• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Merge query or cfset data with word docx or doc and download the updated version
Participant ,
Aug 30, 2017 Aug 30, 2017
I have a word docx named coded_word.doc that is coded (written)  like this
%COURTESY_TITLE% %FIRST_NAME% , %LAST_NAME%
Dear %COURTESY_TITLE% %LAST_NAME%,
I have cf code like this
<!---Read the file--->
<cfset mydoc= FileRead("#GetDirectoryFromPath(GetCurrentTemplatePath())#coded_word.docx") />
<!---Replace the coded variables in he word doc withthese values. These ultimately will be from a query result--->
<cfset mydoc= Replace(rtf,"%COURTESY_TITLE%","Mr.") />
<cfset mydoc= Replace(rtf,"%FIRST_NAME%","Charles") />
<cfset mydoc= Replace(rtf,"%LAST_NAME%","Jones") />
<!---Then download the modified file--->
<CFHEADER NAME="content-disposition" VALUE="attachment; filename=mydoc_updated.doc">
<cfcontent type="application/vnd.ms-word" file="#GetDirectoryFromPath(GetCurrentTemplatePath())#mydoc_updated.doc">
But when I do I get the original word doc. I don't get  mydoc_updated.doc.
I want to merge/replace the %variable% with actual/set values and need the updated version mydoc.doc to download like this
Mr. Charles Jones
Dear Mr. Jones
QUESTIONS
  1. Do I have the coding correct in the word doc?
  2. Do I need to save and rename the new file before downloading?
  3. Can I use .docx extension or does that create additional issues as I probably can't use <cfcontent type="application/vnd.ms-word" ?
  4. I need the original coded_word.doc to stay the same as it is a template that I'll need for the next query result.
Views
582
Translate
Translate
Report
Report
Community guidelines
community guidelines
Community Expert ,
Aug 31, 2017 Aug 31, 2017
LATEST
weezerboy  wrote
QUESTIONS
Probably not. You're reading mydoc in, but replacing in rtf.
In any case, be aware that ColdFusion is reading and storing mydoc as a binary. So you just can't replace strings within it.
Not necessarily. But this question is irrelevant, as you have to address the others first.
The extension .docx is fine, assuming you have a recent version of ColdFusion. However, its MIME type is application/vnd.openxmlformats-officedocument.wordprocessingml.document.
It may not be as simple as that. As you can see, the MIME type hints at XML. (To demonstrate, extract the docx as a zip file) .You might have to decompose the docx into its XML constituent parts, make the replacements, then recompose the result ....
Votes
Translate
Translate
Report
Report
Resources
Documentation
