, 2017
Thanks for everyone's input....i will be posting a video on the steps in the action
Votes
Translate
Translate
Report
Report
Community Expert ,
LATEST
It would be best to upload your Actions .ATN file to a files sharing site and post a link to it.  Far better then than a silent cinema.
JJMack
Votes
Translate
Translate
Report
Report
