5 Replies Latest reply on Mar 22, 2018 8:25 AM by fullflash
    Black screen on Android when returning from sleep
    dews Level 1
      I found a few posts - most quite old - this one appeared to have resolved the issue for some:
      https://forum.starling-framework.org/topic/air-18-black-screen-after-standby-on-android#p ost-82165
      Nothing worked for me - I did figure out a workaround though:
      Add a listener in your main Context:
      NativeApplication.nativeApplication.addEventListener(flash.events.Event.ACTIVATE , activateHandler);
      In the handler - add a dummy object like a button to the stage (you can set its alpha to 0) then simply remove it after a quarter second.  The removal of the object appears to kick the display back on.  Note, if you try to remove the object too quickly, the display will stay black.
