Hello,
I have a simple structure in my artwork:
What I need is to export as PNG my groups this way: “group_name_index_R_G_B.png”. RGB value(color) of each <Path>.
Example for group name ground_9:
Most important for me is RGB value color of each <Path>. Also, each <Path> should be same size and with transparency, size of it should be as artboard size where path located. So all png files should be the same size and with 1 triangle inside.
I don't know if with scripts possble to do all this, I would like to listen any advices about that.
Here is sample and very simple ai file: https://www.dropbox.com/s/3372h0au27ssb34/Untitled-1.ai?dl=0
Silly-V could you please take a look at this? Thank you in advance.
Sounds like a fun deal, I'm a bit busy at the moment but I'll take a look as soon as I get some free time!
Thank you. Actually it's a really problem task(nearly impossible) for us without script. We have a lot of graphics with tons of <Path> needed for export. I'm really looking forward for any your thoughts about this.
